  1. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    Fantastic! Thanks!
  2. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    I'm a newbie here, though I've been lurking since purchasing a PIP last April.
    Mods to date:
    FIAMM horns, installed those within a month of purchasing the PIP
    H9 headlight bulbs
    Dash cam, installed that after some knucklehead turned in front of me, causing $7k damage to my almost brand new car :(
    After work today, I started on a small sound dampening project and finished the driver's door. I applied several pieces of Dynamat to the outer door skin and two very small pieces on a couple "tinny" sections of the inner door skin. Then, I covered the inner skin with Frost King, sealing the edges with foil tape.
    Now the driver's door has the same solid thump as the 2012 Mercedes that I had before getting this PIP.
    Tomorrow, I will do the passenger front and will attack the rear doors later in the week.
    hat tip to sfprankster for the frost king idea
    #6622 scrappy, Mar 25, 2015
  3. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    modification to the existing bumper is required. You need to drill holes (3/16 drill bit) into the spots indicated. then basically screws on. I dont have fogs, but wanted a mesh grille to not use foam electrical tubes anymore when grille blocking in the winter.
    was definitely a hard decision though since I almost ordered the ebay yellow fog kit. but remembered I barely used them in the jeep.
  4. Dark Knight
    Dark Knight Junior Member
    20150322_184355.jpg 20150320_144957.jpg 20150320_221419.jpg 20150320_231534.jpg Post interior, plate and front marker leds. Not sure on the blue yet may switch them all to white.
    Burna J likes this.
  5. prius blk
    prius blk New Member
    los angeles
  6. Xterra72
    Xterra72 Senior Member
    1,432
    1,678
    Most expensive modifications to date.:D
  7. Boston Jim
    Boston Jim Active Member
    202
    148
    Well, I was going to attempt to install my horns today since it's finally in the mid 40's (and rain expected tomorrow). but I learned there is very little room to work (as compared to my Prius v). And I really do need a 14mm wrench. But since I had the front emblem off I decided to try switching the blue out.
    Thanks again to @Starbrand I had a copy of the emblem to play around with the colors. This is just a first test, I picked a green close to the color of my license plate holder, but it ended up a bit lighter than I wanted it to be. I'll need to scan in the license plate holder for an exact color match. Then I printed it out on normal paper and covered both front and back with a layer of 'printable transparent adhesive plastic sheets' for some protection against the elements. Hopefully it's completely sealed. Once I get the exact color match I'll switch them out.
    Please excuse the dirty car.
  8. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Finished sound dampening the passenger front door.
    To do both front doors, I used a little under 3 sq ft of Dynamat xtreme, mostly on the outer door skins and used 9.5 linear feet of Frost King and some foil tape to seal the inner door skins before putting the door panels back on. I have pics, but the site won't let me upload them at this time. I tap on the outside of the doors and it no longer sounds like a tinny drum and when closing the doors, it feels and sounds very much like my 2012 C250 coupe.
    The Frost King material is quite easy to work with, but you do need to clean it once you've applied to the door, or else the foil tape doesn't stick. The adhesive on the Frost King closed cell foam is much better than I had expected, the foil tape might be overkill.
    Some thoughts and a lesson learned yesterday... don't try removing the stock inner plastic barrier and its tacky black butyl adhesive when your car has been sitting in the sun. Also don't wear nitrile gloves when messing with that stuff because it just latches onto the gloves. I spent an hour just cleaning that gooey mess off the driver side door yesterday, before I could start with the real work.
    Today I kept the car in the garage and the butyl adhesive mostly stayed attached to the plastic as I pulled it from the door. Removing the plastic and cleaning up the inner door skin took only 15 minutes.
    Drilling out the rivets on the speakers was more trouble than I thought it would be.
    Accordlayingkit and WolfpackBill like this.
  9. Starbrand
    493
    1,503
    Westmont, IL
    finally tinted car. Ceramic: 18%R 32%S & 5%Sunstrip
    and yes... that first shot is my parking lot. so thanks to those on the other thread who helped me decide NOT to do my springs myself on that bumpy surface :p
  10. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Another peek-a-boo.
    I'm now done with suspension upgrades. Took it out for a quick spin earlier and with the combination of the rear sway bar, Ultra Brace and the Tanabe front brace the handling has been improved markedly. There's a right turn I can usually make at around 30mph (with plenty of body roll) without them and now close to 40mph with them. The car's chassis also felt stiffer so the ride is a lot calmer on the highway (can't really explain it but it also can be a placebo effect). Overall I'm very happy with the upgrades.
    #6630 WolfpackBill, Mar 25, 2015
  11. Xterra72
    1,432
    1,678
    Peek -a - boo to you too.(y)
  12. WolfpackBill
    349
    500
    Lexington, NC
    sfv41901 likes this.
  13. Xterra72
    1,432
    1,678
    Lol.:LOL:. I just wanted to say
    "peek-a-boo".:D
  14. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    I'll try this now with pickshures...
    Virgin door (yes, at this point I realized I had left the window down) :oops:
    Here's a pic of the factory dampening material. No wonder the doors sound like a kid's drum when you tap on the door
    Dynamat installed
    You can see a few of the pieces. The yellow boxes are roughly where I stuck Dynamat and the red boxes are roughly where the factory dampening material is attached.
    A close up just before starting with the Frost King
    Top half of Frost King installed loosely so that I could poke holes where screws etc., need to be and so that I can slip the bottom half under for about an inch of overlap
    Bottom half of Frost King installed, taped up and ready for door panel
  15. ncases
    ncases Senior Member
    609
    672
    Chicago
    Power Auto folding mirrors installed!
  16. Starbrand
    493
    1,503
    Westmont, IL
    great job @ncases ! They look nice and clean (y)
  17. ncases
    609
    672
    Chicago
    Nicely done my friend. we all get this prius mod fever. Don't know when to stop.
    Dylan Doxey and Starbrand like this.
  18. ncases
    609
    672
    Chicago
    Thanks.
  19. Starbrand
    493
    1,503
    Westmont, IL
    oh and my arm stoppers finally came! had to paint them green of course to match door strikers, horns, TRD badge, and emblems :LOL:
    then had to tape these down...I almost derped and pushed them. Still cold out so will let cure for a week to be safe.
    and interior shot of the tints. I like how much darker the ceramic turned out on the outside in my other post. and the front windshield I had to go 7 inches.. little over what you SHOULD do in my state, but had to cover the dots.
    Both hatch windows were tinted as well and matched pretty well.
    and another angle. still looks so dark at 32%! $180 for everything (la grange, IL). Might go back for $50 taillight tints.
    Accordlayingkit, Johnsk93 and ncases like this.
  20. Xterra72
    1,432
    1,678
    Here's what she looks like at night.:cool:
    20150325_201402.jpg 20150325_200857.jpg 20150325_200705.jpg 20150325_200626.jpg 20150325_200840.jpg 20150325_200918.jpg 2015-03-25 21.10.14.jpg
    Accordlayingkit, ncases and Johnsk93 like this.
