  1. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Dropped by @sfv41901 pad to install G headlights. Clean work, as usual! Hit him up if you need mods done.
    #5681 saulbassfan, Dec 20, 2014
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    So now you have 2 sets of LED running lights? I noticed you have the turn signal/LED DRLs/foglights as well.
    SCH-I535
  3. saulbassfan
    979
    3,108
    Southern California
    The fog drl lights are disabled. Gonna change bumper eventually.
  4. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    Looks great @saulbassfan !!
    I guess Sean thru one of his mini mod parties today.... I can see @apt5020 is up next. (y)
    saulbassfan and sfv41901 like this.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Busy weekend.
    Finally upgraded to the 24mm front sway bar on my 2007...makes SUCH a difference.
    Then finally put in these DIY retrofited Mini H1 satin black trim, smoked chrome headlights with TRS Morimoto XB LED DRL.
    Out with the old...in with the new
    #5685 Justdidit, Dec 20, 2014
  6. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Another excellent job by @sfv41901. Got the light door sills installed and side mirrors. All 4 sills has blue LED.
    sfv41901 and Blizzard_Persona like this.
  7. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Those door sills look amazing!! How hard was install and how much did you pay for them?
  8. apt5020
    881
    1,294
    Prius City, CA
    Here is the link. I got them for $139.90 vs $109.90. The $139.90 light up the whole bar. The $109.90 only light up PRIUS, I think. I had to do a little modification on the passenger rear side. The screw didn't fit.Wasn't a big deal. Wiring was a pain. @sfv41901 did a super job on that. Figuring out the correct wire to tap is tough. There are no instruction that come with it. Each door will light up when open.
    Toyota Prius ZVW30 10 Up LED Light Door Sill Plate Stainless Steel Scuff Blue | eBay
    vs
    Toyota Prius 10 Up LED Light Door Sill Plate Stainless Steel Enhancement Blue | eBay
  9. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Those from TRS bend that much? Had no idea! Cause even you ask they only day 'a little.'
  10. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    removed the projector fogs and replaced it LED ones...... (no pics yet)......
    the projector fogs will be up for sale soon........
    these is the projector fogs that would be for sale:
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Bino, do you feel the beam pattern is better with the LED ones?
  12. Sean Callahan
    Sean Callahan Senior Member
    314
    582
    Honolulu
    Started figuring out my layout for my air. I think I'm gonna run something like this hidden in my trunk area above the spare tire well. Nothing is mounted but basic idea of what it may look like.
    My 2013 Prius TWO Build | Page 11 | PriusChat
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Nice, is the pump very loud? I've been slightly looking at a bag setup for my car, not so i can drop it to the frame but the convenience of adjustable height within seconds. Plus, i've heard that you can increase the pressure of some systems and make the ride tighter or softer.. perfect for a sport suspension or if your just cruising.
  14. Sean Callahan
    314
    582
    Honolulu
    Yeah I heard that too, different compressors are rated to different psi. That's the reason I'm doing it really so I can park and lay frame and not be limited to where I am able to drive. I don't want to have to turn around and go another way if something is to steep or a speed bump is to big.Oh also sorry to answer your question I'm not sure about the compressors though. I've never ran an air system before. I don't think they will be to bad though under there providing a sound barrier. Also I have two compressors so they won't be running very long when they do come on. I rode in my boys bagged car it was in a box and in his trunk and I didn't hear it at all. But that also wasn't a hatchback.
    Justdidit likes this.
  15. Hussain
    Hussain Junior Member
    Sacramento, CA
    How's the light output compared to halogen fog lights? Not sure if I should get these or have projector fog lights retrofitted with 55w hids. This would be significantly cheaper.
  16. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    image.jpg image.jpg Today I finally washed my Persona for the first time :)
    I pumped up the tires from 40/38, to 44/42 and will see how that goes.
    And made an appt for tint Tomm morning. 5% all around. I can't wait.
    Am thinking of having the roof wrapped as well.... Any suggestions ie. gloss, matte???
    #5696 Blizzard_Persona, Dec 21, 2014
    RightOnTime likes this.
  17. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I will find out in the next few days that I will be driving with the LEDs...... these (projector fogs) are actually pretty good.... I just want to try out the LED fogs that has been sitting on my garage for a while.......
  18. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    Led's are brighter, also wider light output coverage. Projector hids will definitely be brighter than leds.
  19. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    Got my Prius last week, so this is basically my 2nd post. But for my first mod, noticed the blue backing behind the emblem was just thick glossy paper. So i found this dark navy blue Plasti Dip for the Emblems, and then bought 80lb glossy photo paper and clear gloss for outdoor use to make the backings. I scanned the front and back, uploaded to Photoshop, then basically just played with the hue/saturation and used magic wand tool for making a carbon fiber and "Pixar's Up" version :)
    [​IMG] [​IMG]
    I'll post them mounted tomorrow. I haven't added the outdoor gloss yet.
  20. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Tint is all done. 5% all around with the sunstrip on windshield.
    Was quoted $250 for the roof in 3m gloss black. Eventually will get it done.
