  1. Boston Jim
    Boston Jim Active Member
    202
    148
    Mod for the day - I (with my wifes help) finally opened my drivers door !!! Two offset screw drivers and a lot of pulling and finally Success !
    And the offending CCF that caused all this grief- reminds me of Han Solo in the carbonite
    So true and Thanks!
    I saw a previous post of yours where you used some Thermolite for the back doors, can I ask where you got it from and was it worth putting it in?
    Burna J, sfv41901, scrappy and 3 others like this.
  2. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Dang u owe the wife the night of her life! Haha
    sfv41901 and Boston Jim like this.
  3. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Glad you didn't need to take it to the dealer get the door open.
    Thermolite is $$$, so I used a heavyweight polyester batting material on the door panels during my first attempt at soundproofing when I was trying Frost King on the doors instead of MLV/CCF. It falls into the "it can't hurt" category, but I wouldn't bother with it unless you think you can hear some higher frequency sounds sneaking through the MLV/CCF layer.
    By the way, one tip for working with MLV -- for the final fit, it helps to lay the MLV/CCF piece out in the sun for a few minutes so it gets hot and flexible and will better form-fit to the lumps, bumps and holes in the doors and door panels (or the curves when you're doing the floor). I did mine during winter and used a heat gun to warm up the MLV when the sun wasn't out.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Glad u got that door open.......would've been $$$ at the dealer........~$150 just to look at it
    Semy VS9G using Tatalk
    Boston Jim likes this.
  5. DP200248721
    DP200248721 Active Member
    155
    415
    Suisun City, CA
    @sfv41901 finally got my Gs headlights in, thanks for all your answers to my questions
  6. Accordlayingkit
    1,616
    1,747
    377
    Looks great!
    sfv41901 likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Sweet. Loks awesome.
    Did u align the headlights?
    nt frm m80 4G usng apa
  8. Boston Jim
    202
    148
    I will say I was pretty happy this morning :). The dealer wanted $135 just to get it in the door, then I looked up the price of a new panel which was about $275 (online) if they destroyed it trying to get it open. Could have been a really bad day. Soooo lucky, and I will definitely never do that mistake again :)
    Thanks again
    Burna J, Dylan Doxey and sfv41901 like this.
  9. Boston Jim
    202
    148
    Thanks, I was pretty happy myself that I didn't have to take it to the dealer :). Thanks for the info, I'll just stick with the MLV/CCF for now.
    The MLV sitting in the sun get pretty hot (learned that lession myself :) and I will defiantly be using your tip for the back doors with fitting it around the foam. For the front doors I sealed the openings with aluminum flashing, and shaved the foam down to fit. I wont be sealing the back doors though. It took me way to long to do the front doors, although the drivers door was going well until my little mistake yesterday, but there finally done!
    sfv41901 and scrappy like this.
  10. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    Changed spark plugs on my prius. Bought autolite from napa for $17 for 4 plugs whereas toyota dealer was quoting $16 for a single piece. still have the engine vibration so next will clean the manifold.
    Burna J and Accordlayingkit like this.
  11. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    image.jpg Just got my interior LED kit from iJDMtoy. Question about the map lights... Why put padded foam adhesive on the backside if there's nothing for it to stick to? I test fitted one (that's why it's missing from the photo) and the plug is preventing me from pushing the piece any further. I pretty much just have the light hanging by the cord and resting on the light diffuser. Are your lights like this too?
    *Edit: Got them installed. Wow they are bright!
    #7891 HelloHybrid, Jun 18, 2015
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I was able to make the double sided foam make contact however there wasn't enough surface contact for it to stay......it eventually came loose. I just got more foam to stick in behind the board so it wouldn't rattle
    Seom my VS9 usng Tapalk
    HelloHybrid likes this.
  13. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    The iJDMToy interior LEDs are the only way to go.
    The cheap LED kits aren't worth the trouble, in my opinion.
    #7893 Dylan Doxey, Jun 19, 2015
  14. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    Let's just say, I had a little time at work.... :)
  15. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    engine bay :p?
  16. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    Lol... That was too easy. (y)
  17. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Lol you should make me one too :p haha :D
    sfv41901 and Burna J like this.
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I 2nd that motion
    Sen frm myVS80 4G singTapalk
    #7898 sfv41901, Jun 19, 2015
    Burna J likes this.
  19. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    $17 for 4?? the Prius factory installed iridium tip spark plugs, I bought mine from Amazon
    like $9 each.
    Since changing the plugs isn't easy on the Prius...I'd rather get a good branded plugs to installed. There's not fun taking off the wiper assembly and under tray etc. How many miles on the old plugs?
  20. orenji
    orenji Senior Member
    5,887
    3,488
    All in favor, say Yea!
