  1. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    It's a nice refresh for the rear lights
    TheeWood and Dylan Doxey like this.
  2. Tatnic
    Tatnic New Member
    kittery, maine
    replaced the rear springs but having problems. Excessive knocking when going over the slightest bump. The rubber mounting pad looks okay so what could it be? This car may have been built with the sports suspension or modified before we bought it. I replaced the low riding pimp springs with regular moog springs. It really sounds like the shocks are the problem but I can't seem to figure it out. Replaced the shocks and top mounting hardware but still makes an annoying knocking sounds.
  3. ASRDogman
    ASRDogman Senior Member
    7,591
    3,916
    Something is not tight. You should double check all nuts and bolts to make sure they are tight.
    I replaced front struts on my van twice before I figured out I needed a deeper socket to tighten the nut.
    The socket was slipping and not screwing the nut all the down.
    The knocking sound was because the strut was hitting the nut.
    I just needed to be smarter than the nut! :)
    Montgomery, Ed Beaty and Raytheeagle like this.
  4. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    I would check the top mounts on the rear dampers, if those are loose at all you'll get knocking. You need an open-end wrench and Allen wrench (I forget what size, maybe 10mm?) to tighten them.
    TheeWood likes this.
  5. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    Upgrade endlinks to accommodate for the Hotchkis sway bar.
    #17725 MPGRaja, Aug 2, 2019
  6. 04priusnow
    04priusnow Active Member
    345
    201
    RightOnTime likes this.
  7. 04priusnow
    345
    201
    MPGRaja likes this.
  8. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Non adjustable vs adjustable
    iPhone ?
  9. 04priusnow
    345
    201
    interesting. so you can tweak the ride with adjustable. seems longer right out the box
    Pixel 3a XL ?
  10. Nopho4u
    1,007
    2,061
    Socal son
    Dropped off the car today for wekfest la for the show on Sunday. First major show I ever done outside of yoda fest 20190803_182503_HDR.jpg
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Your car is sitting the lowest of all of them!
  12. MPGRaja
    469
    1,680
    Corona
    Thank you @RightOnTime for the guidance!
    Another direct bolton (y)
    Dylan Doxey and RightOnTime like this.
  13. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    What are these for?
  14. Nopho4u
    1,007
    2,061
    Socal son
    Gotta kiss the ground
  15. MPGRaja
    469
    1,680
    Corona
    It’s the subframe brace. The lower two piece are what Prius comes with. The top one, solid piece is from certain Lexus/Toyota models ;)
  16. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Will it work with the cusco braces?
  17. MPGRaja
    469
    1,680
    Corona
    I have Cusco as well except the Cusco lower arm bar. I don’t think it interferes with any bars.
  18. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    I don't usually post my latest pick up, but this was too good imo. Picked up for a killer deal too. Been going back and forth with refinishing these or not. If I didn't, I'd save money and can just call them my beater wheels. Specs below for those curious:
    Volk Racing CE28
    18x7.5 +33 (squared)
    Also picked up a Blitz washable cabin filter from HP. IMG_20190804_185048.jpg IMG_20190803_102659.jpg IMG_20190803_102728.jpg IMG_20190803_123732.jpg
  19. bobzchemist
    507
    342
    Could you please tell me which Lexus/Toyota models? Or, better yet, give the part number, please?
    I'm also wondering if there's a list anywhere of alternate parts for the Gen 3 Prius. Anyone know?
  20. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    I took my Cusco brace off to replace with that Oem brace. Then again, that Cusco brace was beat up from road rash
    iPhone ?
    Jay J and James Powers like this.
