  1. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    how often do you recondition your hybrid battery and how do do you do it?
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    First time reconditioning but I have done a top end balance before.
    Supposed to recondition every 6 months. I have 155 k miles on our Prius, so out of any warranty.
    Hybrid Automotive sells the equipment I use and it is easy to do:
    Prolong Battery Systems. Extending the life of your hybrid. – Hybrid Automotive
    I have the charger, bulbless discharger and the harness. Once the harness is installed, the reconditioning is done in the car.
    You could pm @jeff652 and he could provide more details too as he runs Hybrid Automotive (y).
    fopoku2k2 likes this.
  3. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Great. Thanks for the info
    MI 5s ?
  4. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Look like your yellow fog light is pointing too high. Turn off your low beam and check to see if the fog lights are level
  5. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Front windows tinted 35% & attended Wekfest.
  6. Andy grover
    Andy grover New Member
    Kent wa
    Those are not fog lights they are low beams h11 hid bulbs.
  7. xliderider
    xliderider Senior Member
    8,139
    3,274
    Honolulu, HI
    It is normal, Google "squirrel finders headlights", installing HIDs and leaving the squirrel finders unblocked lets glare out that will irritate other drivers.
    The fact that your passenger side doesn't have the pattern might indicate that your bulb isn't seated correctly.
  8. xliderider
    8,139
    3,274
    Honolulu, HI
    Andy, here's a picture of my halogen bulbs against my garage door. The lowbeams before blocking the squirrel finder cutouts, and projector foglights with a proper cutoff:
    Here's a picture of the lowbeams after HID kit installed and squirrel finder cutouts blocked, no rectangles, no glare above the cutoffs:
    Starbrand, sfv41901, JoshM and 2 others like this.
  9. Andy grover
    Kent wa
    Thanks. How can I fix it? I can see the left side glare higher than right.
  10. MPGRaja
    MPGRaja Senior Member
    469
    1,679
    Corona
    Shifting days are over and not to mention weight reduction to gain more MPG's haha ;):love:
    Jon Senum, sfv41901, JoshM and 5 others like this.
  11. xliderider
    8,139
    3,274
    Honolulu, HI
    Check the bulb, it's probably not mounted straight. That's the side with really tight access behind the headlight. Take off the 10mm bolt holding the air intake hose off, unclip the hose anchor toward the front and bend the intake hose up and away.
    If you have a crooked bulb, it could melt the plastic headlight housing.
    sfv41901 and RightOnTime like this.
  12. Ricky.ss
    Ricky.ss Junior Member
    Vancouver
    i d
    i dont think thats normal. maybe theyre not adjusted right or maybe some cheap hids?
  13. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Really been dumping too much money on this car but just order a new headunit along side with the dash kit, wiring harness etc etc.
    Kenwood 893s to replace that factory shit box GPS. Hu features Garmin GPS, Android Auto, 6.95 inch high res screen etc. Can't wait!
  14. xliderider
    8,139
    3,274
    Honolulu, HI
    The rectangles of light above the cutoffs is normal, see my previous post pictures before modifications to remove them.
    sfv41901 likes this.
  15. shaotai
    shaotai Member
    34
    39
    Seattle, WA
  16. Andy grover
    Kent wa
    Which side do I need to adjust the driver side or passenger?
  17. StarCaller
    StarCaller Senior Member
    1,275
    726
    Cedar Crest, NM, USA
  18. Andy grover
    Kent wa
    The bulb is sitting fine it's not loose or crooked I checked. The hidextra rep told me it could be defective bulb so he's gonna send me a replacement.
  19. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Looks like money well spent to me! (y)
  20. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    Sometimes you might have to shim the bulb too. Not sure how common that is with the halogen projector, but I know with my HID projector people sometimes have to put a shim behind the bulb to move the hot spot around.
    Just to confirm, are you talking about the height of the cutoff or that the cutoff has a little different shape to it on the passenger vs driver side?
