  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    the thing is, I already have DRL on my headlight, what does the webelectrics module do ?
    Since, my low beam and high beam share the same light bulb, I actually like it the way it is connected right now, cause the DRL low beam is disabled, however when I put on high beam the low beam bulb will still work.
    I tried tapping the L shape LEDs to the DRL headlights, and when I put it on high beam, it lights up :)
  2. El Nino
    El Nino Member
    210
    Michigan
    As long as you always have 100% power when on you are fine. If the power you get at any point is lowered (such as night time driving dimming) then I would be cautious as it could mess up your DRL leds. The module is just 100% on when headlights are off and off when headlights are on. It uses a tap into the parking light to determine your lights are on.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    We are talking about ur gen3.....right? How does the low & high share the same bulb when the gen3 has project tor low beams & a separate reflector high beam?
    I'm a lil confused.
  4. eco-icon
    eco-icon Junior Member
    137
    what's the name of the ano you are using?
    Nexus 7 ? 2
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    What is ano?
  6. El Nino
    El Nino Member
    210
    Michigan
    ANO YOU WAS GONNA ASK THAT. lol
    Mic2go likes this.
  7. ucsmfu
    1,498
    420
    canada
  8. ockevin
    ockevin Active Member
    493
    148
    Orange County
    What the hell is ANO...?
  9. kmkremer
    kmkremer Member
    227
    30
    San Diego
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    In video game speak it means you have turned your characters online presence off (anonymous) so others don't know you online and try to send you messages. LOL
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    My online status isnt hidden
    F8L likes this.
  12. ucsmfu
    1,498
    420
    canada
    hey sean, my DRL and high beam share the same bulb. I will take a picture for you to see, the're a halogen bulb, than 2 led projectors beside it.
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    So ur high beams are also ur DRLs & they prob run at 1/2 power which will not power ur new "L" DRLs. Best thing you can do is get the webelectrics DRL-2P module
  14. ucsmfu
    1,498
    420
    canada
    cool ! thanks.
  15. ucsmfu
    1,498
    420
    canada
    i tried plugging the L DRL's in the DRL connector, and they light up, do you think it will hold up or best still to get the webelectrics module ?
    thanks
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Only time will tell. If it work u might as well spend the money on another mod.
    Do u plan on leaving the high beam bulb hooked up?
  17. ucsmfu
    1,498
    420
    canada
    hmm, so right now the L Leds will light up as DRL, turn off when my headlights come up and turn on again if I'm using High beam.
    Is there anyway to modify one of the 2 led projectors to high beam ?
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Not with out opening the headlight & re-wiring the LEDs. The LED projectors each use their own LED & they are both powered from the same LED ballast
  19. ucsmfu
    1,498
    420
    canada
    If I were to keep my high beam bulb for high beam usage, where can I connect the L Leds for DRL to ? is it using the webelectrics module ?
    thanks !
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Yes. The webelectrics will have 4 connections.
    1) accessory power when in ready mode
    2) ground
    3) power from low beam headlight
    4) power to new DRL
