  1. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I don't think it's random chance that ToyotaFest goes down right after tax season. ;)
    Jon Senum and sfv41901 like this.
  2. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    Hopefully these will fit without too much hassle.
    Has anyone used a similar 20mm spacer? will they fit without changing the stock studs?
    HelloHybrid and sfv41901 like this.
  3. xliderider
    xliderider Senior Member
    8,136
    3,273
    Honolulu, HI
    Your stock studs might protrude past the spacers. If your wheels don't have spaces behind the wheel that accommodate the protruding studs, then you'll have to mount shorter studs, which is what sfv41901 did.
  4. Dylan Doxey
    1,389
    3,459
    92
    For my 15mm spacers I didn't need to trim the studs because my wheels could accommodate the protrusion. But I did need to trim the studs on my spacers by 6mm.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Pretty much what @xliderider said.
    U got lucky @Dylan Doxey (y)
    Dylan Doxey likes this.
  6. SwamppThingg
    235
    443
    Mount Prospect, IL
    Was it a huge feat to swap out?
    Seems like it would be.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Just cut the OEM studs down. Either way u go, If u ever remove the spacer u will need to put in OEM length studs again.
    SwamppThingg, apt5020 and Dylan Doxey like this.
  8. StarCaller
    StarCaller Senior Member
    1,275
    726
    Cedar Crest, NM, USA
    true that/
    but putting on or changing little things can be fun, too/
    Accordlayingkit and Dylan Doxey like this.
  9. SwamppThingg
    235
    443
    Mount Prospect, IL
    for sure.
    slowly plugging away at it over the last year and some change.
  10. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    Hello Priuschat Modders:)
    Tree is in the picture to block the license plate.:D Spring is here!!!yeeaaaah!!
  11. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Hey... But all your neighbors can see your license plate! Lol
    Xterra72 likes this.
  12. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Installed some birthday gifts from a couple of weeks ago. My wife treated me right!
    Cover for my manuals (I can't believe the car didn't come with one):
    Door hinge slider covers:
    Hood struts and partial engine covers. Still trying to figure out how to make the inverter cover fit in the front (trim or place under the radiator cover):
    #10852 mrstop, Mar 20, 2016
    aportades, Tracksyde, scrappy and 7 others like this.
  13. SwamppThingg
    235
    443
    Mount Prospect, IL
  14. Dylan Doxey
    1,389
    3,459
    92
    In my case I placed the inverter cover under the radiator cover. To make it fit, I gently shaved the radiator cover with a sanding drum in my Dremel tool.
    BEFORE:
    AFTER:
    Here's a snapshot of how it appears in the Lexus CT200h engine bay.
    P.S. Your wife sounds like a keeper!
    #10854 Dylan Doxey, Mar 20, 2016
    sonnyd510, PriiPrii, m3pare and 9 others like this.
  15. Xterra72
    1,432
    1,679
    Right! Just to lazy to mod pic:D
  16. freedom1725
    freedom1725 Member
    74
    146
    Palo Alto, CA
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg Hello Prius chat
    Having a little coffee break with my Prii in the middle of work. Haven't update any pictures for a long period.
    Just wondering, for solar roof package, which shark fin should I get? I heard some shark fin maybe too large for us.
  17. Dylan Doxey
    1,389
    3,459
    92
    sonnyd510, Tracksyde, orenji and 7 others like this.
  18. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    Happy Early EASTER!
    Not sure how its gonna look, could be too much. But I just really liked the way the mockup looked in the quote above. So I figured I get rid of the Starbrand Green and try something new... more pics to come once the majority of the green is gone.
    Johnsk93 and SwamppThingg like this.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I've been busy all weekend working on my custom sub enclosure & routing all of the air lines
    2 sets on flush mount rings
    Idea of how the flush mount ring looks
    Routing the air lines & sensor wires
    Down the driver side following the same path as the fuel & brake lines
    Down the passenger side following the same path as the HV power lines
    Lines routed under sub enclosure (y)
    Wanted to run 2 12's but it just wasn't going to happen :confused:
    To be continued :barefoot:
    Ramtart, aportades, sonnyd510 and 8 others like this.
  20. Justin C
    Justin C Junior Member
    I paired the Lexus smart card key to my Prius! Info here.
    fopoku2k2, TopRamen, m3pare and 6 others like this.
