  1. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    I sometimes get a hand signal in the form of “you’re #1” :oops:.
    But I also give that out on occasion (y).
  2. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    I've got no one else to show these to, so you guys get to see some Prius drag pictures.
    IMG_3230.JPG IMG_3226.JPG IMG_3112.JPG IMG_3024.JPG IMG_3023.JPG IMG_3020.JPG
  3. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Since removing my sound system last year, I'm trying to quiet the cabin noise a bit for long road trips. One of the projects is to add a third door seal, piecing it together from various cars. Started today with the OEM Gen 4 edge weatherstrip:
    Next up will be the bottom edges, for which I'll probably use Lexus LS500 weatherstrip.
  4. Chalicekey
    Chalicekey Junior Member
    24
    25
    North Carolina
    Rainguards!
    Now I can crack the windows on hot summer days when parked.
  5. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Very nice. Part numbers?
  6. Vman455
    539
    556
    The Middle
    tony_2018 and Montgomery like this.
  7. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    IMG_3919.JPG IMG_3921.JPG It finally warmed up here in Winnipeg and I was finally able to grind that sharp point off in my wheel wells, install my 19's and drop the car. I took the screws out as per @granTORRESmo suggestion. Painted the ground down part with some rubberized asphalt paint to prevent from rusting. Drove it to work today and still heard it rub but not as much as usual. Will check it in the morning after I get home home and see where it's still rubbing .
    granTORRESmo and James Powers like this.
  8. MPGESUS!
    MPGESUS! Junior Member
  9. Xjmyway
    Xjmyway Junior Member
    22
    77
    San diego
    Finally got my suspension installed. Universal Air Solution Series with Airlift 3P management, two Viar 444s and pancake tank all mounted in spare tire area...Stock trunk floor retained. more to come!
  10. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Sick!
  11. StarCaller
    StarCaller Senior Member
    1,273
    723
    Cedar Crest, NM, USA
    can you hear a difference?
    was it worth buying?
    did it fit out of the box?
  12. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Your front plate looks crooked. :eek:
    Grit likes this.
  13. Xjmyway
    22
    77
    San diego
    It's custom...haha! I think only you and I noticed. The PO was a jackass. I've ordered the "correct" factory mount that I will be using to straighten it once my new plates come in 42-96 months!!! Damn Cali DMVs...
    Grit and James Powers like this.
  14. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Sure does feel like it takes that long!
    Grit likes this.
  15. Grit
    Grit Senior Member
    6,520
    4,214
    Wilkes Land
    Just waiting to see road restoration happen with the gas hike “we” voted to keep which the previous governor ushered it in
    RMB and James Powers like this.
  16. Vman455
    539
    556
    The Middle
    I haven't driven the car yet since putting them on. I'm expecting little discernible difference until I get the rest of the edges weatherstripped too. They fit like factory except they're just a little short, so I think I'm going to buy one more to chop up and get the ~2" at the bottom of each door, then on to the rest of the panel edges.
    StarCaller likes this.
  17. Grit
    Grit Senior Member
    6,520
    4,214
    Wilkes Land
    Custom made window shades, maybe one day they will be tinted.
  18. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Why not just tint your windows
    Grit and RMB like this.
  19. Vman455
    539
    556
    The Middle
    Tint still allows visible spectrum light in, while the radiant barrier blocks all visible light transmission and most infrared. Plus, you need more than tint for camping:
  20. Grit
    Grit Senior Member
    6,520
    4,214
    Wilkes Land
    Saving up to buy a house with a garage next year and need to put a big down payment much as possible to keep monthly payments low so I can host Prius meet ups also. Being single in this situation is a disadvantage.
    By the way, have you seen a video on youtube with some guy at a car meetup in a parking garage that just finished having lunch and came back to the meet and completely drooled over a red prius with body kit but had lexus emblem? Thought it was yours. Seen that video yet?
    RMB and Raytheeagle like this.
