  1. ASRDogman
    ASRDogman Senior Member
    7,897
    4,016
    I received the Prolong system last week. Finally installed it. It wasn't difficult to do, a little trickly.
    Remove the bottom rear seat cushion though. So if (when) you drop one of the nuts or fasteners
    you can retrieve them without having to remove everything you've put on top of the seat backs!
    I started the cycles Saturday afternoon and it's completed one charge/discharge cycle and its now charging.
    The first charge photo is when I first started the charge. Then the finished charge.
    Then the start of the discharge, then completed discharge. And start of 2nd charge.
    Steph1972 and Raytheeagle like this.
  2. ASRDogman
    7,897
    4,016
    I installed the wiring harness on July 27. The front bus bars were very clean. Just a little
    green stuff on the positive and negative connectors, the ones for total voltage. and it was
    only on the washers. I had to take them off anyway to install the cables so I clean them.
    But I didn't clean the rest of them. I really didn't have the extra time, and didn't want to chance
    damaging the wiring.
    The rear bus connectors were more corroided, but again, only on the outside. I did remove them and
    cleaned with baking soda and water. Again, it was more on the outside. The connection between the
    plates and terminals of the battery were clean and clear. And since there are no wires, except for the one
    in the more or less center, there was less chance of damaging anything.
    The one thing I didn't do that I wished I had, was measure each unit. I had a brain fart and just forgot!
    I was not happy, as I rememberd AFTER I have put it back together.
    When you remove the essembly cover, there is the vent/drain on the drivers side. Prolong didn't mention it
    in there instruction, and I don't remember anyone mentioning it when they remove the battery, or how to get
    it back together.
    On the front left, there is a tiny opening. IF you can get to it, you can seperate the black hose from the white.
    I couldn't. So I removed the hose where it goes into the body. Then I was able to seperate it with the cover off.
    There is a bracket that holds the hoses in place on the battery, then you route the black rubber hose through the
    metal cover and semi align them while you place the metal cover over the battery. It's tricky, but not difficult.
    I used silicone spray on the hoses to easily connect them after you have the metal cover on.
    I was going slowly, making sure I didn't damage anything or miss anything. It took me about
    3 hours from start to finish, maybe a little more, I wasn't really watching the clock.
    And I cleaned the fan and all the fan ducts while I was in there. The was only a thin layer of dust/dirt on it, as
    did the ducts. I used cue tips and water to clean the fan blades and washed the ducts in the sink.
    The top of the batteries only had minor dust/dirt on them. Easily brushed away.
    The extra layer of filter I added to the vent cover must be doing it's job because there was NO dog fur at all
    throughout the fan or duct work.
    #18842 ASRDogman, Aug 8, 2021
    Mendel Leisk, Steph1972 and Burna J like this.
  3. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
    Bought Sandberg bluetooth audio link for music streaming. It was working great when we tested. Testing was done with my son’s phone and later when i did some test driving (aux was selected but no phone connected) i noticed horrible ground loop noise. Just horrible. Told my son that we need isolator and ordered one (Besign ground loop isolator from amazon, good reviews). It just arrived but when i put it on bass was completely(!) missing. Sound quality rediculous. First thought i somehow broke something but no, without the isolator sounds are perfect. In fact, also the ground loop noise missing when i tested with my phone connected (earlier i tested with my phone not connected).
    My son never complained about any ground loop noise so this was just me keeping myself busy for nothing (and wasting money). Anyways, i installed bluetooth audio link
    Burna J likes this.
  4. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Any pictures of it installed ??
  5. Dr.pri
    Dr.pri New Member
    South Florida
    This is the dongle. It goes inside the armrest
  6. drbtz
    drbtz Member
    102
    51
    United States
    Finally got around to...
    EGR pipe cleaning
    Transaxle fluid change
    Coolant change
    Intake manifold cleaning
    Throttle body cleaning
    She drives like a dream only sitting at 122k miles. I'm still astounded at Toyotas transaxle filled for life talk... That fluid was brown when I drained it...
    Steph1972 likes this.
  7. ASRDogman
    7,897
    4,016
    I completed the reconditioning of my hybrid battery Tuesday evening.
    It sat at 233 volts for 6 hours. I disconnected the charger and it sat for 1.5 hours.
    I started it, and all the lights lite! I was semi expecting that. I turned it off, started again, no lights.
    For about 5 seconds. Then the Check Hybrid Battery displayed and the yellow triangle lite.
    P084A code. Hybrid fan control. I disconnected the 12v battery for 10 minutes, but the code came back.
    Cleared with Techstream, it still came back.
    Of course the Prolong store was closed. But the heat and mosquitoes were active.
    I phoned and left a message then sent them an email.
    I did check the 12v battery, and it was 12.54v. So I put the charger on it at 2.5 amps overnight.
    After 8 hours of charging, it was 12.9v. I waited 30 minutes and checked the battery again.
    It was 12.8 volts. I reconnected it, and pressed the brake pedal, and the button. Check Hybrid once again.
    I took a break, thought about it and figured it was working before the reconditioning.
    So I disconnected the Prolong harness and plugged the fan back in.
    I started the car, NO LIGHTS! So obviously there was something wrong with the harness that failed during or
    after the reconditioning.
