  1. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    D'oh! Thanks (y)
    marvingloria2011 and Burna J like this.
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Doesn’t look shiny anymore. J/k
    Congrats on the sale.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    They were blown away by the detailing ;).
    Particularly the paint (they asked “is this really almost 10 years old”):).
    Thanks for the assist(y).
  4. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Did you sell it to a fellow PC member? Hope to see it around in the Gen3 forums! (y)
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    A brother of one of @Pedal Logic ’s business associates :).
    You’ll see it around(y).
    RMB likes this.
  6. ASRDogman
    ASRDogman Senior Member
    7,591
    3,916
    Certainly works for me! Catches a LOT of fur!!!
    It was worth $14!
    Burna J likes this.
  7. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Is there at all any dust filters in the cooling fan system? I have been thinking about just cutting out a dust metal filter of a PC and put there lol. But that part seems like a much better option.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    So it’s been in the car 5 days. Just thought I’d give an update. Im pretty well used to using it, but given how it snaps in, I had to modify it a bit. I trimmed some cardboard into strips and folded it up to put it behind the snaps. It had a tendency to rotate in the hole a bit. It will turn if I want it to, but only with some added force. And it can be popped out if I need too.
  9. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    I bought the Stage 10 push button shifter and it came with 3 small pieces of double back tape to help secure the shifter from rotating. Never had a problem after snapping it in. (y)
    Dylan Doxey likes this.
  10. orenji
    orenji Senior Member
    5,887
    3,488
    Waiting for my Tom’s Shifter to arrive, but in the mean time I received today in the mail a used shift surround with all the buttons, so I can mount the Tom’s shifter into it and change out the surround when I want to. My original one will be for the custom shift knob!
    HelloHybrid, James Powers and Burna J like this.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    A fast way to cool down the HV battery.
    1. Use mosquitoes net replacement kit which comes with adhesive strip w/velcro on the other side. Cut net to size and stick net to velcro.
    2. Remove front passenger head rest & fold seat all the way back down. This will result direct air flow from air vents to the HV fan intake, line of sight w/o any air flow obstruction. Other suggestions: Override the HV fan controller and turn it to speed 6, speed 1 only kicks in at 96 degrees. Take all rear seats and back seat bench out for better MPGs. While your at it, take the tanneu cover, plastic compartment panel above spare & compartment folding cover out. Leave the spare tire.
    #17331 Grit, May 1, 2019
    James Powers and RMB like this.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Spark plugs from rockauto came today, pumped for this months meet up.
    James Powers, Xterra72, RMB and 2 others like this.
  13. MPGESUS!
    MPGESUS! Junior Member
    Went and got some wrap work done at Protective Film Solutions here in Orange County. Will post the finished product soon!
    In the meantime... my Prius is certainly among good company here. Not pictured is an Avendator SVJ and a Ferrari 488 Pista.
  14. ASRDogman
    7,591
    3,916
    You forgot the duct work from the right outer vent to the fan inlet. Direct cold air right in the inlet.
  15. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Is there a heat problem?
    marvingloria2011 likes this.
  16. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Yes. Car parked under direct sun rays for 8 hours, HV battery heats up to 100 degree F on start-up in warm to hot seasons.
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Please go into more details, not sure what you mean :)
  18. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Got some engine bling with a VVTi solenoid made in Taiwan. I've got a drag race this weekend so I'll post some runs with or without it to get some data on how much it helps. So far I can definitely feel some more mid end pull.
    IMG_20190501_191210128.jpg IMG_20190501_190902724.jpg IMG_20190501_190605082_HDR.jpg
    StarCaller, Putu Ariawan, RMB and 8 others like this.
  19. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Don't bother checking the temperature on this cause this baby's Hot!!
    RMB and James Powers like this.
  20. maximgr
    maximgr Junior Member
    Montréal, QC, Canada
    Premium w/ Solar Cells
    Just got a 2012 Prius, with Nav, Solar Panels, with 70 000 miles in top shape! Super stoked on it.
    What I did do today?
    Put some brand new Michelin Energy Savers tires on, along with an update of the firm ware of Entune.. (Being from Quebec, we speak french ;) - That's why the screen is in french.)
    Would love to prep my Prius for both bike carrying (checking out roof rack options and inside cargo area protector) and eventually camping.
    Cheers!
    Dylan Doxey, RMB, orenji and 3 others like this.
