  1. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Bought this !! Can't wait to get it on!!!
    ckam1989 and Tweaksalot like this.
  2. Grren4ever
    Grren4ever Active Member
    347
    167
    wow...everyone is modding their car this summer. Can't wait to see it on your car :)
  3. Grren4ever
    347
    167
    Ray's Forged lug nuts w/ locks. Not cheap for little pieces of bolts, but doing the best to keep everything on my car high quality and "made in Japan" :)
    My goodness they are lightweight.
  4. Grren4ever
    347
    167
    Spent Friday night test fitting my new JDM wheels:
    New JDM wheels vs Prius Plus wheels. Which setup is lighter?
    17' forged w/ Toyo Proxes A20 weighing in at 38.4lbs.
    My setup weighing in also at 38.4lbs! How uncanny. I don't anticipate any MPG loss with the LRR Michelin's.
    After months of research on the internet, Priuschat and debating on colors/offsets/spokes, I am extremely happy with the setup. Ray's forged lug nuts give it the finishing touch.
    Stock 50mm offset still OK.
    KennyGS, Tweaksalot, ckam1989 and 2 others like this.
  5. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Can't go wrong with SSR's!!!!! Looking good
  6. A617
    A617 Member
    213
    95
    OKC, OK
    Just did a metallic hybrid 30% tint all around except windshield, camera makes it appear darker then it is, but its really nice.
    Michael325 and ckam1989 like this.
  7. Horsefeathers
    Horsefeathers Member
    104
    59
    SW Georgia
    Well, then. I got a $5 fundraiser car wash done today by some kids. Water spots and random application of Armor All included. They just think of everything! No pictures. You can imagine.
    I also vacuumed it out and installed some new seat covers.
    KennyGS, ckam1989 and Grren4ever like this.
  8. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    So jealous right now!
  9. Grren4ever
    347
    167
    It took me a long time saving for that setup; and a lot of hard earned dollars too...plus lots of sleepless nights thinking about how it would look - It was not a breeze to arrive here! I hope the pictures help you and others out so that they don't have to go through what I did!
    Seriously tho, good luck - I think you'll be pleased with the 18 inch setup we were chatting about!
  10. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    Well a few of us went to Toyotafest yesterday, to show off are hard work. :rolleyes:
    KennyGS, Dawit, ckam1989 and 8 others like this.
  11. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    Began first part of Operation Rodent Proofing the Prius.
    Following ebsmythe's example in MouseProofing the Prius | PriusChat :
    I decided to screen "from the outside" in order to keep the foam rubber flappy vents behind the screen, and realized I could do this by removing the rear bumper cover.
    Shot with vent cover insert removed
    After screening..
    I'm using standard 1/4" galvanized steel hardware cloth for my screening material. Fasteners are stainless steel M10 x 1/2" self-tapping sheet metal screws with hex heads and largish stainless steel washers from Fastenal. (Forgot to take a pic of the screened LH side. The screen there is smaller but the idea was the same.)
    Checked all spots first to ensure wouldn't be screwing into wiring or other obstructions.
    There are L-shaped blocks of yellow-white foam attached to the inside of the plastic bumper cover, aligned along the
    bottom and rear edges of these rectangular vents. At first, I thought, if I can't screen off the entire volume space encompassed by the rear bumper cover, perhaps I could at least screen around these foam blocks which would prevent rodents from harvesting it for nesting material. On the other hand, that's a lot more effort, especially to fit screening between both the cover and the chassis, just to protect foam I could probably buy and glue back on for less. Still, I dislike the thought of rodents there at all.
    When I get the opportunity, the vent ports in the firewall of the engine compartment will be next, along with air intake. Also recall seeing a hole in the floor pan diagrams. It's supposed to have a cover, but if that's plastic or some other soft material, it could pose another potential ingress point. This should cover full exclusion, of the cabin area, at least. Am also thinking of doing the rustproofing spray as an additional deterrent. It sounds plausible since, although mice|rats aren't averse to touching grease, they probably don't like it if it's inedible and any petroleum scent from the spray would reinforce that.
    Will probably look to the engine cover set, including cable connector covers. Unfortunately, there're still a vast amount of wiring running everywhere. Ideally, I'd like to be able to physically exclude off the entire car, including the engine compartment. Removing the bumper cover has demonstrated to me though that that entire volume of space that's "within the car" but outside the cabin itself doesn't really have much of a solid shell bounding it. The entire underside of the car is a mish mash of pieces of flexible plastic, some partially overlapping others, with occasional plastic fasteners. The flexibility's great for deflecting small pebble kickup from the road, but there're countless seems and ledges any rodent could easily squeeze through.
    Wolverine88, Haschwalt and Grren4ever like this.
  12. Michael325
    Michael325 Member
    85
    57
    Central Valley CA
    Today I tried to put an LED parking light in and dropped it. So cool. Had a horrible time baking to paint too. image.jpg
  13. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Man, that sucks. Did you get it out?
    PlusIV
  14. Michael325
    Michael325 Member
    85
    57
    Central Valley CA
    Nope too lazy. I'll leave it til next weekend. Hopefully I won't have to bake it again.
  15. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    You can remove the headlight housing and shake the loose light out of the highbeam socket (remove 9005 highbeam bulb first). If you can't do that, then you can use one of those small parts grabbers that have a claw on the end and activated by pressing a plunger.
    SCH-I535
  16. Michael325
    Michael325 Member
    85
    57
    Central Valley CA
    Thanks!
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Meet up with Chunker today & installed a pair of 3in1 signal mirrors. Hopefully he'll post some pics as I forgot.
    VS980 4G ?
  18. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    Hi Michael,
    I did the same thing. :mad: Easy fix:
    • Remove headlight bulb
    • Attach tape (sticky side out) to long zip tie or other bendable piece of plastic,
    • Reach in, fish around, stick to LED,
    • slowly remove LED! ;)
    tankyuong likes this.
  19. Michael325
    Michael325 Member
    85
    57
    Central Valley CA
  20. Chunker
    Chunker My name is Chunker...I wear a hat
    71
    Ohh...I should post some pics...I'll take some tomorrow. Thanks again man!
