  1. sadie72
    sadie72 Junior Member
    45
    Chicago
    I got new spark plugs installed today. I just had the dealership do it.
    Will have some more self install coming up soon.
    Want to paint the brake calipers blue to match the Prius logo. It will make my car faster!
  2. sadie72
    45
    Chicago
    I just got my trans fluid changed at around 150K for the first time.
  3. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
  4. Wicker 56
    Wicker 56 Junior Member
    Columbia City, Indiana
    I changed my oil for the first time. I just purchased my Prius on December 26th of 2019. I decided to try out some of Grit’s suggestions. This will be the first time that I’ve used Liqui Molly or Red line oil in any of my vehicles. I also changed the cabin filter. I was planning on changing the air filter, but it looks like new. 5F1369A5-AA0D-4777-AB0A-715707977250.jpeg
    RMB and Grit like this.
  5. hotelprisoner
    hotelprisoner Member
    102
    85
    Ontario, Canada
    Technology
    Are those the Denso 4711 TT plugs?
  6. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    Old is Denso but the new are NGK Ruthenium HX
    icyrius likes this.
  7. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Make sure you go with an oil filter synthetic media that’s at least 20,000 miles approved if your breaking out redline oil.
    Wicker 56 likes this.
  8. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    67 MPG for the week w/AC on :mad:
    RMB, SFO and Raytheeagle like this.
  9. Wicker 56
    54E9A763-9230-458C-830E-1880A496EEB7.jpeg 5AA2D833-EE4D-40D8-9510-652711D63934.jpeg 4BF3C85E-0815-4F01-B6A5-A20846B91904.jpeg image.jpg I finally got around to installing my new Sony XAV-AX5500 radio with Apple CarPlay and Bluetooth today. I really like using this for my navigation. I also installed a Accele backup camera. I’m impressed with the picture quality for an 80.00 camera. I really need to get a license plate frame and some better looking bolts though.
    #18369 Wicker 56, Aug 29, 2020
    HelloHybrid, icyrius and Grit like this.
  10. sega64
    sega64 New Member
    26
    Olympia WA
    I blew a rod through the block. That’s what I did... lol
    TheeWood and Raytheeagle like this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    That's unfortunate:(.
    Good luck finding a new block(y).
    Grit likes this.
  12. orenji
    orenji Senior Member
    5,887
    3,488
    No oil?
    Grit likes this.
  13. sega64
    sega64 New Member
    26
    Olympia WA
    I’m gonna do the gen 4 swap. Ordered the engine, and tearing down my gen 3 in my spare time in preparation. Should be interesting. Never done anything like this before. I’m a suspension guy.
    Just got done doing oil change, plugs, cleaned manifold, cleaned EGR valve, new EGR cooler, installed oil catch can, new PCV, ...among other small things. But the engine has 240k soooooo I think it was bound to happen. I’ve read about this happening to others often too with 200k+ miles
  14. priusgreymint
    priusgreymint Member
    96
    67
    1. B31AE516-8B26-4D86-9BC7-8D190CE31122.jpeg FEDB6B50-C246-4858-A3A5-AA471ED08868.jpeg 345B17C7-542D-4223-887D-1F01797C322A.jpeg 8E542389-D3DD-4C09-93B5-C25C6A8E1243.jpeg 8E542389-D3DD-4C09-93B5-C25C6A8E1243.jpeg 345B17C7-542D-4223-887D-1F01797C322A.jpeg FEDB6B50-C246-4858-A3A5-AA471ED08868.jpeg B31AE516-8B26-4D86-9BC7-8D190CE31122.jpeg Oil change (Mobile one 0w-20 w/ Toyota filter)
    2. Intake manifolds cleaned with gasket
    3. New pcv valve
    4. EGR pipe clean
    HelloHybrid, Burna J, orenji and 4 others like this.
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    mjoo likes this.
  16. priusgreymint
    96
    67
    I have not , I will look in to this Egr cooler clean
    Thank for the pro tip
    Raytheeagle likes this.
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    No problem;).
    I've done the job about a dozen times, so a pressure washer is your best tool for quick cleanliness and effectiveness :).
    Check out the @NutzAboutBolts videos in the maintenance section and you'll be ready for the setup and execution of the job(y).
    SFO and NutzAboutBolts like this.
  18. priusgreymint
    96
    67
    Looks like next week I will be busy ! Pe
    Nice! @NutzAboutBolts this guy is money saver!
    Thank you again.
    NutzAboutBolts and Raytheeagle like this.
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We prodded him to make the videos ;).
    I tried to make one with @m.wynn that didn't turn out so well:cool:.
    But I'm not a videographer either:whistle:.
    Good luck (y).
    m.wynn, SFO and RMB like this.
  20. Majafamily
    Majafamily Member
    66
    Elk Grove, CA
    Just changed my ICE coolant, inverter coolant, transmission fluid, oil and filter. Everything was OEM fluids except oil and with new gaskets! Transmission fluid had some red to it still but was very dark and nasty.
    Pretty easy job. Wanted to do brake fluid but too lazy to take the wheels off. Maybe I'll pay someone for that haha
