  1. BuickGN
    BuickGN Junior Member
    25
    48
    Los Osos
    Not all today but all in this month.... ~76k on it... Redline 0w40/0w20 oil mix, Redline D4 ATF, new Yokohamas, replaced burned out headlight, replaced plugs with regular "copper" plugs, replaced engine and inverter/trans coolant with a 30/70 antifreeze/distilled water mix, ordered new carpet and future wiring to be placed underneath. This is my commuter, 4k+ a month so I'll be repeating much of this month's activities way too soon.
    In the near future, I'll probably obsessively start on the audio with a couple of infinite baffle 15s and Dynaudio front end for my much-too-long daily commute with a goal of adding <40lbs of extra weight.
    James Powers and Accordlayingkit like this.
  2. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    How do you get to the fan?? I would like to clean mine on my 2012 but i cannot figure out how to get to it!
  3. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    Check out the @NutzAboutBolts DIY video on YouTube :)
    GTprii, Sporin, gertsprius and 4 others like this.
  4. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    150k Service Done! Expensive, but major stuffs o hopefully it gives us a few more years of trouble free driving.
  5. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    What did that consist of?
  6. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Spark plugs, inverter flush, coolant flush (these were the bulk of the time & cost), oil change, tire rotation, and a ton of others checks and inspections.
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You didn’t do the plugs at 120 k miles like the manual says:whistle:?
    At least they got done(y).
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,695
    1,742
    Bay Area
    Same with engine and cabin air filters, and transmission and brake flush :whistle::whistle::ROFLMAO::ROFLMAO::ROFLMAO:
  9. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Oh good, lots of passive aggressive assumptions :whistle::whistle::whistle:
    I live in a CARB state, plugs come at 150k not 120k.
    Yes, they are the same exact plugs in CARB and non-CARB states.
    Did I say this was the first service I've ever had done? Why would you assume that?
    I've had every single service Toyota recommends done at the dealer since the day I bought it. Believe me, if it was supposed to be done, it's been done.
  10. NutzAboutBolts
    1,695
    1,742
    Bay Area
    :whistle:
    I was being sarcastic by replying to @Raytheeagle if you haven’t noticed, but hey, you do you. :whistle::whistle::whistle:
    Raytheeagle and James Powers like this.
  11. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Sorry, my bad, my sarcasm meter is broken.
    NutzAboutBolts likes this.
  12. NutzAboutBolts
    1,695
    1,742
    Bay Area
    Lol no worries. I’m just here for the amusement. Don’t mind me :ROFLMAO::ROFLMAO:
    Sporin, James Powers and Burna J like this.
  13. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Manual? Who even reads that? Hand feed me answers!
    potatoesLOL and Raytheeagle like this.
  14. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
    I’m about this life as well :ROFLMAO:
    James Powers likes this.
  15. ASRDogman
    ASRDogman Senior Member
    7,587
    3,909
    Manuals? I'd rather have Automatics! :)
  16. NutzAboutBolts
    1,695
    1,742
    Bay Area
    Manual? My name is Manuel :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    sfv41901, James Powers and Burna J like this.
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Bay Area meet up today in Lafayette :).
    Meetup prep:
    We’ll see some of you there(y).
    m.wynn, James Powers, GTprii and 6 others like this.
  18. NutzAboutBolts
    1,695
    1,742
    Bay Area
    Dang, looks like someone’s getting a full service for their Prius :ROFLMAO::ROFLMAO::ROFLMAO:
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    So the list of what was done at @Pedal Logic ’s place:):
    @Friendlyx was there like @The Critic and I for the social aspects and to lend a helping hand;).
    @edspecR with his son and the addition of sound deadening material. Repurposed works well:).
    @Pedal Logic and Gen3 friend with oil changes and tire inspection which showed the need to replace as a belt was showing:eek:. Then we did the brake flush on @Pedal Logic ’s Prius.
    @gifuboiler with an oil change and trans axle fluid drain and fill :).
    @mrjeff was the winner for biggest job. We did the egr circuit stem to stern and changed spark plugs :).
    Always good to work together and share a BBQ lunch with all the fine vegetables and sides;).
    Maybe we’ll see you next time @NutzAboutBolts (y).
    m.wynn, James Powers, Burna J and 8 others like this.
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I see the orange goop and blue shop towel in the attached image. Hope you all put it into good use (y)
    m.wynn, James Powers and Raytheeagle like this.
