  1. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Did the first oil change since taking ownership. That filter housing was a nightmare. The dealership must've put it on with air tools. Finally got it, but it was a joke how tight it was.
    After that was done, I ordered Clazzios from Rodney. Super excited for those.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
  3. techno-Zen
    techno-Zen Junior Member
    Mesa, Arizona
    Where did you get those?
  4. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    Ebay seller from China: http://bit.ly/17KQB5n
    I did the electrical knock-out cap thing, sprayed them enamel black to prevent rust inside the wheel from metal-metal contact, then crazy-glued these on. The peel-off glue that comes with the emblems aren't sticky enough to hold securely.
  5. Gouda Cheez
    Gouda Cheez Junior Member
    73
    Looks good. I've been thinking of picking up some 1" stickers to put on my centercaps. Still undecided.
  6. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I wiped the hardware caps down with alcohol and the stickers hang on just fine.
  7. Gouda Cheez
    73
    Debating if I want white to match the car or silver to match the lug nuts. ;)
  8. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Took it to the dealer for a 10,000 mile check up. Tires rotated and oil change. Also picked up one those wide rear view mirrors
    Galaxy Note 2 ? 4
  9. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    I prefer the flat, non-distorting type of wide mirror. Those convex ones give me a headache. :(
  10. riceroni87
    360
    598
    Oxnard, CA
    I might pick one of those flat ones too. They were 15 bucks at the dealer (valley hi toyota)
    Galaxy Note 2 ? 4
  11. Gouda Cheez
    73
    Finally put some air in the tires today. They were only set at 32psi from the factory and I bumped them up about 10 pounds. :)
  12. ePrius
    ePrius Member
    162
    76
    Trying to figure what happened to my fog lights. They were working on Tuesday and now they don't; already checked the bulbs! ;)
  13. burstaneurysm
    469
    144
    Chicago, IL
    Check the fuse.
  14. ePrius
    ePrius Member
    162
    76
    That's what I'm thinking. Thanks!
  15. xliderider
    8,140
    3,276
    Honolulu, HI
    Check the fuse. If the fuse is okay, then the relay might have gone bad.
  16. xliderider
    8,140
    3,276
    Honolulu, HI
    If it's an add on kit, then also check the tap where the trigger wire for the relay gets it's power from the brown wire.
  17. ePrius
    ePrius Member
    162
    76
    It is an add on kit. I am hoping it's not the relay as I installed a STB.
  18. ePrius
    ePrius Member
    162
    76
    Thanks burstaneurysm & xliderider for your help! Fuse replaced! :)
    burstaneurysm likes this.
  19. FishCandy
    FishCandy Active Member
    220
    292
    Hello Modders, have not been on for awhile but I just installed Cusco's Power Bracing - Rear, Mid and Front, with Front Sway Bar and Upper Strut Power Bar. What a difference! Car is very nice and stiff, makes driving more fun and my wife told me she totally felt the difference! Totally worth the investment. Ask for Kenji at Cusco and tell them I referred you. Totally worth the investment.
    Also, added Ran-Up, oil additive. Great product! I noticed that our idle had become very smooth and you could definitely feel less vibrations from the engine. I was like no way this is when I was in POWER MOD. Seems that they use this Ran-Up oil additive on the space shuttle...
    sfv41901, David2sav, nedear88 and 2 others like this.
  20. Pando
    Pando New Member
    Did you put covers on top of headlights? Looks like a different car now.
