  1. Steve Robinson
    Steve Robinson Junior Member
    36
    44
    Mississauga, ON, Canada
    That's a Stage 10 electronic shifter. Here. Expensive but too cool.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I got the LED fogs in but need to replace the relay.....it got damaged :cry:
    F8L, Tracksyde, wotcher and 2 others like this.
  3. Ragin Cajun
    Ragin Cajun Junior Member
    52
    16
    I ordered my Stage 10 Carbon switch. Should be here by weeks end.
    ockevin likes this.
  4. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    Looks awesome man. Bummer about the relay. Hope you get it fixed soon.
  5. jmrmotorhead
    jmrmotorhead Junior Member
    85
    44
    New Hampshire
    Looks sweet, but somthing's missing...wheres the Toyota emblem? ;)
  6. jmrmotorhead
    85
    44
    New Hampshire
    Got my rear illuminated emblem installed. The pictures don't show it so well, but I can tell its lit up today, its foggy out. I'll get some night photos later!
    sfv41901, Steve Robinson and mnml like this.
  7. Ragin Cajun
    52
    16
    I installed my H11 Philips headlights. Ive had these in every car I own except for my Vette. They are very good and last very long.
    mnml likes this.
  8. Steve Robinson
    36
    44
    That is very, very nice. You used EL wire? Where did you put the converter?
  9. jmrmotorhead
    85
    44
    New Hampshire
    Thanks! Sure did, makes it super even around the emblem, no hot spots from LED's. I placed the converter for the front emblem right behind it. For the rear I routed the wires through one of the license plate light housings, with the converter inside the hatch. The converters are really small, maybe an inch by a half inch box.
    Here are some dark pics! Don't mind the light out...I plugged in the harness backwards, its fixed now.
    Oh and in case your interested, I'm working with Danny to try and set up a group buy for these. I can do them for 45-50$ for both emblems, not trying to make any money. I can let you know where that ends up if you want!
    Matt
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I let a GM sales guy run the VIN to see what he would give me towards a 2013 Volt. Yup, I almost pulled the trigger. So close to trading due to the annoying rattles and wind noise.
    Tomorrow I'll work on rattle control. :)
    Econ likes this.
  11. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Who would've thought our own F8L is a traitor? :cautious: :sneaky:
    RxGATOR, sfv41901 and F8L like this.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Persistent annoying noises can make a man do crazy things.
    32kcolors likes this.
  13. wotcher
    wotcher Member
    403
    97
    16
    LA
    i think he wants to try new tires and tires sizes on the volt.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Don't think it didn't cross my mind...... ;)
    If I can't fix these rattle I may give you your money back and keep my Energy Saver A/S 15s! Ha!
  15. watchingthetides
    watchingthetides Junior Member
    33
    46
    Has it always made noises or did it just occur overtime? Just curious so I might know what to expect in the future
  16. wotcher
    wotcher Member
    403
    97
    16
    LA
    no no no. volt needs bigger tires!
    F8L likes this.
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It has gotten worse over the last few thousand miles. I think a lot of it is due to lower temps (40F-60F) but even when I first purchased it in March, temps were similar and it had zero rattles. I keep lowering my tire pressure knowing that the low profile tires are not helping. At 36-34psi it still rattles.
    I've tried putting felt furniture tabs in the usual places and it seemed to help a little but they are still audible. The dash rattle/noises are the ones that worry me most. I'm at 30,000 miles.
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Y
    Yep.......there on their way to u
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I added a bunch of round felt furniture pads at various points on the car and I temporarily removed the "strut" that attaches to the lower glove box. I am happy to report that the rattles were very much reduced and only noticeable when hitting large bumps. Because the roads were wet and I was traveling at 65070mph the road noise may have masked the more quiet rattles but overall the ride was much more pleasant than it has been. Now I just have to come up with a better looking method to reduce the rattles. Black vs. green felt pads would be a good start!
    MarkPressey likes this.
  20. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    I had a problem with a dash rattle when new. Like you, when it was cooler in the 50s and 60s it would rattle. When it warmed up into the 70s it wouldn't. I took it to the dealer 3X and the first 2X they put foam tape all around the dash and that didn't fix it. Then they just ended up replacing the whole dash cover and putting foam tape and that seems to work.
