  1. Silvertn350
    Silvertn350 Junior Member
    64
    51
    Tennessee
    Ordered one recently as well, good choice .
  2. Mendel Leisk
    41,153
    Doesn't anyone like to have hot used motor oil trickling down to their elbow?? (n)
    fopoku2k2 likes this.
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Installed my Hella Horns today.
    TopRamen, sfv41901, Xterra72 and 9 others like this.
  4. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    What is that behind the right side (left in the photo) horn?
  5. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    VPNS speaker?
    sfv41901 and Dylan Doxey like this.
  6. Dylan Doxey
    1,389
    3,459
    92
  7. LDB
    LDB Member
    279
    71
    Interesting. I've never heard that. I'm not sure mine has it.
  8. Dylan Doxey
    1,389
    3,459
    92
    They're present in all 2012 or newer Prii. The mounting location varies.
    bonchang and sfv41901 like this.
  9. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I disconnected my. Stealth mode :)
  10. Dylan Doxey
    1,389
    3,459
    92
    I thought about doing that ... but it is required by law. Well, at least the regulation requires Toyota to install it.
    I was thinking about getting a stack of them and running 12 in parallel. I'd like to see what that sounds like. :)
    HelloHybrid and bonchang like this.
  11. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Not a good idea! Very dangerous!
    bonchang and Dylan Doxey like this.
  12. ncases
    ncases Senior Member
    609
    672
    Chicago
    I've been on a stealth mode and many times I almost got run over a pedestrian. I knew that they can't hear me so always take extra caution. I'm reversing it now to unstealth mode before I get hit and ride by the next owner. ;)
    bonchang and apt5020 like this.
  13. Dylan Doxey
    1,389
    3,459
    92
    In a worst case scenario, that involves your car striking a pedestrian, it could be very bad for you if an investigation reveals that your VPNS had been disabled.
    bonchang likes this.
  14. chkcee
    chkcee Junior Member
    Los Angeles
    Moved my Gen 3 to the side and stretched my 1972 Mercedes 250C out a bit
    Tracksyde, TopRamen, ncases and 3 others like this.
  15. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
  16. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Is yours installed? Do you leave it installed to your car or remove after use?
    XT1060 ?
  17. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    whelp... after a 4 month modding break, @ncases de-modding sale has made me go at it again :ROFLMAO: removed my stocks:
    then swapped with @ncases for his 3-in-1 light w/autofolding mirrors. yes, i know its blizzard pearl... need to fix that.
    he DID have some difficulty wiring, but still worked. Neil said the wire coloring is different from his 2012 from my 2015. Particular to the puddle wires.
    then here's his with my WGM mirrors.. :D
    [​IMG][​IMG]
    We couldn't figure out @SwamppThingg fogs, but might try again in 2 weeks. tried comparing with @ncases wiring setup. issue was @ncases had 1 ground and no need to run to battery. But @SwamppThingg kit had an extra ground and wanted to connect all the way to the battery and extra wires to go to the fuse i think. not sure.
    ncases slowly turning his car back to stock. my steering wheel swapped with his.
    aaannnd another weird look at my new mirrors. @SwamppThingg says to keep it white.. I personally cant take it and need to change it to CF or something... LOL
    hard to believe this car isnt even 1 year old yet...
    ePrius, Xterra72, bonchang and 6 others like this.
  18. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    Nah, that's the look.
    I was semikidding but it's really growing on me.
    And I gave you an "or something" option too.
    Stickerbomb it up. I'll order you a Miku for your tow hook.
    bonchang, ncases and Starbrand like this.
  19. Dylan Doxey
    1,389
    3,459
    92
    Finished up my Hella DRL install this morning.
    Screenshot from 2015-11-01 09:26:07.png
    Here's a before snapshot:
    Screenshot from 2015-11-01 09:41:50.png
    orenji, Tracksyde, Xterra72 and 6 others like this.
  20. bluhawk
    bluhawk Junior Member
    25
    Torrance, CA
    Last week i installed DDM hid 55W 6000K. Today i yellowed out my high beams using krylon paint.
