  1. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Haven't seen very many apparently
    Montgomery likes this.
  2. PaulMS308
    PaulMS308 Member
    Orange county
    Happy Memorial Day weekend!
    This morning slapped on Lower door moldings dip'd Graphite, Black's out Tails, new eBay rear Bumper and Illuminated Door sills
  3. SnowMexicanuck
    55
    66
    Quebec, Canada
    I had the pleasant surprise of seeing stains on both front doors under the mirrors today... I have a special kind of hatred for manufacturers that uses that [insert curse words here] metal for injection molding. It always corrode and turns into white powder and ruins your paint, yet they keep using it. I wasn't having any of that, so I removed the mirrors, took them apart and cleaned them as much as I could before painting them, inluding a couple of baths in muriatic acid hoping it would get rid of the white crap. I was out of primer, so I used my matte green Krylon paint I have laying around. We'll see if last...
  4. ASRDogman
    ASRDogman Senior Member
    7,592
    3,916
    CRAP! It looks new now!
  5. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I would not have used muriatic (hydrochloric) acid without trying vinegar or some other mild solution first, but I'm glad that it worked out OK for you.
  6. ASRDogman
    7,592
    3,916
    If you use the tool correctly............................. :)
  7. SnowMexicanuck
    55
    66
    Quebec, Canada
    Well, it didn't really work anyway, I still had to do mostly manual labor. I had the acid already, so I gave it a shot and I was going to stop if I saw that it was eating that crappy metal away. The best option would be using something like soda blasting, but I don't have the gun or a compressor at home.
  8. PaulMS308
    PaulMS308 Member
    Orange county
    Foglights
  9. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
  10. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    New home for the rear Cusco brace :D
    Don’t think I can ever look at it without the diffuser:cry: So wack
  11. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    When/where did you get that diffuser?
    IG: twnzy_
  12. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Wow, I love that diffuser! What type is it?
  13. MPGRaja
    469
    1,680
    Corona
    Got it back in 2015, when it was available.
    #18133 MPGRaja, May 30, 2020
    orenji likes this.
  14. TheChip
    388
    1,210
    Misissippi
    Wow,that's a long time ago! Who makes that model?
  15. TheChip
    388
    1,210
    Misissippi
    Nevermind, that's a Seibon diffuser with the middle fin torn off!
    If anyone is interested in puchasing they're still available and retail for 4-500 dollars. Just search for part number RL1011TYPRS-MB :)
    TheeWood and SFO like this.
  16. Majafamily
    Majafamily Member
    66
    Elk Grove, CA
    Hardwired my dash cam finally and installed an oem auto dimming read view mirror with homelink.
    I bought all the fluids to change them all out on my almost 65k Prius
    One of these days I'll do oil change. A little After that I'll do transmission fluid, coolants. Probably do brake fluid with my oil change.
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    65K miles and no oil changes yet? In your shoes, I'd pick a day next week.
  18. Majafamily
    Majafamily Member
    66
    Elk Grove, CA
    What? I usually do oil changes every 5k miles despite the Toyota 10k recommended interval. I however haven't changed any of the other fluids. They honestly look all brand new but will be changing it all out regardless
    TheeWood likes this.
  19. JarrettOriginal
    116
    81
    North Hollywood
    The clamp for my hood stand broke, and instead of replacing that, I figured that I might as well upgrade!
    Installed the Sokie Tech Hood Dampers, super easy install.
    No pictures because the car is quite filthy and I'm embarrassed lol
    +5mpg for posting
  20. TheChip
    388
    1,210
    Misissippi
    I installed mine last weekend! I only put in one side, did you do both? One side alone holds the hood all the way open so I didn't see much reason to install both.
