  1. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    My forward splash shield met with road debris at highway speed. Tore the center of the shield out. And I noticed the fender liners were damaged as well so I cutoff the damaged areas and rolled with that until weather allowed a changeover.
    I think the forward cover disrupted the airflow under the car and allowed it to come back up in front of the radiator, cooling the car, or holding temps down longer then they would have with the panels in place.
  2. orenji
    orenji Senior Member
    5,887
    3,488
    2043A3BF-B70E-44FB-8660-995CD2C1417D.png Catch Can on its way! Looking forward to having this installed soon!
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Don’t get me wrong, the TRD RSB serves it’s purpose & matches up nice if ur doing a white theme or a TRD theme.
    For me I liked how it eliminated the end links & there are grease nipples on the bushings plus u can match it up with a Front Sway Bar (FSB)
    aka Masta S
    https://www.facebook.com/100004124476496 Sean Dasselaar (@sfv41901) • Instagram photos and videos Sean D (@sfv41901) on Twitter
    James Powers and orenji like this.
  4. hotelprisoner
    hotelprisoner Member
    101
    85
    Ontario, Canada
    Technology
    I have the same Mishimoto can. The top mount cover is a little flimsy and I’m considering a better mounting solution.
    With the orientation of the ports, I ended up using a straight fitting and a 90 elbow fitting and routed fuel line tubing behind the inverter. Originally I used that clear braided hose from Home Depot - that became brittle and was replaced by good quality fuel line hose.
    I was also going to use thumb screws to speed up the removal process for emptying. I’ve instead fitted a mini ball valve to the bottom of the can and attached a hose barb fitting. I connected tubing that exits underneath the car maybe 6-8” ahead of the left front wheel (there’s already holes in the underpanel in that area that are big enough) and I leave about 1/2” of the tubing protruding underneath.
    The cold weather here means emptying the can quite often which is easily done using a small drain pan under the car ahead of the wheel after my 1 hour commute home while the gunk inside is still “warm”.
    Montgomery, James Powers and orenji like this.
  5. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    I got my hotchkis rsb much much cheaper than the trd new from jegs
  6. orenji
    5,887
    3,488
    And how cheap was it??
  7. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    134 shipped
  8. orenji
    5,887
    3,488
    That’s cheap! :)
    Montgomery, James Powers and sfv41901 like this.
  9. nick31
    nick31 Member
    65
    31
    SoFl
    Why did you switch to Hotchkis rsb after running both trd and Cusco? Shouldn't 2 rsbs be stiffer than 1?
    Hotchkis attaches to the shock bolt correct?
    #17069 nick31, Feb 22, 2019
    sfv41901 likes this.
  10. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Its the end links that I have heard are the weak point in the TRD setup. I didnt realize the Hotchkis one was a more rigid setup. Now I am more interested lol
  11. James Powers
    396
    555
    Bay Area
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    James Powers and Burna J like this.
  13. orenji
    5,887
    3,488
    In coming from Japan ! My Jig Saw puzzle is slowing coming together.
  14. nick31
    nick31 Member
    65
    31
    SoFl
    But but did you notice any difference in handling at all going from trd to trd and cusco and then from both to hotchkis?
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    James Powers likes this.
  16. 04priusnow
    04priusnow Active Member
    345
    201
    sfv41901 and James Powers like this.
  17. orenji
    5,887
    3,488
    All I know is that my Pri with the rear TRD bar handles curves like a much sportier and more expensive exotic! :)
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    This is true.
    As I’ve said in the past, adding “any” RSB on the Prius in the most bang for the buck suspension mod.
    TRD, Cusco, Hotchkis......they all make a great difference considering we don’t have 1 to begin with
    aka Masta S
  19. James Powers
    396
    555
    Bay Area
    Why do you not have a build thread sir!? Im pretty sure you have a lot more going on than what we see on the outside LOL - dont you have some white interior too??
  20. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    In all seriousness, I would love to see some pictures.
    INDREW likes this.
