  1. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    Cusco LHD front strut and Prius Plus rear sway bar... all green :ROFLMAO:
    and starting to use Torque app more often.
  2. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    Here she is all lit up......
    Forgot to close the garage. Excuse the mess.:D
  3. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Is that the white mini cooper for the kid in the garage?
  4. Xterra72
    1,432
    1,679
    Yo... that green is sure infectious. ..
    :D
    ncases likes this.
  5. Xterra72
    1,432
    1,679
    Yup my kid's mini...
    apt5020 likes this.
  6. apt5020
    881
    1,294
    Prius City, CA
    Nice. I have the blue one for the kid :)
    Xterra72 likes this.
  7. jamessicat408
    jamessicat408 Active Member
    110
    175
    San Jose, CA
    Tried installing a backup camera today and gave up. Everything was going smoothly until the boot part. Any tips guys?
    Rhinoruns likes this.
  8. xliderider
    xliderider Senior Member
    8,135
    3,273
    Honolulu, HI
    You would usually need to push a wire coat hanger or similar through first, then attach the wire you need to go through, then pull it carefully and slowly through. Hint, wrap the video plug so that it doesn't catch when pulling.
  9. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    I'm interested in the same thing. Curious to see how yours goes. Where did you get your camera?
  10. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Around 10 minutes in the video! Maybe easier from the roof towards the hatch direction.
    #7410 Sergiospl, May 24, 2015
    jamessicat408 likes this.
  11. jamessicat408
    110
    175
    San Jose, CA
    I got my camera from Amazon. It's called HDE E318
  12. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    Great video... But looks like too much work for install!! Lol!! I might need a couple of days!!
  13. Sergiospl
    3,938
    1,351
    28
  14. Boston Jim
    Boston Jim Active Member
    202
    148
    Other than what others have already provided above one thing to note, at least with my 2015 it may be different on your 2011, the bottom portion of the boot had a plastic 'lock' to hold it in place. Even with that bottom boot portion completely off it was still a pain to run wires (smaller than what your trying) through it. Good luck
    see @sfprankster 's photo - http://priuschat.com/attachments/img_5499-jpg.74203/
  15. apt5020
    881
    1,294
    Prius City, CA
    Just got my new fog light installed. Look real nice. The lens is really thick. I used 3000k bulb
  16. xliderider
    8,135
    3,273
    Honolulu, HI
    Hmm, LEDs with yellow plastic sleeve?
    That pic has got to be with the front end up on ramps or jackstands. There's no way the cutoff is up that high up the garage wall. :D
  17. apt5020
    881
    1,294
    Prius City, CA
    You can adjust it. It's flat to the ground on TRD spring. I bought those fog from Cheizy. Worth the price. You can do any color you like. Just H11 bulb. If you like them Cheizy should be getting more. Here is the link
    Projector Fog lights (BOLT ON) finally! | PriusChat
  18. xliderider
    8,135
    3,273
    Honolulu, HI
    I bought a set from Cheizy, though I put them on my Camry. I had already put a pair of projectors on the Prius, but they aren't high quality like the ones Cheizy is selling. They do have a wider angle lens though.
    So you mounted them angled upward, not level?
  19. apt5020
    881
    1,294
    Prius City, CA
    I flip it backward. Unscrew the two side screw and reverse it. Look better with a flat line going across.
  20. xliderider
    8,135
    3,273
    Honolulu, HI
    What does this mean? Does this mean you turned the mounts around and mounted the left in the right and right in the left side backwards?
