  1. JarrettOriginal
    116
    81
    North Hollywood
    While one side did seem to do the trick, I decided to go ahead with both.
    One might experience some torque, and both should last longer working together (maybe?)
    +5mpg for posting
    James Powers likes this.
  2. PaulMS308
    PaulMS308 Member
    Orange county
    Hard to tell from just a side pix sorry in advanced. Install was just a set of black housing headlights and LED smoked iJDMtoy DRLs....and a quick body wipe down...
  3. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    LOL You're right, you cant tell at all actually, but, lookin good!
  4. SnowMexicanuck
    55
    66
    Quebec, Canada
    I've done like the Carolina Squating trucks and only installed half a lift kit. Finally received my hood shocks after almost two months and decided to try like some people have done and only install one. It keeps the hood up, so I'm fine with that.
    AdrianAsu likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,592
    3,916
    That's pretty nifty! What does the kit cost? Looks simple to install.
    It would be a lot easier!
  6. SnowMexicanuck
    55
    66
    Quebec, Canada
    $36 US on AliExpress.
    SFO likes this.
  7. ASRDogman
    7,592
    3,916
    Thanks!
  8. PaulMS308
    PaulMS308 Member
    Orange county
    Swapped out the Tein H-Tech's for a set a D2 RS Coilovers.
  9. JarrettOriginal
    116
    81
    North Hollywood
    $70 for a pair on Amazon.
    +5mpg for posting
  10. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Just installed JDM-type rain guards.
    Amazon item B009WUIRJK
    I couldn't have got them positioned properly without a pair of helping hands, and when I was installing the first one I found that I had left only barely enough of the peel-off protecting layer of the double-stick tape and had to open the door and grab the tiny projecting bit with long=nose pliers. That protecting layer tends to curl back into position onto the adhesive surface.
  11. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Just installed JDM-type rain guards.
    Amazon item B009WUIRJK"
    You get what you pay for. I use WellVisor guards. None of those problems, and they also look better (IMO). They do cost almost twice as much...50 bucks a set, shipped.
  12. NewHybridOwner
    607
    283
    W. Michigan
    The ones I see at the PriusChat shop use the same 3M double-stick tape, so I don't see what advantage they would have over the ones I bought.
    And the extra pair of hands were just to hold one end in position while I started peeling tape back at the other end.
    RMB likes this.
  13. Michael Craig
    Michael Craig Junior Member
    28
    45
    Oceanside, Ca
    2013 Prius Plug-in
    C8F784A9-1B42-4712-B13E-A3BAEFE26FD2.jpeg 5E7B97C2-E523-4E65-9D73-B79FA8431A8B.jpeg 5B3C4F92-8E0E-4224-894F-BF78E036A516.jpeg
    Wrapped my tail lights today
    JoshM, RMB, FST4WHT and 5 others like this.
  14. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    271 mile joyride @ 64.6 MPG, not too shabby for 149,000 miles. That means 18 miles til Toyota pops the cork on champagne :cry:
    RMB, James Powers, Burna J and 3 others like this.
  15. pree_us
    pree_us Member
    64
    97
    Santa Clarita
    H&R install, forged grey 86 17" TRD wheels with 215/45 Michelin Primacy HPs, and aluminum pedals.
    JoshM, NorCal Prii, RMB and 11 others like this.
  16. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    About 11,000 miles from the OCC, total volume about a shot glass size. Plastic zip ties still holding up nicely.
    James Powers and Raytheeagle like this.
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
  18. PaulMS308
    PaulMS308 Member
    Orange county
    20200607_114021.jpg 20200607_104054.jpg Adjusted down the rear end, might go lower still...
    Oh....this eBay Headunit visor actually work pretty well!!
    #18158 PaulMS308, Jun 7, 2020
  19. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    @PaulMS308 what is that handle/lever just down from the park button?
  20. PaulMS308
    PaulMS308 Member
    Orange county
    Just a USB LED light thingy... nothing special
    Raytheeagle likes this.
