  1. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Looks good! Glad it's running good now.
    That stuff is super expensive! Looks like it does a good job though.
    #18601 ASRDogman, Feb 10, 2021
    MexicanChip likes this.
  2. Mendel Leisk
    41,412
    The “executive” description says it’s alkaline, so I’d think somewhat similar action to Oxi-clean or oven cleaner.
    For cleaning coils in-situ think you need something that foams and clings. With the EGR cooler maybe not that important; just cork one end and fill with a moderately caustic solution, let it percolate?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    Looks terrific. Even if it doesn't have anything to do with what you did to your Prime. :D That really looks clean. Hope you put it on the Gen 3 forum, too, so they will see it there. (y)
  4. Mikethe3d
    Mikethe3d Junior Member
    Vancouver, BC
    Had this day planned in advance to do my EGR circuit clean-out because the weather was supposed to be nice and sunny.
    But as usual in winter, mother nature had other plans in place and it started to snow all over my engine bay and tools o_O
  5. MexicanChip
    MexicanChip New Member
    Las Vegas, NV
    Whoops I did indeed put this on the wrong forum page. Sorry guys!
    Mod note: Moved the appropriate posts to the Gen 3 section
    #18605 MexicanChip, Feb 11, 2021
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,151
    Tampa, FL
    Well, this looks dumb now and it's too late to edit it. :ROFLMAO::ROFLMAO::ROFLMAO:
    Nevertheless, thanks for moving what I was responding to to the right forum, @Tideland Prius. You do a great job. (y)(y)
    Tideland Prius likes this.
  7. joeynickels
    joeynickels Junior Member
    23
    48
    Installed these Fiamm El Grande horns on my 2015 to replace the stock meep meep, which round these parts doesn't cut it. Now I can be heard! Wanted to get the Toyota Premium Horns but after some research, concluded they weren't worth 5 times the cost of the El Grandes, which are louder, plug 'n play and snazzy lookin.
  8. southsidedakota
    southsidedakota Junior Member
    27
    22
    After 208k miles, I had brake rotors and pads replaced all 4 corners.
    Montgomery, Raytheeagle and ASRDogman like this.
  9. h3x
    h3x Junior Member
    Poland
    Premium w/ Solar Cells
    DEFA safe start on board. 68b642cc-df7e-423c-873b-ad3def7887c3.jpg 222bd3dc-4791-4c76-ac78-2c6b55e07e36.jpg 373b4b2a-8bb2-4e5c-b186-b0d19e553c00.jpg 79820e62-0e95-4c1f-836b-c88b1f90bc49.jpg
  10. ASRDogman
    7,571
    3,905
    ???? Don't understand what this is or it's purpose?
  11. jerrymildred
    11,517
    14,151
    Tampa, FL
    Looks like a block heater
    Nice! I put Freeway Blasters on both our Gen 4 and Prime. What an improvement!! And easy to do. (y)
    h3x likes this.
  12. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    Got my PlugOut Power Inverter kit.
    This turns my prius into a generator for my house.
    Check out PlugOutPower.com
    They have a discount going on right now that saves you $200
    Code: pres2021 20210212_192302.jpeg
    Burna J and jerrymildred like this.
  13. AzusaPrius
    2,184
    920
    Got my PlugOut Power inverter cable installed today.
    Ready for 3kw pure sine wave.
    Now my prius can be an emergency home generator.
    Today is the last day to save $200 on your order with code "pres2021" 20210216_115213.jpeg
    Burna J likes this.
  14. ChapmanF
    18,153
    What's being shown in that photo? I think I am looking at one conductor, one fuse, one ¿connector in a rubber sock?
    Shouldn't I be seeing two conductors?
  15. AzusaPrius
    2,184
    920
    @chapman
    That is the harness connected to the traction battery, it has a rubber cover at the pigtail to then connect to the rest of the plugout system.
  16. ASRDogman
    7,571
    3,905
    Used 12 ounces of BG109 Engine cleaner
    and let it run for 16 minutes
    Changed oil and filter 0W20 Mobil 1
    225171 miles
    Normally changed at 10,000 miles, but did it at 5000 miles and will change it in another 5000 miles.
    The drained oil was certainly a lot darker than when I changed it at 10,000 miles, so maybe
    it cleaned things out.
    Keeping it at 65mph and less I used about 1 quart between changes.
    And I have some AT-205 Re-Seal I put in at the next oil change.
    I figured it was worth the small investment to see if it makes any difference.
    Raytheeagle and Steph1972 like this.
  17. ChapmanF
    18,153
    I hope there are really two conductors there, and a two-pole connector, and it only looks like one conductor because of the angle of the photo?
  18. joeynickels
    23
    48
    Dressed up the coolant reservoir with a cover. It's not necessary but I'm determined to find all the OEM engine bay covers that exist that were excluded for the US market, that is without paying an arm and a leg for shipping from Japan.
  19. M One
    M One Member
    63
    108
    Kuala Lumpur, Malaysia
    Nothing like a good looking engine bay to welcome you when opening the hood. :)
    Otium, Starbrand, m3pare and 4 others like this.
  20. joeynickels
    23
    48
    Wait a second, your engine cover is black. Did you paint it??
