  1. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    looks great, ridder
  2. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    hey, do you have the link for the hood dampers ?
    are they carbon fiber ones ?
    Also, was the install easy ?
    thanks
  3. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Did the Footwell Courtesy Lamps in my Prius II...Thanks to Sean for the P/N's.
    F8L, sfv41901 and ucsmfu like this.
  4. Ridder
    Ridder Member
    141
    51
    Netherlands
    I bought these:
    2009 2010 2011 2012 Toyota Prius XW30 Black Color Shock Lift Hood Damper D2N5 | eBay
    I bought a black set, but they are also available in silver and carbon.
    Installation was very, very easy......it took more time to open the package than to install.
    BTW: I installed them with the heavy part to the chassis.....that makes sense to me.....
    The seller has pics with the damper bolted to the hood.....don't know why.
    zhutton (on this forum and in this thread) has the same dampers and also installed them like the seller.
    I can't find a reason why to do it like that.....only the other way around.
  5. ucsmfu
    1,498
    420
    canada
    does it have the red imprint letters on the dampers that says sokie tech ??
  6. The Critic
    The Critic Resident Critic
    3,193
    2,328
    CA
    F8L's 2012 Prius received new Mobil 1 0w20 and a Toyota oil filter, as well as a transaxle drain/fill with Toyota ATF-WS.
    F8L likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I had the same 1's but had to remove them when I installed my Tanabe STB but now that I'm going to install a Cusco STB they will be going back on.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    How many miles on it now F8L? Was thinking of having the dealer do it during my last Toyota Care oil change.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I am at about 34,600 or so. I think Mike stored the info on his laptop last night so he'll probably correct me.
    From what I saw last night and what the knowledgeable folks on here are saying I would probably have it done during your next visit. It's cheap insurance at approx. $100 IMO.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I will change it. There's no question about that. I'm just not sure what my service rep will charge me. If its too $$$ I'll just do it myself
  11. Ridder
    Ridder Member
    141
    51
    Netherlands
    They're plain black. (the hood dampers)
    My DRL's when they are off: you can barely see them.....and that's whst I want.
    mnml and sfv41901 like this.
  12. Burna J
    1,067
    3,337
    53
    Long Beach, CA.
    I heard the reason to have them mounted, like they show in there picture. Was to help lubricate the o-ring, with the oil in the main cylinder. If you let the o-ring dry up, it will crack and leak. Don't know if that's true, but I figured I go with it.
  13. The Critic
    3,193
    2,328
    CA
    It will probably be around $150 for them to do it.
    ATF-WS is around $9/qt (discounted) and the two washers are about $2/ea.
    sfv41901 likes this.
  14. khurra
    khurra New Member
    washed and waxed my girlfriend's 2012 Prius 2 and my (pictured) 2012 Prius C 2.
    Loving the mpgs!!
    #firstpost
    #firstprius
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Welcome to the forum & congrats on ur new Prius.
    Since I see u got ur Prius in Santa Monica, u should check out the local meet we have planned. U can find out more info by clicking on the link in my signature.
  16. zhutton
    zhutton Junior Member
    85
    Staffordshire, UK
    Ridder, have you installed the gas struts the wrong way? I've got mine with the black at the top as per the pictures on their guides/advertising
    Zakk
  17. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Longo Toyota gave me too much trouble for wanting it changed at 35k miles and wanted like $250 if I insisted on it, so I said forget it and walked over to their parts department and purchased 4 quarts of ATF-WS. I had an independent shop do the change. It's a 0.38 hour job ($37.50 in labor charge).
    sfv41901 and F8L like this.
  18. Ridder
    Ridder Member
    141
    51
    Netherlands
    Yes, I did it the other way.....
    I've never seen struts mounted upside down like our chinese friend did.
    Maybe there's a reason (like Burna J wrote) but I never had problems with struts leaking on previous cars.....or lids of containers or whatever.
    I figured that you want the least amount of weight on the hood-side (or bonnet-side ;) ) like with your suspension....that's why you want lightweight wheels and wishbones etc.
    Nice theory of course.....but for a hood damper it doesn't really matter....I think.
    But there was a little thinking involved in my way of mounting.
    Burna J: the dampers are horizontal 99.9999% of the time with lube everywhere: on the gland/the seal.
  19. Ridder
    Ridder Member
    141
    51
    Netherlands
    I bought and installed a Thule roofrack and a Thule Motion 800 Limited Edition Glossy White.
    Too bad I don't like cold, snow and skiing.
    mnml likes this.
  20. mnml
    377
    161
    Ladera Ranch, CA
    I like the color match. ;) BTW, what size wheels are you running?
