What did we learn from the Chief Engineer?
Discussion in 'Gen 3 Prius Main Forum' started by windstrings, Jan 13, 2009.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    "Two-Speed" seems to be the most appropriate label I've encountered for the design/behavior. It avoids the craziness associated with Two-Mode while indicating that there is a second something available.
    Anyone hear of an official identifier?
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Don't forget Rae, you also have to say his name clearly three times within 5 seconds or you are not worthy! :D
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    I believe it is a fixed planetary gear. I suppose it could be a two-speed planetary gear, but then you need brake bands or clutches, and you start down the path to GM's dual-mode system.
    Tom
  4. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I love you too.
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi all,
    Let me clarify about reduction gears.
    The NHW10/NHW11/NHW20 Priuses have low-speed/high-torque MG2 and the ring gear is driven by the MG2 directly, no reduction gear.
    The RX400h/Highlander/Camry have high-speed/low-torque MG2 and the ring gear is driven by the MG2 through reduction gear (single stage).
    The GS450h/LS600h/2010 Prius are designed to cover wide range of speed more efficiently, then the ring gear is now driven by the MG2 through two-stage reduction gear.
    TOYOTA: Company > Technology
    Ken@Japan
  6. Tideland Prius
    16,680
    hmm....
  7. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The HSDII for the TCH has a second planetary gear set for MG2 speed reduction. The ratio is 2.6:1 and single speed only.
    I believe the G3 uses the same system.
  8. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Japanese press clearly says 2010 Prius has two-stage reduction gear.
    2010 Prius at Detroit show
    Ken@Japan
  9. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Thank you Ken.
    Can you provide for a better link where a nice diagram of the GS450h/LS600h system is found? Anyone?
    I would like to understand what are the connections, what spins with what, and that page that Ken provided at Toyota does not show that.
    P.S. - Ken I have sent you a private message some days ago, can you please check it? Thanks.
  10. qbee42
    18,058
    3,081
    Northern Michigan
    Interesting, Ken. Thank you for the information. This begs several other questions:
    1) How is gearing shifted between the two ratios?
    2) Will we be able to detect the shift, as in some sort of shift shock?
    3) Will the shifting mechanism reduce the overall reliability of the HSD?
    I can take a guess, and that's all this is:
    1) I imagine they are using a planetary gear system where one section freewheels or is locked depending on the ratio.
    2) Shift shock should be minimal, since we are dealing with a fast electric motor, but I'm going to guess that we will be able to detect it. If we can't feel it, then they might be using some sort of smooth braking system on the planetary gear; perhaps an electromechanical lock.
    3) More parts, more mechanical things to break. I don't suppose it's a big hit, given Toyota's track record, but added complexity always concerns me. That's one of the things I like about the original HSD - it's so darned simple.
    Tom
  11. JSH
    JSH Senior Member
    2,605
    140
    PDX
    A two-stage reduction doesn't mean that you will switch between two ratios.
    • A single-stage reduction uses 1 set of gears (2 total) to achieve the required reduction ratio.
    • A two-stage reduction uses 2 sets of gears (4 total) to achieve the same reduction ratio.
    • A three-stage reduction uses 3 sets of gears (6 total) to achieve the same reduction ratio.
    There is no limits to the number of stages
    Why would you want to use two-stage instead of a single stage to get the same reduction ratio? Size. Every additional stage reduces the size of the gears so you can achieve the same reduction ratio within a smaller package. You can also use different stage reductions to change harmonic frequencies to get them to cancel out instead of resonate.
    In Bedrock's PDF from the Compound Gear Unit to the Final Driven Gear is a two-stage reduction.
    The transmission company that I worked for used a two stage reduction from our motor gear to the final gear for packaging reasons. The downside is number of parts, complexity, and cost.
    This is a two-stage reduction from a segway:
    EDIT: If this was a one stage reduction the shaft with the 68 and 17 tooth gears would disappear and the 91 tooth gear would need to be a 360 tooth gear.
  12. bedrock8x
    1,483
    137
    Two stage is different from two speed. Two stages means the final ratio is archived by using two gear reduction sets cascades together.
  13. windstrings
    6,280
    378
    Central Texas
    Did anyone get better info about the near prospect of a "plug in" prius with LiIon battery technology?
    I remember someone asked a subjective question like "what happens when the plug in is available" and he didn't deny or confirm but merely nodded his head.
    Did anyone else catch better info about this?
  14. darelldd
    6,059
    389
    Northern CA
    The PHEV Li version will be in fleet use (by the hundreds) in 2009. There was no word that I heard about retail timing. We also heard that there is no (Toyota sanctioned) way to upgrade the 2010 production car to the later Li PHEV versin.
  15. windstrings
    6,280
    378
    Central Texas
    That really makes this a delima for me... I hope this price is really good.
    With the other technology being the same on the 2010, how much to you suppose a LiIon battery that would store enough to go even 10 miles would change gas mileage?
  16. qbee42
    18,058
    3,081
    Northern Michigan
    Thanks for that clarification. I mixed up stages and speeds. This makes a lot more sense.
    Tom
  17. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    So it seems to me that the final drive system is still two-stage, as it is in the current 2004 - 2008 Prius; does that mean that the silent chain step from MG2 is retained, for weight reduction reasons? The gearing ratio between the higher RPM MG2 motor is probably increased to provide the enhanced 0 - 60mph acceleration, since the larger (1.8L) ICE torque curve at low speed is probably not much better than the smaller 1.5L ICE in the current Prius.
    This is a lot of guessing on my part; I'm sure those with more info can correct and enlighten me!
  18. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I don't think any of us will have correct info until Toyota releases their NCF guide for the 2010 Prius and makes it available at techinfo.toyota.com
    They're usually VERY elaborate on changes and technology.
  19. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The question I got to ask was about grill-blocking. I suggested the Prius seemed to have excess cooling capacity, particularly for some climates at certain times of the year. I asked if there was any thought given to thermostat-controlled louvers on the air intakes, which would lower the aerodynamic drag and improve the cabin heating and the mileage. I got the impression he'd love to be able to do something like that, but cost considerations pretty much ruled it out.
  20. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    Bummer. I CAN NOT believe it would cost more to make thermostatically controlled louvers than to stick a sun/moon roof on it. No concerns about water leakage, no 'tight tolerance' for windage when closed. No 'pop up / slide back' design and motor issues. No lost head room ;)
    The 'deciders' at Toyota just have not yet been convinced there are a LOT of people who could benefit from such a system. Do they know how many people are strapping pipe insulation over the lower grill and stuffing it into the upper grill?? Probably a good number of the 'special invitees' at the show. I suspect I could foam the entire engine compartment tonight (other than engine air intake) and not have it over heat tomorrow, it is supposed to be -17F.
