  1. MPGRaja
    MPGRaja Senior Member
    472
    1,681
    Corona
    I would thing that could work as well. I personally go with OEM fluid since it’ll be in there long period of time and it’s reliable. I was luck to grab 2 gallons OEM for $30.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    That’s pretty cheap for the OE fluid. Mine was the Peak Asian Red that I put in mine. After diluting it looks the same as the OE fluid in the inverter tank. That was last changed on mine at 135k by the previous owner.
  3. ASRDogman
    ASRDogman Senior Member
    7,904
    4,018
    If you put red food die in water, it will look just like the Toyota coolant.
    Won't function the same though...
    And that is a good price. You should have bought 2 extra for the next time. :)
  4. Tom Kat
    Tom Kat Junior Member
    I added a side turn signal under the hybrid badge. Got the LEDs on eBay and tapped the wires into the front turn signals. I also have the Smart Tap turn signal relay module from diode dynamics. It’s pretty sweet.
    here’s a video:
    JoshM, HelloHybrid, Xterra72 and 2 others like this.
  5. n0streble
    n0streble Member
    44
    61
    Manhattan Beach, CA
    Organized my garage and almost forgot I had these... Prius PLUS wheels and Ground Effects kit.
  6. ASRDogman
    7,904
    4,018
    Imagine what you would find if you cleaned your whole house!!! :eek::eek::eek:
  7. nepbug
    nepbug Junior Member
    23
    31
    Denver, CO
    Got it tinted, so glad to get rid of the fish-bowl effect.
    JoshM, BlkGenIII, RMB and 4 others like this.
  8. ASRDogman
    7,904
    4,018
    What percent tint is that?
  9. FriedCells
    FriedCells Member
    95
    72
    Added a Lexus CT200h driver's seat, installed foot space adjustable LED's that can be any color, or flash colors to the beat of the music, and installed neon wire in the shift knob:
    Also, did full engine clean (EGR, PCV, Intake, added OCC, and more):
  10. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Looks great, what will you do with the OCC when it's smog check time?
  11. FriedCells
    FriedCells Member
    95
    72
    Luckily, I just had it smogged 4 months ago. So I have 1 year and 8 months to not worry about it. By then, I'm hoping that I can convince them that it's a closed system, non-ventilated mod and therefore, does not violate emissions standards. If not, it will only take about an hour to remove it, connect the hoses together below the air box without the OCC connected, smog it, and then take an hour to put it back together. Worth it for the ease of access and benefits.
    RMB, ASRDogman and Raytheeagle like this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Another option is to find a shop that understands and doesn't send you through that rigamarole;).
    Those exist too(y).
    James Powers, RMB, Burna J and 2 others like this.
  13. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Pcv valve is a one way check valve. This would lead a backflow of oil from your new location down to the original location of pcv valve. Just a bit confused
  14. FriedCells
    FriedCells Member
    95
    72
    You can see this vid for an explanation:
    RightOnTime likes this.
  15. sadie72
    sadie72 Junior Member
    45
    Chicago
    Whats this Fuelly app? Is it worth it?
  16. PaulMS308
    PaulMS308 Member
    Orange county
    20200731_123259.jpg 1) Swapped out eBay Rear diffuser w/ OEM 3 PC Plus rear air dam I scored off eBay in Winter Grey!
    2) Swapped out rubber from 245-45-17 Arroyo Grand sport - Federal 595's 215-45-17
    3)Re-dipped lower door moldings too gloss black.
    4) Rear wiper delete.
    #18256 PaulMS308, Jul 31, 2020
  17. pree_us
    pree_us Member
    64
    97
    Santa Clarita
    So you swapped to 215/45s? Why?
  18. pree_us
    pree_us Member
    64
    97
    Santa Clarita
    Tablet HU . . . an inexpensive XTRONS.
    RMB, Xterra72, Tom Kat and 2 others like this.
  19. PaulMS308
    PaulMS308 Member
    Orange county
    Mostly for clearance reasons but also because I Love the look of fed tires!
    Even w/ my rear fenders pounded flat I still scrubed bad on freeway bumps the way my wheels are setup. Fed tires also run slightly wide so the 215 actually"Looks" as if 225 but ride like a 215...if that makes sense?? Lol
  20. pree_us
    pree_us Member
    64
    97
    Santa Clarita
    I like the Federal Evoluzion ST-1, that tire's tread looks very similar to my BMW's Michelin Pilots. The ST-1s are only available in 215/45-17, with no 225s available. But after your comment with your 595s, I'll have to check out the ST-1's size closer.
    BTW, your car is looking great. Subtle.
    PaulMS308 likes this.
