  1. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Watch this thread.
    WHAT DID SFV aka Masta Sean do to my prius | Page 47 | PriusChat
    We're talking about doing one in October.
  2. SubCode
    SubCode Senior Member
    739
    1,341
    just prepare your wallet for Priusmoditis...
    sfv41901 and Jk818 like this.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    It will be "spook-tac-u-lar". Get there early so you can be the first to see the new custom Prius V Hearse, immortalized by Dylan Doxy, Masta Sean, saulbassfan and new member (only seen at night)............Cadaver Dan.
    Jk818 and Dylan Doxey like this.
  4. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Installed VLEDs Triton turn signals, front and rear, and reverse lights yesterday. Much better output/visibility than the cheapo SMD towers I had before. I also switched the turn and reverse, now it's turns on bottom, reverse on top.
  5. intlhouseofdan
    intlhouseofdan New Member
    Massachusetts
    Tinted the tail lights.
  6. Dylan Doxey
    1,389
    3,459
    92
    Oh, cool. I haven't heard of these VLED Triton LEDs before.
    I adapted a set of OPT7 LED Headlight Bulbs for my reverse lights. They are FAR brighter than any reverse light I've ever seen. @sfv41901 & I were discussing the possibility of a similar bulb that illuminates in amber that could be used as a turn signal. I'm going to check this out.
  7. Dylan Doxey
    1,389
    3,459
    92
    I got some fresh G-Sport goodies this week. :whistle:
    Before ...
    And after ...
    And then there was also this. :D
    Boom!
    To be continued ...
  8. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    sfv41901 and granTORRESmo like this.
  9. Dylan Doxey
    1,389
    3,459
    92
    Already have it. (y)
    HelloHybrid, sfv41901, orenji and 3 others like this.
  10. pnkp63
    pnkp63 Active Member
    56
    373
    Looks like Seamless Tank is going to fit well :D:D:D
  11. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
  12. Dylan Doxey
    1,389
    3,459
    92
    I don't think that featherweight thing I removed could be regarded as a "subwoofer."
    Tracksyde, pnkp63 and RightOnTime like this.
  13. Jimi1976
    242
    124
    Denver, CO
    So not the JBL system?
    If you put a full range speaker in the JBL subwoofer location (which is being fed by a crossover), I'm afraid you may have made a counterproductive upgrade
    #13233 Jimi1976, Sep 25, 2016
    Dylan Doxey likes this.
  14. pnkp63
    56
    373
    Will probably give some mid bass punch ;)
  15. Vman455
    539
    556
    The Middle
    That's a midbass woofer, and while it may seem redundant to put in a coaxial full-range speaker, if he's using the stock wiring there is a resistor in-line that limits the frequency that speaker will play anyway, so it will function the same as the original speaker (but perform differently, based on the stiffness, cone material, resonant frequency, sensitivity, impedance, etc.)
  16. orenji
    orenji Senior Member
    5,887
    3,488
    So today I have finally found a product that actually works and cleans early stages of hazing and yellowing on plastic headlights. I did my 2012 PriusC and 2010 Prius Gen III. All you need is Maguries PlastX and a Microtowel to do it by hand. It takes about 5 minutes on each headlight. :D(y)
    IMG_0555.JPG IMG_0548.JPG IMG_0550.JPG IMG_0551.JPG IMG_0552.JPG IMG_0553.JPG
  17. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    I did this yesterday using the Turtle Wax kit. Before the haze was just above the low beam projection outward and was more severe than what you had. This also worked well but involved wet sanding( the 4 levels of grit came in the pack:)).
    Very pleased with the result and will monitor for longevity and report back;).
    The before:
    The after:
    Johnsk93, sfv41901, PriiPrii and 3 others like this.
  18. SubCode
    739
    1,341
    Just a caveat...the oxidation happens on both sides of the plastic..so to get it perfect you will need to open up the headlight and do the same treatment on the inside. Toyota dealership will not honor warranty replacement caused by oxidation.. that's when I got this important added information.
    #13238 SubCode, Sep 25, 2016
    Tracksyde, orenji and Accordlayingkit like this.
  19. SubCode
    739
    1,341
    Good luck..air ride dramatically changes the way your car rides.
    sfv41901, pnkp63, Johnsk93 and 3 others like this.
  20. apt5020
    881
    1,294
    Prius City, CA
    This going to look real nice with the white side reflector. High heat clear coat apply.
    #13240 apt5020, Sep 25, 2016
