  1. ChapmanF
    18,151
    If we didn't ask so often, we'd have fewer windstorms.
    xliderider and TheChip like this.
  2. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    Wasn't today, but rear G bumper and rear G delete. 20201229_181209.jpg 20210113_211152.jpg
    IG: twnzy_
  3. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    I love the G's rear bumper!
    What spoiler is that? I've been considering switching from the wing to a spoiler like that for a while now.
    TheeWood and Daigi_ like this.
  4. Daigi_
    198
    427
    Hacienda Heights
    Speziell.
    IG: twnzy_
    Putu Ariawan, _xw30_chris and TheChip like this.
  5. TheChip
    388
    1,210
    Misissippi
    Here's how mines sitting right now, besides the dirt.
    Steph1972, Fifen and Burna J like this.
  6. Daigi_
    198
    427
    Hacienda Heights
    It's like seeing double white Henry.
    Are you going to get G/phv headlights any time soon. I have one spare headlight... Can sell it as a set once I complete the set.
    IG: twnzy_
    TheChip likes this.
  7. TheChip
    388
    1,210
    Misissippi
    They'd definitely look better than the stock headlights, so if you manage to complete the set let me know!
    Daigi_ likes this.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I installed the forward portion of the Cat Defender converter shield today. I used M6 rivet nuts, M6x16 bolts and fender washers to install it. I also used M6 rivet nuts, M6x12 bolts and fender washers to install the engine under cover. No more busted or broken push pin rivets.
    tony_2018, mikey_t and SFO like this.
  9. AzusaPrius
    AzusaPrius Senior Member
    2,183
    920
    Picked up my turn signals for my mirrors.
    This should be a fun install and will upload finished pics later. 20210131_094006.jpeg
    TheeWood, Montgomery and mikey_t like this.
  10. AzusaPrius
    2,183
    920
    Cleaned out the intake manifold and slapped a new gasket on it.
    Cleaned a couple hoses that connect to it that had a lot of gunk in them. 20210203_141734.jpeg
    icyrius, Steph1972 and TheeWood like this.
  11. tony_2018
    tony_2018 Member
    227
    68
    Replacing inverter and engine radiators. Can't drain inverter because somehow the damn thing is in there and I stripped it. Time to chisel it out.....
  12. tony_2018
    tony_2018 Member
    227
    68
    Sonofabitch, I got lucky and was able to get it out. Gonna order a replacement and washer. Coolant drained and now time to remove the inverter.
  13. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    1FD354B7-6517-4B19-964D-B98326272AD8.jpeg Installed new fog lights bulbs this morning, amber yellow , major improvement compared to useless stock ones.... here’s some pics , will update when tried at night ...
    Mikethe3d likes this.
  14. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    I take it you got the drain plug loosened?
    Are you going to replace it with a good one?
  15. tony_2018
    tony_2018 Member
    227
    68
    You damn right I am.
  16. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    I'm very sceptical about that 2800 lumen rating on the box, based on the configuration of the actual LEDs.
    Grit likes this.
  17. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
  18. MexicanChip
    MexicanChip New Member
    Las Vegas, NV
    Performed a intake manifold cleaning and EGR cooler / valve cleaning, intake port cleaning and coolant change on my 2015 Prius 90240 miles. The job took 2 days and the most challenging part was removing the EGR cooler.
    one tip to easily clean the EGR cooler is to use Nucalgon condenser cleaner. It cleaned all the carbon off within 10 minutes. No scrubbing, simply soak and rinse off the cooler and solvent and dry off.
    the car sputtered after I started it for a few moments but it was due to the computer trying to recalibrate due to less air restriction. Here are some pictures.
    nrg, Otium, icyrius and 7 others like this.
  19. xliderider
    8,140
    3,276
    Honolulu, HI
    Ah OK, couldn't tell from your original pics that these are COB (circuit on board) LEDs with multiple emitting diodes all around and on the front end.
    I guess the COB-72 means there are 72 diodes emitting light?
  20. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
