  1. StarCaller
    StarCaller Senior Member
    1,272
    723
    Cedar Crest, NM, USA
    you need like a 3/8 to 3/8 connector for that?
  2. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Exactly, 3/8th inch to 3/8th inch male to male with two hose clamps closes the cooling loop and prevents the throttle body and surrounding material from heating up to 190+ degrees, which also heats the incoming air and reduces available power.
    Absolutely worth doing for any Prius not in Alaska. And it's easily and quickly reversible. Just undo the hose clamps, take off the hoses and quickly reattach to the throttle body if you need to.
    #16022 TheChip, Jun 6, 2018
    StarCaller likes this.
  3. Shibikku
    Shibikku Member
    40
    104
    Oklahoma City
    Johnsk93 likes this.
  4. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    ahh.. i didnt do that... im done wiring now, wasent to hard to wire, most frustrating was the feeding part from the mirror into the door and formt he door in the car lol. I took power for the puddle lights from the foot lights inside the car, apparently when i worked on it the lights where on all day... battery was down to 10.9V and it refused to start, park-lock is enabled cause it doesnt have any power what so ever... so now its charging, ive heard people have also gotten that message while driving. Atleast i got in while standing still.
    But hey! it worked lol. I wanted the buttons hidden away somewhere so i could just switch the pattern whenever i wanted.
    I took power for the puddle lights from the footwell lights on both sides. And i took power for the blinkers (the yellow wire i believe it was... that gives power to the blinkers even when the car is off) from a 7.5A fuse in the interior fuse box, for the green wire (ACC) i still dont know what does i connected to a 10A fuse i already had my front camera system in, next project now is 360 camera, already found a bunch of stuff to make it an easy install, this install will be so i wont loose the parking assist.
    Accordlayingkit and HelloHybrid like this.
  5. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    Correct me if I’m wrong. But I think that’s the eBay front lip. They have the 2012-2015 version online also.
    Johnsk93 and Accordlayingkit like this.
  6. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    #16026 Accordlayingkit, Jun 6, 2018
    Shibikku and PutPutMobile like this.
  7. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
  8. Shibikku
    Shibikku Member
    40
    104
    Oklahoma City
  9. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Had to hose her down.
  10. PutPutMobile
    292
    518
    Buena Park, CA
    Shibikku likes this.
  11. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
  12. Red_Prii
    Red_Prii Junior Member
    27
    16
    Chicago, IL
    Screenshot_20180607-054521.png Screenshot_20180607-054543.png Screenshot_20180607-054636.png Screenshot_20180607-054837.png Installed on/off toggle for lock/unlock exterior beeper. (Because I'm not 100% sure if I want it permanently off)
    Beeper is above the front driver side wheel. Must remove plastic wheel well cover to get access to this beeper. I then fished wire into cabin (following the hood release cable that goes through the wheel well and into the cabin). Installed a cheap on/off switch interrupting the loop. Popped the switch next to the dash light dimmer scroll switch, into of the unused cutouts. Relocated the exterior beeper under the hood so I can gain easier access if ever needed.
    Disabled interior beeper (reverse beep, seat belt, etc.)
    Removed center dash display unit. Open back of it. Popped off beeper housing. Removed inner "diaphragm". Replaced housing. No more beeping of any kind.
    And if you noticed the center "flying buttress" is missing, I removed that thing a year ago so I can spread my knees comfortably. Quickly relocated the shifter module lower, but still within reach. (So much more room for my knees and better access to put things in the center shelf without the need to do yoga each time).
    #16032 Red_Prii, Jun 7, 2018
    potatoesLOL likes this.
  13. Inza2
    Inza2 Member
    43
    106
    Netherlands
    Very impressive, but you can also turn the beep off with a simple app and OBD2 scanner.... Screenshot_20180607-132507_Dr%20Hybrid.jpeg Screenshot_20180607-132522_Dr%20Hybrid.jpeg
  14. Red_Prii
    27
    16
    Chicago, IL
    Yes, I have the Bluetooth OBD II. But:
    (1). If I disconnect the battery, I'll have redo ALL my beep settings each time or so I've heard (even with the app, it STILL beeps once for each reverse with the Carista app).
    (2). No matter what, it would also STILL beep multiple times when the car was turned on and every time I shifted (As a personal preference, I'd perfer it off. Didn't need beeps my whole life and I still don't want them now).
    PLEASE don't bother telling me about the "safety" reasoning behind the beeps. If it makes you feel better, I kept the seat belts and airbags inplace. I don't want the beeps, so I solved that.
    #16034 Red_Prii, Jun 7, 2018
  15. MagnusAG99
    673
    521
    Norway
    really? mine doesnt do that... it keeps all the settings.. becuase all carista settings is factory options that stay even when u kill the car. It saves it and keeps it.
    I think toyota made the "beep once" feature because its a hybrid lol, u will be surprised how many thats accidently driven forward when they think its in reverse and stuff... Ive read a few articles about it lol.
    And BTW, is that white walls on ur tires?
    #16035 MagnusAG99, Jun 7, 2018
    James Powers and Burna J like this.
  16. Accordlayingkit
    1,616
    1,747
    377
    LOL hey I got out my car the other day at the body shop and told my son to sit still and thought I pressed parked but apparently not and stepped out and it started going fwd.. .freaked out and was able to step back in and apply the break to put it in park before it hit the red brick wall infront of me! Scared the #+&t out of me haha
    Burna J, sfv41901 and MagnusAG99 like this.
  17. MagnusAG99
    673
    521
    Norway
    LOL, IKR! happen to me at school also, i wanted to take a pic of the horizon (my school sits in a very special place lol), so i went out of my car and surprise surprise... it was in drive... lol, i guess the best thing to do whenever u leave the car is to turn it off lol, since it applies the park mode by itself whenever u turn it off.
    Accordlayingkit likes this.
  18. Red_Prii
    27
    16
    Chicago, IL
    You guys can have my beeper and install it to beep while the car is in Drive :D
  19. MagnusAG99
    673
    521
    Norway
    i think id rather need an "idiot" alarm instead lol, maybe a huge speaker sitting in the front that yells out whenever it feels im going out of the car while its in gear "hey idiot, im in drive, BYE!" in Kevin Hart`s voice lol.
    Accordlayingkit and Red_Prii like this.
  20. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
    /// Today ///
    Light work at HybridPit, just rolled out. Kicked it with @TK Rocket & a few others (forgot to get their PriusChat handles :ROFLMAO:). Nice to meet y’all- LMK I’ll tag you on edit.
    1. 5MM Ichiba Spacers
    Added to my front wheels. Subtle but definitely noticeable difference. The wheels sit way more flush with the fenders now. I’m running 5MM front and 15MM rear on 17” Package Five wheels. The rear can likely run 17-20MM nicely, but I like the 5/15 setup :D.
    2. Window Module (OBDII Reader)
    YESS buy this now it’s SO sick hahah (msg @RightOnTime ). Pressing unlock 3x on your key-fob opens all windows, lock closes all windows. Awesome functionality + plugs directly into your OBDII reader.
    Getting folding mirrors soon from HybridPit @sfv41901. So “lock” will now close all windows and fold mirrors simultaneously :eek:. And if you air out your suspension at the same time you’re basically a God.
    3. Avest Sequential Signals - Mirror
    These are dope. Replacing my MIT mirror indicators at the same time folding mirrors are installed.
    I did the side skirts of the Plus Kit. Scared to drill the front/rear bumpers but it’s time LOL.
    Also @RightOnTime and I working on exhaust ideas... for next time :cool:
