  1. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    I have Morimoto hids and it’s been giving me problems after having it worked well for a couple of years.
    When I turn the hids on, it does not ignite. After driving for about 5 minutes or more then it decides to turn on.
    Weird
  2. MPGRaja
    MPGRaja Senior Member
    469
    1,679
    Corona
    I’ve had my DDM hid kit for over two years and still running. I’m just swapping the lens to Morimoto clear lens.
    Xterra72 likes this.
  3. xliderider
    xliderider Senior Member
    8,136
    3,274
    Honolulu, HI
    If you are doing that, you might as well get the Morimoto retrofit projectors, if they still sell them. Then you won't have to worry about blocking the squirrel finder cutouts on your oem projectors.
    MPGRaja likes this.
  4. Oxygen
    Oxygen Junior Member
    Lithuania
  5. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Sure have.. Commute over 100 miles daily. Normal traffic speeds, excessive speeds, no issues. Including in the rain.
  6. Sloth.Power.Prius
    Sloth.Power.Prius Active Member
    104
    331
    Monterey Park
    Sounds good! Where did you get yours btw?
    James Powers likes this.
  7. James Powers
    396
    555
    Bay Area
    I bought it off of Amazon and its a Prime item so you get free one-day shipping! Just look up EZ lip and it will pop up. There is an original and a 'pro' version.. The pro version is 54 vs 35 for the original.
    RMB likes this.
  8. gamma742
    gamma742 Member
    178
    73
    Luxury
    Has anyone tried to pass SMOG in CA with one of these on the intake?
    Dylan Doxey likes this.
  9. tuskin
    tuskin Member
    51
    51
    SFV CA
    serapio.jpg Today purchased the following for my 2010:
    - Beat-Sonic FDA31-3R3 Barcelona Red Metallic Functional Shark Fin Antenna (from Amazon for $19.54 shipped)
    - One set of Cawanerl H8 H11 Auto LED Fog Light DRL from overseas.
    - One set of Cree LED Headlight Kit 6000k 60w from eBay.
    Will post pics when installed.
    Dylan Doxey, granTORRESmo and orenji like this.
  10. Jisnis
    Jisnis Active Member
    119
    117
    Just in case others are interested....I got the rear camber shims from Realcamber.com. Cheapest I found by far.
    granTORRESmo and riceroni87 like this.
  11. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Did you go with the 3 or 5 degree
    iPhone ? Pro
  12. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
  13. Jisnis
    119
    117
  14. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I don't have one, but maybe I can answer your question from experience with other "visual" changes to a car's engine at a smog inspection place. Rule of thumb from a visual standpoint, "if it ain't stock, it won't pass". The technicians are certified by the state of California and everything in the engine compartment should be stock from the get go.
    James Powers and Burna J like this.
  15. gamma742
    gamma742 Member
    178
    73
    Luxury
    That's what I figured but a lot of people buy stuff like this for their cars and some are here is Cali ...granted not many in the Prius Arena..
  16. riceroni87
    360
    598
    Oxnard, CA
    Should pass smog. Although my Prius is stock under the hood.... my truck passes smog in Cali and has cold air and Borla exhaust. I have a programmer for different tunes depending what gas I use even e85.
    iPhone ? Pro
  17. Jisnis
    119
    117
    Took the Prius to West End Alignment today. Had Chris adjust the height, camber and alignment. I love the stance now.
  18. Nopho4u
    1,007
    2,061
    Socal son
    Looks great. U maxed out the oem camber in front? I didn't think it was gonna work with 225 but u made it work
    #14998 Nopho4u, Nov 16, 2017
    granTORRESmo likes this.
  19. Jisnis
    119
    117
    They maxed out the camber on my coilovers and i also had them install toe bolts aswell.
  20. Nopho4u
    1,007
    2,061
    Socal son
    How much camber was the front after all said and done? Also toe bolts? Do u mean camber bolts? I'm not aware of toe bolts
