  1. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Had a show yesterday image (3).jpeg image.jpeg and represented with Kyoei USA / Air Runner / Vankulture
  2. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    I'm in too
    Dylan Doxey and Johnsk93 like this.
  3. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
    I'm in as well! Would love to have another get-together :)
  4. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    Set it up so some SoCal guys can come up too (y)
    Lookin' good pare!! I have your brackets btw.
  5. DP200248721
    DP200248721 Active Member
    155
    415
    Suisun City, CA
    Sounds good gentleman I'll try putting something together and make a post once I have a good idea... Nevertheless I went to start my car after being gone 2 weeks... Dead... Person watching the house apparently turned the car on and didn't completely turn it off so I'm assuming it sat in ACC until it depleted the battery. $171 new battery cause I'm not risking it dying down the road cause the battery was completely drained
    HelloHybrid, Lit Lit and granTORRESmo like this.
  6. InspectorGadget
    InspectorGadget Active Member
    216
    450
    Heber City, Utah
    Rear bumper brackets???
    Please continue my education; why does the Prius need rear bumper brackets.
    If this is not about rear bumper brackets, please disregard.
  7. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Damn you, TRD rear sway bar. The ungodly amount of force I created between my thumb and forefinger to shut the bushing clamps together far enough to shove the bolt through is absurd. Not sure how some of you installed it in 30 minutes without lifting the car up and removing the shock absorber. I was able to tighten everything except the end link nuts attached to the shocks. Don't have a wrench small enough to fit in the small space.
    Edit: Great...I realized I only put washers on one side of each bushing clamp bolt. I'd rather do it correctly, so I guess I'm gonna have to endure this mess again. Everything is tightened down enough it should be good till next weekend. I even forgot to remove the bungee cord I used to hold the bar up :rolleyes:
    #12567 HelloHybrid, Jul 17, 2016
    Jk818, Xterra72, granTORRESmo and 3 others like this.
  8. orenji
    orenji Senior Member
    5,887
    3,488
    I order Black Legacy plates for the new Gen III, should feel right at home with the black paint! Now just gotta wait 8 to 12 weeks. :D
    Xterra72, sfv41901, m3pare and 3 others like this.
  9. MPGRaja
    MPGRaja Senior Member
    469
    1,679
    Corona
  10. xliderider
    xliderider Senior Member
    8,104
    3,251
    Honolulu, HI
    Here's a long thread on the problem:
    Prius Rear Bumper Cover loose and gap? | PriusChat
  11. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
  12. HelloHybrid
    482
    1,483
    Test footage off my new dash cam. Seems like I have a smudge on the lens, but the picture quality already looks a lot better than the Mini 0806.
    #12572 HelloHybrid, Jul 18, 2016
    Ramtart, Xterra72, Lit Lit and 3 others like this.
  13. Dylan Doxey
    1,389
    3,459
    92
    And that Jeep accelerated to get in front of you for ... ?
    FinToy and HelloHybrid like this.
  14. HelloHybrid
    482
    1,483
    The resolution of this camera is so good, you can see the a$$hole in the Jeep with CA license plate 7NJA109 quickly show his face for a split second before he decides to cut me off in the middle of an intersection, just so he could downshift for no reason, then later cut off the car he was just in front of if he just stayed in his lane to begin with :ROFLMAO:
    Xterra72, Tracksyde, sfv41901 and 6 others like this.
  15. Dylan Doxey
    1,389
    3,459
    92
    Nice Dashcam. I'm glad no Prii were harmed in the making of this video. :cool:
    priusrick, Ramtart and HelloHybrid like this.
  16. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    HelloHybrid, which model of dash cam did you decide to go with?
  17. HelloHybrid
    482
    1,483
    Got this one off Amazon.
    So far so good. The night quality isn't as great (I'll try to post a video later today) versus the day. There's no screen on it, so you need a smartphone with the app to change any settings via WiFi.
    The WiFi transfer rate to view videos through the mobile app is also extremely slow which sucks. That was pretty much the whole reason why I wanted one with WiFi. The camera does create a low-res version at like 200p to make viewing videos on the spot a little easier. If you want that full resolution video though, you'll need to put the SD card into a computer.
    Another weird quirk is the USB connector that powers it is backwards... They provide a cable with a right-angle connector, causing the cable to make this U shape if you route the cable from the top. I tried rotating the camera 180 degrees to make the connector orientation correct, but there's no setting to flip the image, making all the videos upside down.
    Dylan Doxey likes this.
  18. saulbassfan
    979
    3,108
    Southern California
    What a douche. Is it because Prius?
    HelloHybrid likes this.
  19. Dylan Doxey
    1,389
    3,459
    92
    Being a former Jeep guy myself, I would say this is because of Jeep.
    Ramtart, Tracksyde and HelloHybrid like this.
  20. HelloHybrid
    482
    1,483
    Yeah, I'm sure it was just hater. I was driving down that street for a good 2 miles in the same lane by the time the video starts. I cut the video short, but he ended up making a left at the next light, so yeah, not sure what he was trying to prove :rolleyes:
    saulbassfan and Dylan Doxey like this.
