  1. MPGRaja
    MPGRaja Senior Member
    471
    1,681
    Corona
    Minimum disassembly. You can use the existing connector in the OEM speaker to transfer over to the new speakers for plug and play.
    Daigi_ and Steph1972 like this.
  2. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Did the same this week , and front doors speakers too, what an improvement!!! Choose to flush install using the grids for supporting the tweeters , looks good and sounds amazing !!(y) Had to cut bottom side of speakers baffles because it was killing the sound, just wanted to protect the speakers from water...
    icyrius, sfprankster, Burna J and 2 others like this.
  3. Bohemian Grove
    Thanks to Priuschat I installed LED side mirrors! Also added vinyl wrap, TRD springs, and spray painted the stock hubcaps.
    No one knows it’s a base model with 213k miles! The EGR was the only issue it had.
    icyrius, TheeWood, Steph1972 and 4 others like this.
  4. ASRDogman
    ASRDogman Senior Member
    7,899
    4,018
    You should paint the wheel covers red to match the car. :)
    Joele3 likes this.
  5. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    Lol really?
    IG: twnzy_
  6. ASRDogman
    7,899
    4,018
    Yes, really. The "silver" on the wheel covers would look better in red. (y)
  7. AW82
    AW82 Member
    186
    99
    Madison, WI
    So, I bought my 2012 knowing there wasn't a good place (subjective!) to stick my phone while driving. The front cupholder (the one with the lid) is ok with the lid open and no drink there. The little slot between the two cupholders would be perfect if it was about 2-3 inches deeper so the phone didn't fly out when turning corners. Has anyone figured out a way to make this happen in a clean way?
    No, I don't want a phone mount. The lower tray down by the 12v and seat heater controls is too low for my tall self.
  8. 04priusnow
    04priusnow Active Member
    345
    201
    This is what im using
    amazon.com/Nimbus-Mount-Co-TNM1-The/dp/B00X2UEP5Q/
  9. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    I played a little with Techstream and modified odometer to know how will appear when close to 1 million...
    Also is displayed maximum speed.
  10. ASRDogman
    7,899
    4,018
    So you reset the odometer?
  11. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    No, it was only a test, after I closed the test, the odometer goes to old value...
    ASRDogman likes this.
  12. Daigi_
    198
    427
    Hacienda Heights
    Friday.
    G front bumper. Test fit Tom's lip.
    Yesterday.
    Trust Beat Max Ti.
    No, it is not loud and there isn't a sound clip. You hear a low rumble when you turn the car on. 20210404_143425.jpg 20210404_143409.jpg 20210403_010706.jpg
    IG: twnzy_
    Johnsk93, m3pare, MPGRaja and 4 others like this.
  13. tony_2018
    tony_2018 Member
    227
    68
    replacement engine is in
    replacement engine harness is in
    runs smooth
    no leaks
    waiting on new battery pack
    Johnsk93, TheeWood and Daigi_ like this.
  14. tony_2018
    tony_2018 Member
    227
    68
    Where were you able to purchase the springs?
  15. tony_2018
    tony_2018 Member
    227
    68
    But keep the toyota emblem original. It will pop.
  16. ASRDogman
    7,899
    4,018
    Yep! Either paint the "T" red and the background black, or the "T" black and background red.
  17. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    A little bit of autocrossing in the PNW. After the last round of chassis stiffening I've hit the limits of the Tein springs. Next up I need to find a nice set of coilovers for street and track use. IMG_4493.JPG IMG_4526.JPG IMG_4608.JPG IMG_4564.JPG
    Montgomery and Burna J like this.
  18. shaotai
    shaotai Member
    34
    39
    Seattle, WA
    I have a set of Tein's if you're interested. I'm in the PNW too. (reach out to me at shaotai at gmail dot com)
  19. bisco
    52,538
    1A41DDB4-5E71-4762-8116-43E3CA55D18C.jpeg I modified my bumper :oops:
    Johnsk93 and Raytheeagle like this.
  20. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
