  1. Topher
    Topher Member
    32
    32
    Pasadena ca
    Where did you order the center caps?
  2. ibmoses
    ibmoses Junior Member
    109
    22
  3. Michael325
    Michael325 Member
    85
    57
    Central Valley CA
    A member posted a thread bout some caps. I bought mine from lowes and spray painted them black lol. Some electrical cover caps or something, it was like $3.
  4. C.R.E.A.M.
    C.R.E.A.M. Member
    55
    68
    39
    Sacramento, CA
    Plasti Dipped my front and rear Toyota emblems, removed the Prius and HSD from rear. Trying to find a good way to plug the holes they left but I also might put the emblems back in place if I can't find a good solution. IMG_1621.JPG IMG_1615.JPG
  5. ibmoses
    109
    22
    Any of youse guys got pics of a bug deflector mounted and comment on fit?
    Im thinking I want one:)
  6. OkCorrell
    OkCorrell Junior Member
    Where is the link for this mod?
  7. OkCorrell
    How much was this? Can you attach the link for the write up or the person who you bought this from, please?
  8. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    JDM / Japanese VIP Styling: My Prius III Build | Page 15 | PriusChat
    Justdidit likes this.
  9. David2sav
    David2sav david2sav
    107
    171
    San Jose, California
    My GF 's prii got messed up and we aren't sure how. Does anyone know the part number for the back plastic wing (oem). Here are pics to help. Thanks!! uploadfromtaptalk1403149902489.jpg uploadfromtaptalk1403149916563.jpg
    SM-G900T ?
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I've got 1 I can sell u :)
    VS980 4G ?
  11. xliderider
    xliderider Senior Member
    8,136
    3,274
    Honolulu, HI
    Installed aluminum mesh behind my upper and lower grilles to protect the radiators from stone damage.
    Lower grille from the front:
    Upper grille from the back:
    Will get a pic tomorrow from the front. It was dark by the time I finished today and put everything back together.
    SCH-I535
    sfv41901 likes this.
  12. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Just a guess. Many times someone closes a trunk or hatchback, they have a set of keys in their hand. Could be a house key? One of our former hatchback cars had a similar scratch and and that's how if figured it happened. Second guess is that something was placed on it and got scratched removing it.
  13. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    How did you anchor? I just received my mesh the other week. I was think of hot glue, but it looks like you may have used zip ties?
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    planning on doing the exact same thing
    VS980 4G ?
  15. David2sav
    David2sav david2sav
    107
    171
    There is impact damage at the tip of it, so something had to hit it hard and then scratch the surface.
  16. xliderider
    8,136
    3,274
    Honolulu, HI
    Maybe the hatch hit something on a low ceiling, a branch, or something, when opened? Very common.
  17. Gaspeed
    Gaspeed Senior Member
    286
    1,624
    San Diego CA
    Do you park in a garage? If you do, this is what might of happened. While parked in the garage with the garage door open and your trunk open...then you close the garage door while your trunk is open all the way...the long metal bar of the garage (the one near the chain thingy on top) will hit the wing on your trunk. I only say this because it happened to me. Looking at your pictures the scratch pattern is similar to mine and the tip of my wing was actually chipped a bit.
    Burna J likes this.
  18. xliderider
    8,136
    3,274
    Honolulu, HI
    Yes, I used zip ties. Pic was taken before clipping the ends. Threaded them through the holes where the clips are located around the oem grilles. Main drawback is the zipties show from the front, around the edge of the bezel, which is why I used black zipties.
    I'm thinking the zipties will deteriorate with time and the elements though. But the car is garaged and doesn't see much sun.
    I ran over a semi truck's shed tire tread laying on it's side on the freeway the other week. It made a big bang and more commotion as it went under the car.
    If you look good at the pic of the lower grille, the lower left vertical brace on the lowest two louvers is missing. The other one above it is cracked off the louver on one side as well.
    I guess I got lucky that the damage wasn't as severe as your encounter previously. Also, that I didnt put the mesh on yet, because it might've messed it up.
    If my car was lowered, the impact certainly would have caused more damage to the front end.
    #4358 xliderider, Jun 19, 2014
  19. David2sav
    David2sav david2sav
    107
    171
    My GF does not park her car in a garage while at home, who knows what she does with it while at work. I'm pretty sure she parks outdoors though. I think someone else did the damage to her vehicle.
  20. Grren4ever
    Grren4ever Active Member
    347
    167
    Hi Davidsav,
    A few times I almost inflicted a scratch like the one on your spoiler by accident; onto my car
    For example, in my garage, there is very low ceilings so if I open my trunk, it will bang onto the ceiling of the "opened" garage door and may scratch. Also in a few public underground parking garages, the concrete ceilings are very low and the same thing can happen if one opens the trunk without taking into the consideration the car trunk swinging upwards. In one of my previous cars - a 2004 mazda 3 hatch, I left the hatch open in the garage and closed the garage door. The garage door arm connector scratched the entire trunk and ripped off the rear wiper. Costed me $400 worth of damages at the body shop.
    Also, did anyone put any sort of box on the spoiler and then drag it off as opposed to lifting the box off? If the box has been on the floor, it could have picked up small rocks and being dragged off the spoiler may create a scratch like that...especially if the box was heavy.
    Good luck.. maybe you can take this opportunity to upgrade to a carbon fiber spoiler:
    Advan Carbon - The leading retailer of quality carbon fiber body kits, car body kits, rear spoilers.
