  1. JarrettOriginal
    116
    81
    North Hollywood
    Had a strut making a lot of noise, so I replaced both fronts today.
    While I has the cowl off, I went ahead and replaced the 4 spark plugs.
    Seems like typical 120k maintenance, plus with the help of youtube, it was a breeze. 20210313_131125.jpg 20210313_123114.jpg
    +5mpg for posting
    Steves895 and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    You do the egr circuit yet:whistle:?
    Another good task to do while the cowl is off(y).
    SFO likes this.
  3. JarrettOriginal
    116
    81
    North Hollywood
    I definitely need to with my milage, but this was enough work for me today.
    Having taken the cowl off twice now, once before to install the Cusco strut tower brace, it's pretty easy. It's just a pain.
    +5mpg for posting
  4. Alan5794
    Alan5794 New Member
    MA
    FIRST POST
    Hey guys I am newish to the world of prius and I want to modify it I saw some super nice ones (I dont remeber the user names). I'm not new to the world of modifications I modded out my old WRX but for some reason I'm drawing a blank where to start I'm gonna install switch back LEDs for turns and painting my rims gold and red any suggestions would be great 20210316_175231.jpeg
  5. Radiospank
    Radiospank Member
    169
    82
    Was the strut replacing worth it? I’m at 132k with mine
  6. tony_2018
    tony_2018 Member
    227
    68
    Replacement engine is on the stand. Tore off the timing chain cover and valve cover. Getting ready to reseal both oil pans and a new rear seal put in place. Replace the orings and reseal the timing chain cover, replace orings in the oil filter adapter. Rplace valve gaskets. Hook everything back up.
    ASRDogman likes this.
  7. JarrettOriginal
    116
    81
    North Hollywood
    My driver's side was making a ton of noise (rubbing/squeeking), and you change them in pairs, so absolutely.
    Also, my ride got more comfortable, the shocks had definitely worn out.
    +5mpg for posting
    Radiospank likes this.
  8. _xw30_chris
    _xw30_chris New Member
    29
    Socal 626
    I was on the same boat but started with small things. Haven’t slapped anything on yet due to weather tho. Aftermarket drls, fogs, lip kit, coilovers are a good start
    Burna J likes this.
  9. Alan5794
    Alan5794 New Member
    MA
    I was looking for a cheap....ish lip kit any suggestions ?? Annd I saw a aftermarket fog/turn sig replacement on amazon that someone recommended for like 80 I was gonna try
  10. joeynickels
    joeynickels Junior Member
    23
    48
    Finally put a cat shield on. Got the Auto Defender because it's quite a bit cheaper than the others. Did a combo of riv nuts and rivets. The rear shield probably isn't helping but it came with so on it went. And i know the shield won't stop a determined thief but hopefully any would be thieves will just move on to an easier target. Also added some adhesive foam weather strips to prevent any rattling. Bit of a pain to install but only because of limited space under the car. On a lift it would be a breeze.
  11. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
  12. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    I tried both, Oxy and oven cleaner. Since my cooler was totally clogged, 5 rinses with Oxy did not do the job. I even poked the passages with wire and it would still bend. Then I tried the oven cleaner from Dollar General and it only took two applications and rinsing to clean it. You must wear gloves or it will burn your skin though. It was a lot more effective than Oxy. I sun dried the cooler and blew compressed air afterwards. Very pleased with the results.
    C999EEFD-3BB9-4B19-B8F5-FEDEE39942A1.jpeg 056BA5B7-6845-4591-B150-7F85BA170F74.jpeg D78CD27A-B160-4D07-BF95-B221DC663D6F.jpeg EE586FBC-35A5-42A6-A737-679EBEB4DFD6.jpeg
    #18692 icyrius, Mar 23, 2021
  13. ASRDogman
    ASRDogman Senior Member
    7,899
    4,018
    Oven cleaner is wonderful! I used it on my RD350 to decarbonize it.
    Next time, since it shouldn't be so clogged, use a pressure washer. That will clear it out.
    Then the oven cleaner with clean it out, using the pressure was to rinse it out.
    It also helps to have a spare cooler. :)
  14. Mikethe3d
    Mikethe3d Junior Member
    Vancouver, BC
    Gen 4 -esque DIY Wireless charging mat for $20
    Super easy to do, here's the charger I used: hooks directly into the 12v system
    https://m.aliexpress.com/item/1005001309582598.html?trace=wwwdetail2mobilesitedetail&spm=a2g0s.9042311.0.0.61de4c4d5GqtfV
    I took out the bolt below the cloth mat and just sent the wires right through there, no drilling required. Then I quite simply stuck the leads into the 12v connector that plugs into the cigarette adapter
    Hot glued the charger straight to the bottom, and then bought a sheet of foam from the dollar store $1.50. cut out a nice border so the cloth would sit even over top of the charger.
    And done! I wanted to make this project as simple and as factory original as possible. PXL_20210313_003148984.jpeg PXL_20210313_002633921.jpeg PXL_20210321_044951561.jpeg PXL_20210324_012716475.jpeg
    Priipriii, Otium, TopRamen and 5 others like this.
  15. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    My project today was to replace the cartridge oil filter with a spin on oil filter. While there I also changed the trans fluid. The spin on oil filter mod was pretty easy as I have access to a lift. I also removed the front right wheel as that made it that much simpler. Good mod.
  16. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    (y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)
    Mikethe3d likes this.
  17. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    Wasn't today, but did a few things this year. Things. I think I'm nearing the end of modding the Prius soonish. A few more things planned.
    Threw in extra pics from the shoot. 20210324_173701.jpg 20210324_173817~2.jpg 20210324_165239.jpg 20210324_170800.jpg
    IG: twnzy_
    Johnsk93, m3pare, Montgomery and 4 others like this.
  18. MPGRaja
    MPGRaja Senior Member
    472
    1,681
    Corona
    Threw out the OEM garbage and replace it with life changers :eek:
  19. privilege
    privilege Active Member
    659
    169
    Birmingham
    more kilmat in the spare tire area, and weather stripping under the hatch trim pieces. I'm slowly getting rid of all the rattles.
    Steph1972 likes this.
  20. Shaun_Durr
    Shaun_Durr Junior Member
    NA
    Daigi_ and TheeWood like this.
