  1. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    In order for these micro fans to impede any type of air flow from the HV fan, the fans would have to spin at least 10,000 rpm. These fans are commonly in network rackmount equipment and sounds like a jet engine taking off at 10,000 rpm. It's not affecting air flow either because the modder is using the app to not allow the HV fan to spin, other modder posts has the temps up to 114 F on battery packs.
    Montgomery likes this.
  2. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    It actually keeps the duct from being warped and the fans are meant to be on while driving also.
  3. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Too small to do anything effective.
    Grit likes this.
  4. M One
    M One Member
    63
    108
    Kuala Lumpur, Malaysia
    Decided to give a Father's day gift to myself.
    Something tells me I will soon regret spending that much money for some covers but for now, feeling quite happy. IMG_20200620_154106.jpeg IMG_20200620_154112.jpeg IMG_20200620_150010.jpeg IMG_20200620_145729.jpeg
    RMB, FST4WHT, Putu Ariawan and 5 others like this.
  5. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Yes, I know that some fans that size run at 10K rpm. but not all: I replaced some 10K rpm ones in a lightly loaded Dell network switch by much slower, quieter ones.
    But, whether those little fans are running or not, or at what speed they run, they are reducing the size of the opening through which the air from the standard fan flows.
    ASRDogman likes this.
  6. NewHybridOwner
    607
    283
    W. Michigan
  7. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    If the duct is well sealed to the stock fan, blocking part of the flow path in the duct will not reduce the volume of air passing through because of the principle of flow continuity (duct area x flow velocity = constant); the same volume of air will still move through per time.
    The faster flow may actually reduce battery temp in itself, without the helper fans. The only way to really know here is to test. AzusaPrius, do you have a Scangauge or Torque app that will read out battery temperature?
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    True, I agree. But the modder haven't changed the default setting on the app for the HV fan to come on therefore there's no air flow going into the pack so these fans are not impeding any air flow because there no air flow. I have app and the fan doesn't come on even over 103, modder haven't change the settings either.
  9. AzusaPrius
    2,184
    920
    Stay tuned I will post pictures soon of the hybrid battery temps. I am using the app only to look at the temps, I have not did not disable the fan or make it run at full speed.
    Vman455 likes this.
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I'm blind and can't see what he did................
  11. AzusaPrius
    2,184
    920
    He put black covers on the coolant jug and hybrid converter.
  12. n0streble
    n0streble Member
    44
    61
    Manhattan Beach, CA
    1438EAE9-A020-49FF-AF49-BC27BB903602.jpeg 19727880-8B12-4EEC-BF47-D1C5CE9266A4.jpeg E5F4D9C6-806F-45B4-B531-EF248322505D.jpeg
    Installed WellVisors
  13. sd1810
    sd1810 Active Member
    105
    361
    Socal
    2015 Prius Plug-in
    Fitted full Liberty Walk.
  14. ASRDogman
    7,571
    3,905
    What is that?
  15. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
  16. JarrettOriginal
    116
    81
    North Hollywood
    That big lower lip?
    +5mpg for posting
  17. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    can't stand lb or rock funny but should be interesting to see
    James Powers likes this.
  18. n0streble
    n0streble Member
    44
    61
    Manhattan Beach, CA
    Went with a different setup and installed Tein Street Basis Z coilovers
    Putu Ariawan, FST4WHT, m3pare and 5 others like this.
  19. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
    Wash, wax, detailed. Car has been basically sitting in the garage for months now. Been driving some but barely any. 8F253944-0452-4459-B392-9CB80702F33A.jpeg
    TheeWood, FST4WHT, m3pare and 6 others like this.
  20. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Damn it.. I need to get my coils installed! Looks good!
    n0streble likes this.
