  1. webpong
    webpong Junior Member
    Thanks for this, but I just want to replace it, because I don't have the knowledge in wiring it. I want it very simple plug n play. I'm afraid to mess the electronic
    SM-G900P ?
  2. ChapmanF
    18,180
    Well, I've had it about 3 weeks, so this wasn't all today, and it's not all exciting, but ...
    • No more reverse beep (now that's exciting)
    • No more looooong door-isn't-closed-beep
    • No more lock motors going kachunk on every shift to or from Park
    • Brakes and tires inspected, TPMS set to new pressures
    • First change of oil (coming from a Gen 1 where you leave the car on the ground and just reach under the front bumper, oh man, what were these people thinking?)
    • Alignment adjusted, then alignment-shop greasy handprints removed from headliner and A pillar trim :mad:
    • In-cabin AC power setup removed from Gen 1 recreated in Gen 3-ish way....
    ... using Gen 3 recreation of Gen 1 trunk aux-power distribution thingy.
    -Chap
    donbright, ErikJ, sfv41901 and 3 others like this.
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    My reverse lights are still incandescants.
    There, I said it.
    So, tonight I thought I'd try putting in some LEDs.
    Can you guess which of the above is an LED?
    I had a set of these Opt7 LED H11 bulbs laying around.
    How do you make an H11 peg fit into T20/7440 hole?
    With a Dremel tool. ;)
  4. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    The day has finally arrived and I will say no more :censored: :love::love::love: image.jpeg
  5. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Replacing bumper?
  6. DP200248721
    DP200248721 Active Member
    155
    415
    Suisun City, CA
    Perhaps a suspension upgrade?
    granTORRESmo likes this.
  7. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    Live from @Dylan Doxey's pad... LED mod going down :) #filipinocombo
  8. Gaspeed
    Gaspeed Senior Member
    286
    1,624
    San Diego CA
  9. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Post pictures tonight. Want to see your color combo. :)
  10. m3pare
    679
    1,818
    SoCal (626)
    Thanks pare! More stuff getting installed Tuesday. :)
    Will do! It's similar to @Gaspeed's setup.
  11. Krish Udvadia
    Krish Udvadia Junior Member
    Westlake Village
    Has anyone done spherical bushings or know anyone that makes them?
  12. MPGRaja
    469
    1,680
    Corona
  13. DP200248721
    155
    415
    Suisun City, CA
    Idk what it is about doing suspension work on these cars but I actually like having to remove all the panels and what not as it takes finesse to put everything back to look like it was never removed.. Especially the bumpers to remove the exterior lights was a fun challenge
    adawg and granTORRESmo like this.
  14. Friend of Bill W.
    109
    164
    Elkhart, IN
    So to install springs you don't just drop the strut and switch out the spring like most cars?
  15. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Fixed my saggy rear bumper lip and replaced weather stripping this morning.
    @Dylan Doxey my LED's didn't even arrive yesterday.
  16. m3pare
    679
    1,818
    SoCal (626)
    Installed Cusco STB and Injen intake while @Dylan Doxey worked his magic...
    LED teaser... Can't wait 'til it gets dark!!
  17. DP200248721
    155
    415
    Suisun City, CA
    Sir, if you have a 2012+ your in luck for the rear as they have access covers to the strut bolts (if your replacing lowered struts along with the springs) rear springs alone are a walk in the park, front end no matter what year you have to remove the wipers, wiper motors, upper wiper cowl, and lower wiper cowl... Fun times
  18. Dylan Doxey
    1,389
    3,459
    92
    After working with @m3pare on his LED retrofit, I finished up on this reverse LED install.
    There it is, mounted in its new home, with its ballast stashed in the corner and 3M taped to the body.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I can see this mod coming in useful if u could trigger the reverse lights while driving to shine some light on the A**holes who like driving with their high beams on :mad:
    iPhone ?
    RollinBad, saulbassfan, Jk818 and 3 others like this.
  20. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    ...and lifted trucks running HIDs in their reflector headlights and foglights.
