  1. Boston Jim
    Boston Jim Active Member
    202
    148
    Pictures below. It is a very very close fit (mm), it couldn't be any closer, the floor fit's flush, but I could see it touching if you put anything heavy on the floor. Though this would be touching the top of grill. It might be possible to find a slightly smaller grill cover. Thankfully no rattles or buzzing from anything :)
  2. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    Did this today... bought blind spot mirrors from Canadian Tire, took the lens of their black plastic housing then mounted 'em directly to the side mirrors. Makes it sit flush and more like part of the mirror, IMHO.
  3. BPZVW30
    BPZVW30 Member
    73
    141
    Did the LED headlight swap. Plus had the reflector painted #070. Haven't seen one like it before and I thought hey, go for it!
    These lights are simply amazing.
  4. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    Are those OEM?
  5. slowpriusj
    167
    271
    Brunswick, MD
    Been thinking about putting a sub here or doing a bazooka tube, how is the sound? Love the clean look, where is your amp?
  6. Boston Jim
    202
    148
    The sound is great, but I'm pretty sure any sub added to the Prius would sound much better than stock. It would depend if you can give up the space in the trunk for the bazooka, I really didn't want to lose the space. The amp is under the passenger seat.
  7. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
    @BPZVW30 That's bad nice person! Was it tough to remove the reflector? I noticed you left a small part of the Orange reflector which is smart.
  8. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Behind the part he left orange is where the bulb shines through
  9. BPZVW30
    BPZVW30 Member
    73
    141
    Yes OEM from MY 2012-2013.
  10. BPZVW30
    BPZVW30 Member
    73
    141
    Thanks @Ramtart. I didn't split the headlight apart, had a shop do this for me so not absolutely sure how those pieces separate. I'm sure someone here will know though.
    Ramtart likes this.
  11. BPZVW30
    BPZVW30 Member
    73
    141
    That is correct @Accordlayingkit. This exactly how I wanted to look and function.
    Accordlayingkit likes this.
  12. Accordlayingkit
    1,616
    1,747
    377
    Gotta bake/heat the lens and separate the lens from the rest of the light unless they were able to get the lens off enough at the corner to take it out.
    Ramtart likes this.
  13. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
  14. Thanh Tran
    Thanh Tran Member
    104
    77
    Anaheim, CA
    shaved emblems and color matched front emblem!
  15. BPZVW30
    BPZVW30 Member
    73
    141
    Before and After shot:
  16. BPZVW30
    BPZVW30 Member
    73
    141
    DRL's on with Parking and LED headlights.
  17. BPZVW30
    BPZVW30 Member
    73
    141
    What it looks like right now.
  18. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Updated to newer LED's in the trunk and the dome/map lights. MUCH brighter…
  19. Delta Flyer II
    547
    248
    69
    I love the white bulbs…. I did the glove box too…
    Anyone have pics of the Persona Blue bulbs in action?
  20. Xterra72
    Xterra72 Senior Member
    1,432
    1,678
    Not the best pictures but you get the idea.
    20141031_061746.jpg 20141031_061821.jpg 20141031_062630.jpg 20141031_062422.jpg 20141031_061409.jpg
    Ramtart likes this.
