  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    hey F8L, i'm running the motivo nitto tires on my PP wheels, and lately I've been noticing rattling sounds coming from the left window, and some creaking sounds here and there, will I get a more comfortable and smoother ride with the Michelin MxM4 tires ?
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    What pressure are you running? How cold has it been when you notice these rattles?
  3. ucsmfu
    1,498
    420
    canada
    i'll have to check the tire pressure today, what's the ideal psi i should be running at ?
    Also, the weather was around 10 degrees Celsius or below, when the weather was warm, I never noticed the sound with the windows rattling, and I keep my car outside, it's about 8-9 degrees Celsius now, and some mornings are 3 or below 0.
    Does the cold cold weather have an affect on the wheels and the rattling sounds ?
    I've started noticing squeaking noises for my TRD springs too, especially when I sit in the car, brake, releasing the parking brake, and stopping uphill or downhill.
    thanks
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In colder temps the plastic parts in our cars rattle more often than in warmer temps. Low profile and/or harder tires can make this worse. When temps are 45F and lower, tires become less pliable (harder) and will ride rougher. Road surfaces also become less pliable. The whole thing leads to a rougher ride and rattles.
    Check your air pressure and maybe try lowering it to factory specs to increase ride comfort. I doubt switching tires willcure the rattles 100% and I would suggest trying a few things with your current setup before you spend any money. :)
  5. ucsmfu
    1,498
    420
    canada
    what's the ideal psi I should have it on right now ?
    thanks
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That's up to you. I would say no lower than 35 and no higher than 40. Please report back on what the pressure was and what it is later and if it helped reduce rattles. :)
  7. ucsmfu
    1,498
    420
    canada
    for sure :)
    thanks !!!
  8. allen2oo3
    allen2oo3 Junior Member
    44
    Orange County, CA
    Just finished installing xenon supply 4300 kit. Used "xsforum15" for 15% off
    sarir97, Chwaz and F8L like this.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I installed the lower grille block. Waiting for colder temps to do the upper. Highest coolant temp has been 195F at 70F ambient temperature. On average coolant temp is only 2-3 degrees hotter than without the grille block.
  10. allen2oo3
    44
    Orange County, CA
    At what temp should I be thinking "oh crap i'm about to overheat"? I'd like to keep an eye on it when driving through the desert for vegas.
  11. jmrmotorhead
    jmrmotorhead Junior Member
    85
    44
    New Hampshire
    From my research I have read the radiator fan will kick on at 194 *F. Optimum coolant temp is 154-194 from that same source.
    Based on that I would assume that in the desert heat you may hit 194, but as long as it doesnt continue to climb real high you should be fine!
    Hope this helps
    And today I installed an OBDII bluetooth adapter and did a full grill block (cold here in NH). Havent seen any coolant temps above 145 in my short commute.
    Matt
    allen2oo3 likes this.
  12. watchingthetides
    watchingthetides Junior Member
    33
    46
    I just got in jdm steering wheel... was going to try to do it myself but i think it would be better if i found someone to do it for me. Anyone from the tampa bay area that can make some recommendations? =)
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Too bad ur not closer caise im about to do my swap over the weekend :D
  14. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    Installed the Tanabe under-brace today. Big thanks to Tracksyde for providing the torque specs for the install.
    ucsmfu and Adam Leibovitch like this.
  15. watchingthetides
    33
    46
    Just got my Eco emblem in the mail..will be sticking on the car once it stops raining
  16. wotcher
    wotcher Member
    403
    97
    16
    LA
    did you buy it and how much?
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I jut removed two slats on lower grille blocking. I noticed while climbing uphill my temp was hitting 202F and would only drop to 198F. Once I got onto flat areas it stayed at 195F. It is 66F outside and dry. When I pulled out one of the foam pieces the air inside the bumper smelled like hot plastic? I'm keeping the grille only 50% blocked for now. I'll report back if more foam needs to be removed.
    sfv41901 likes this.
  18. jmrmotorhead
    85
    44
    New Hampshire
    Good to know. Hills + full lower block +65* Temps = Bad
    Anyone ever come to a conclusion about the inverter temps? Its 35 and below here and I've seen consistent 80-90* temps on both inverters. The inverter coolant has been in the low 80's but the individual inverter temps have spiked up to 122, and were at a consistent 100 for a while today. Thinking of removing the upper grill block.
    Pulled the plastic hubcaps off my rims today and picked up from center caps from HD. What a difference! Wheels look 100% better now.
    Matt
  19. Adam Leibovitch
    498
    102
    Got bue accent stickers for the steering wheels toyota emblem
    JE Sukara, sfv41901 and mnml like this.
  20. J Dunn
    J Dunn Active Member
    118
    169
    Newport Beach
    Where did you get those? I've been searching for the steering wheel emblem, but what I want most is the front and rear emblem with lime green instead of blue! Thinking I may have to get one custom made?
