  1. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Picture of LED
    Johnsk93, Snow, HelloHybrid and 7 others like this.
  2. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Awesome! How's the ride with 2 sway bars?
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'll tell u 2morrow. Haven't taken her out yet
    iPhone ?
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Glad I was helpful. You must have spent more than $17 as I wasn't able to cover mine to that extend. Wait, $17 must have went all to the trunk area. My 2 rolls went to 4 doors and trunk. Overall I'm very happy with mine but still out gasing a little.
    iPhone ?
  5. Sfcyclist
    1,621
    376
    SF, CA
    Just finished basic upgrade of audio system. Kept original non jbl navi head unit, added amp, and speakers. Overall very happy with it. Sounds better than my Lexus now. I did his when I was sound dampening my doors. I'm sure both helped reduce hearing road noise. Wow! What a difference now!
    iPhone ?
  6. Drewintoledo
    Drewintoledo Junior Member
    49
    Ohio
    2015 Prius v wagon
    Where did you mount your amplifier? Did you also add a subwoofer?
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The ride with both sway bars was fantastic. A lot firmer in the turns
    iPhone ?
    bonchang, orenji, HelloHybrid and 3 others like this.
  8. Sfcyclist
    1,621
    376
    SF, CA
  9. Dalamar
    Dalamar Junior Member
    2013 Prius v wagon
    Today was the adding of the sticker, painting calipers, and painting knock out seal center caps, bought a 2015 left over last Friday
    Snow, saulbassfan, Burna J and 6 others like this.
  10. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    I ordered some 17x7 wheels with a +45mm offset.
    That should be fine right?
    I did a fair amount of lurking around about it and that seems to be a fine choice.
    Accordlayingkit likes this.
  11. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    Yes you'll be fine. Stock 17" Plus/Persona wheels are 17x7 with 50 offset.
  12. eunique
    eunique Member
    66
    89
    US
    I successfully changed coolant in my ICE/radiator...Drained an much as I could with temp on HI opening the heater core. Then I used Airlift UVIEW to vacuum fill the coolant using AISIN pink SLLC from autohausaz.com
    I had 118,900 mi on odometer
    I will do inverter coolant next (I didnt have proper 10mm hex on hand to drain)
    A0001 ?
    sfv41901 and granTORRESmo like this.
  13. granTORRESmo
    237
    648
    Norcal
    Road trip to Pacific Grove CA. 400 miles total. Coilovers are stiffer than Tein Htech, but still comfortable my passenger fell asleep. image.jpg
  14. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Today I added more chrome. Mwahaha
    Did passenger side window trim this is evening. I'll snap a photo tomorrow. :)
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Aren't the the vacuum fillers great? Good investment
    iPhone ?
  16. eunique
    eunique Member
    66
    89
    US
    They are great...I was hesitant to use it at first since I had never used it before. It was harder to take the clips out to remove the undertray. The best part is that I found a used one on eBay.
    OnePlus One?
  17. PentaTetraContaMiler
    Philadelphia
    Hi all! :) I bought my 2010 CPO Prius III no-nav a month ago. Since then I've removed my wheel covers and added Toyota branded chrome center hub caps, removed the front license plate holder and for now used small panel plugs to fill in the screw holes, added a clear license plate shield to the back (I might need to remove the shield, not sure if it's allowed on the road), added AVS Smoke seamless ventvisors, installed interior LED bulbs, added AGPtek Handsfree USB Car Charger Bluetooth for music streaming, an iOttie phone mount, and OEM all weather floor mats.
    Also have the Carmate cupholder tray on its way and plan on getting the OEM all-weather cargo mat and cargo organizer this week. Once I get a bit more educated on the matter, I'll also be upgrading the rest of the lighting to LED and probably adding fog lights. After that, once the weather gets nicer I'll be touching up some of the visual blemishes on the paint and start toying around with plasti-dipping some things :)
    PriiPrii, eunique, Johnsk93 and 4 others like this.
  18. saulbassfan
    979
    3,108
    Southern California
    image.jpeg I'm a sucker for chrome, at least for this build. All in good taste of course.
  19. apt5020
    881
    1,294
    Prius City, CA
    I like it. At least you didn't go all out chrome wheels.
  20. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    Pictures
    PentaTetraContaMiler likes this.
