  1. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    How do u think I feel with a 6 yr old and 3 yr old running around the yard! I'm always going outside and moving my car and parking it down the street out of the kids way hahahah
    Dylan Doxey likes this.
  2. ncases
    ncases Senior Member
    609
    672
    Chicago
    I get separation anxiety everytime I hand off my car at the dealership for maintenance and when i get it back I do a complete body check. And it seems like I'm asking my prii, "Are you okay?"
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    " ... show me where they touched you."
  4. ncases
    609
    672
    Chicago
    Hahahahaha
    solrunner likes this.
  5. Xterra72
    Xterra72 Senior Member
    1,432
    1,678
    You and me alike.
  6. Xterra72
    1,432
    1,678
    You and me alike.
    ncases likes this.
  7. ncases
    609
    672
    Chicago
    Now that i have the auto folding mirrors I made sure they know about it otherwise they might unfold it manually. Damn! What happens i they did that I will be so pissed.
    slfare likes this.
  8. slfare
    slfare Member
    64
    135
    Portland, OR
    This! I just got my JDM power folding mirrors on and I cringe at the thought of someone attempting to manually fold the mirrors. I brought the Prius for scheduled maintenance service and they said it is not in their policy to manually fold the mirrors. Still, they were nice enough to print and put up a sign on the windshield to not fold the mirrors manually.
    Also, now that I have the Prius lowered on TRD lowering springs, I feel the need to tell them to be careful when going through bumps and slopes.
    ncases likes this.
  9. Xterra72
    1,432
    1,678
    You should grab a label maker and create one you can stick on your mirrors that states
    "Caution! Automatic Folding mirrors! Do not manually fold or face the consequences!"
    Hahaha! :D
    Accordlayingkit and ncases like this.
  10. Phx_Prius
    Phx_Prius Junior Member
    Phoenix
    Great and expensive thread!
    So far I've just done the cheap mods, led lights, Hids and the plastic Covers on the doors from China (which only took about a week to get, after seeing them here).
    I like the folding mirrors, so I may do that in the future.
    For now though, I am really interested in the DRL and headlights on the same time Mod! Could someone please point me in that direction?
    Is there a thread on it (couldn't find one) or is there a list w instructions?
    Thank you!
    Dylan Doxey and Burna J like this.
  11. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    was a pretty simple mod...
    take off sides and beige-matching vents
    fail horribly at CF wrapping and destroy the pics for any evidence of terrible modding. (think there was too much texture on the plastic to be adhesive.)
    when all else fails, just plasti-dip
    turned out okay... theres 4 coats, but will have to do another due to scratches from trying to put back on.
    but regardless... no more bright beige pillars being seen from outside!
  12. ncases
    609
    672
    Chicago
    Sure I guess you took Tylenol Extra strength while wrapping it with CF.
    Great job though.
    Starbrand likes this.
  13. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    Hi. Is it a pretty simple install? just backing up onto ramps to access? I think I'm going to want one.
  14. Xterra72
    1,432
    1,678
    fog light leds went out. Received new ones under warranty. What a pain to change out.
    Remove 4 screws then turn wheel in each direction to access each fog light.
    Remove and replace leds and then reinstall all screws.
    I guess it would have been easier if I had a lift. Oh well all done.:D
    Johnsk93 and Accordlayingkit like this.
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    ...then turbo?!
  16. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    Getting my dip on after work today ;)
  17. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Replaced the stock 2.5" squawkers with a pair of Pioneer TS-A878 3.5" 2-way speakers.
    Yeah, they sound much better and with the grills and A-pillars back on, it just looks stock. These $35 speakers seem to be a great bang for the buck.
    Fitting them required just a tiny bit of cutting on the dash.
    I wanted to reuse the factory connector which had a 6.8uf capacitor to function as a high-pass filter that filters out frequencies below about 6000Hz. I desoldered that capacitor and replaced it with a 100uf to filter frequencies below about 400Hz.
    On to the porn...
    Old v New comparison shots
    Test fit before cutting
    Stock grill. I cut that lip with a dremel roughtly where the sloppy yellow line is drawn, so that it's flush and won't hit the speaker.
    New capacitors to serve as 400Hz high-pass filters
    New caps and wires soldered onto the factory connector. Desoldering on those plastic connectors was a little tricky and I melted the blue plastic in a couple spots.
    Driver side mounted
    Pass side mounted
    #7077 scrappy, Apr 24, 2015
    Justdidit, sfv41901, fatdawg and 4 others like this.
  18. Stephen Ryan
    Stephen Ryan Junior Member
    Wake Forest, NC
    Yeah, super easy install. I backed into a set of Ramps, remove the rubber hanger from the muffler, remove the four bolts (two on the muffler and two on the tow hook), place hitch and tighten down the four bolts. I chose not to run the wiring harness since I won't actually tow anything that would need it but I could also go back later and add that if I choose. Good luck!
  19. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    Rebound, Caniac, orenji and 22 others like this.
  20. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    Okay. Cool. Thanks!! I had a trunk mount from a previous car, but I don't want to use that and not be able to use the hatch.
    Stephen Ryan likes this.