    I drove it around the block to make sure it was good to go.
    I was going to send an email to Prolong, but they had already replied and said it sounds like the harness
    control box was at fault and will make one up and send it to me.
    I have noticed that the charge/discharge cylcle is longer. It no longer jumps from sitting at 2 bars for a while
    then to 3 then 4 fairly quickly. It is back to the smooth cycle when I first got it.
    I can run in the EV mode longer, and can drive 44mph after decelerating to 44.
    And I have gained the 4mpg I was losing.
    Over all I would say it has done what it was designed to do with MY hybrid battery.
    My Prius was put into service on July 24th, 2009, so for a 12 year old battery with over 244,000 miles on it,
    it's pretty good! And $1000 less than a new cells!
    I think the battery was just starting to go out of balance and some cells were
    getting weak I probably caught it in time to save it.
    Only time will tell how often I will have to do the reconditioning. Hopefully only once a year.
    #18847 ASRDogman, Aug 15, 2021
    drbtz likes this.
  8. ASRDogman
    7,897
    4,016
    Did you clean the cooler also???
    drbtz likes this.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    We are at 124k on the odometer, cleaned the intake manifold, changed PCV valve, cleaned EGR pipe.
    EGR cooler will be swapped for one currently being cleaned out. Will change coolant (engine/inverter), engine coolant pump, and thermostat and housing. Will keep the coolant pump as a spare. Will also replace the spark plugs, since the wipers and cowling will be removed to access the EGR cooler.
    Will lube the front/back brake caliper slide pins in phase 3 of planned maintenance. Still considering doing brake fluid bleeding.
    At some point, going to clean the HV cooling fan.
  10. drbtz
    drbtz Member
    102
    51
    United States
    No unfortunately. Getting it off has been so frustrating. I bought some box wrenches and am hoping to take it again soon here.
  11. ASRDogman
    7,897
    4,016
    The cooler and intake are the most important parts.
    Don't stress over it. Take your time and take one part at a time.
    Once you get it off, you'll realize it wasn't as bad as everyone if making it out to me.
  12. Ueki
    Ueki Junior Member
    Novi,Mi
    Today I did some Scandinavian drifts (in a closed environment) and also got some petrol!:sneaky:
    Dr.pri, Steph1972 and Burna J like this.
  13. Radiospank
    Radiospank Member
    169
    82
    Painted my wheels, lowered car on trd springs and added 25mm rear spacers
    Here you can see the rear does not have spacers yet B4AE5EAC-0A54-4C29-8E3D-A623A0422267.jpeg
    original color stock rims
    here you can see the rear with spacers installed
    29BC75F6-0710-4C36-A4E0-0131192AB7AB.jpeg 093027AB-CE74-4445-80D3-CE210F28F0BE.jpeg
    Painted rims with rattle can 3 coats, then 3 coats 2k clear
    Dr.pri, FST4WHT, BlkGenIII and 2 others like this.
  14. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    410
    2013 Prius Plug-in
    tony_2018, Dr.pri, w84me and 4 others like this.
  15. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
    Took off my original 17s for 2020 Corolla XSE wheels! Specs are 18x8 +40 F and 18x8 +35 rear (5mm spacer) no rubbing even with extra weight in the rear deck. Tire is 225/40 18 yoko avid.
    overall I was initially concerned with caliper clearance because I had seen that thrown around on the forum, but there is a Gen 4 ive seen around LA with these wheels and so I thought it’d work. Plenty of clearance. So far on my commutes (only have done a couple since) I have lost around 1.5-2mpg. I was running 225/ 45 17 on the stocks.
    4E8611F6-FB4E-4ED1-B3C2-F481FE71AE5A.jpeg 1725F453-911B-49D6-9949-F1F10EFC98D5.jpeg 1B6BCF63-71B2-4CCA-9293-FE71B411EDA5.jpeg E6135F1F-FA8D-4817-A3FF-C45FF3F1EF31.jpeg 2C6C036B-4642-41A7-82EE-24D43FD5101E.jpeg
    #18855 BlkGenIII, Aug 19, 2021
    m3pare, Radiospank, Steph1972 and 4 others like this.
  16. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Looks great.... (y)
    BlkGenIII likes this.
  17. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    New Pirelli tires and clay bar + polish + wax
  18. FST4WHT
    FST4WHT Junior Member
    Sacramento, CA
    Within the last month. Finally settled on 2020 Corolla's.. Screenshot_20210820-180755_Photos.jpeg Screenshot_20210820-181244_Photos.jpeg Screenshot_20210820-181316_Photos.jpeg
  19. xliderider
    8,140
    3,277
    Honolulu, HI
    Celica wheels?
    I finally got tires mounted on old school Subaru Imprezza WRX rims today. The 16 x 6.5 inch Subaru wheels weigh 16.7 lbs on the bathroom scale. Not bad, the OEM 15 x 6 Prius wheels are 15.7 lbs on the bathroom scale. 20210820_115337.jpeg
    #18859 xliderider, Aug 20, 2021
    BlkGenIII and FST4WHT like this.
  20. FST4WHT
    Sacramento, CA
    NICE!
