  1. Chwaz
    Chwaz Blizzard Brigade #189
    50
    Dallas Tx
    Well it's a aftermarket part that is being connected to the OEM connector. I know it's all Plug and Play, but some dealers just want to screw you how ever they can.
  2. Ragin Cajun
    Ragin Cajun Junior Member
    52
    16
    There are other things that plug into OEM connectors also like aftermarket radios, HID headlights and LED interior bulbs. I would hope that a dealer would put the shift in the same category.
  3. Chwaz
    50
    Dallas Tx
    Maybe, but hey keep up updated when you take it in for your next service if you would.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The only way that the shifted can void ur warranty was if it was the cause of a problem & they would have to prove it, not just say it.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Didn't know ur Prius could go that fast. LMAO :D
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I get a power boost from the rats living in my engine bay!
  7. zeoth
    zeoth Junior Member
    43
    Got the rear 6 windows tinted 20%. Kind of wished I did 70% for the driver and passenger windows.
    Mods to date:
    Rear 6 windows 20% tint
    Stage 10 carbon fiber with blue light
    WeatherTech floor and trunk mats
    Chrome side moulding
    3M Clear bra
    HeatShield sun shade
    FIAMM horn
    Still debating if I should retrofit HID's into the Prius. I love them on the other cars but the headlights on the Prius isn't too bad.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Retro fit FTW
  9. maoira
    maoira Junior Member
    79
    St Paul, MN (formally from San Diego, CA)
    Drove through 3-6 inches of snow and slush on OEM tires... scary.
  10. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Mounted my Garmin GPS in a convenient location. The power cord is nicely hidden except for what you see in the pictures.
  11. dimetech
    dimetech Junior Member
    31
    Los Angeles
    Which nuvi is that and how do you like it? (Obviously more that the oem nav ;)
  12. CaliforniaBear
    1,179
    289
    Northern California
    Its the 1450. I'm not sure they still sell that model. No traffic because I don't commute. I like the 5 inch size. The main feature I was looking for is to set up routes with multiple way points because the shortest or fastest are not necessarily the way I want to go on long trips.
    The problem with the Nav in the Prius Three is that the screen is low resolution and hard to read. Often I use the GPS to see what roads are ahead when I not on a programmed route. I can't read the upcoming street names on the Prius Nav. Another feature of the Garmin is it tells you the correct speed limit on many roads and all highways. Very convenient if you missed the last speed change sign or just need a reminder.
  13. Ragin Cajun
    52
    16
    I just bought the 50LM from Amazon for $99. Great GPS and I also put mine in the same place on the drivers side small window.
  14. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Swapped in some LED tail lights for the burnt out stock one. Couldn't tell the diff from the non-LED bulb.
  15. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    installed my Itronics ITB-100HD dash cam today, pics and DIY write to come tomorrow :)
  16. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Look forward to the wiring pics, I have a dual dash cam to install myself, and not sure about how to run the wire (was way easier in my RAV4).
  17. Jill E
    Jill E Member
    60
    40
    San Diego
    I got my roof wrapped in glossy black, turned my fog covers covered in yellow, and lightly tinted my tails
    mnml likes this.
  18. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    Do you have any pics? Thinking of wrapping my roof too.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Got my red 3rd brake light today from Panson & replaced the relay that came with the Yaris fog lights to a more common Bosch relay. The 1 that came with the harness is readily available.......so now my LED fogs are working ;)
    Pics coming in the am.
  20. Adam Leibovitch
    498
    102
    Focal access components and rear coax speakers. 10" jl w3 and jl hd700 amp. :D
    SGH-T999 ? 2
