  1. Yokemonkey
    Yokemonkey Junior Member
    Wet sanded headlights
    600, 800, 1000, 1200 grit
    Covered car with plastic
    Wiped sanded headlights with Stoners window cleaner.
    Sprayed headlights with 2 coats of 2K clear.
    Lights came out perfect.
    Montgomery, icyrius, RayL99 and 2 others like this.
  2. Yokemonkey
    That wheel looks great.
    Outside my price budget.
    What are you doing with the old wheel?
    I’m looking for that style.
    Wanted to buy the leather wrap kit that goes over the old leather.
    Zip 75035
    Thanks
  3. SnowMexicanuck
    55
    66
    Quebec, Canada
    What cable are you using? Our Techstreams at work all have Mongoose cable. Toyota actually specifies what cable to use, from what I remember, it's mostly to avoid issues with the update software, not sure if it can prevent proper access/recognition.
  4. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    Old wheel I threw in storage but it’s the typical plastic one. They have a bunch on eBay for about 100
  5. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
    Detailed for the weekend…
    Montgomery, icyrius, Johnsk93 and 5 others like this.
  6. RayL99
    RayL99 Junior Member
    Sprayed my tail lights with some VHT Nightshades Red. 4 coats of VHT + 4 coats of clear + light wet sand with 2000 grit. IMG_20211128_091709[1].jpg IMG_20220130_192758__01.jpg .
  7. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
  8. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    But is the cutoff determined by the headlight fitting or by the bulbs that are installed?
  9. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    The cutoff is determined by the cutoff shield within each lamp assembly. Doesn't have anything to do with the bulbs.
    Raytheeagle and Burna J like this.
  10. AzusaPrius
    AzusaPrius Senior Member
    2,180
    920
    You can adjust it if needed, the guy I bought mine from adjusted it on his prius and I have not had any issues with blinding people.
  11. ChapmanF
    18,147
    The cutoff doesn't have anything to do with the bulbs, as long as the bulbs are exactly the designed ones, with the filament right at the designed position. If the bulbs are mispositioned, or the wrong type, or are like some LED retrofits where the light is emitted from a wider area than the original filament, then that can mess with the effectiveness of the cutoff.
    There's an adjustment provided on the back of the headlight to move the cutoff up and down. But if you look at in on a nice white wall or something, you will see it is not straight across. It angles further up on the side away from opposing traffic. A headlight for the RHD market will have that on the other side. There might be a way to change that after baking the assembly apart, but it's not a provided adjustment.
  12. NewHybridOwner
    607
    283
    W. Michigan
    I thought I recalled from looong ago seeing cutoff shields within the bulbs.
  13. AzusaPrius
    2,180
    920
    Finally completed the full LED conversion on my prius.
    6000K LED through out the whole car with hyper flash relay all the way down to the footwells and finally today the glove box.
    Replaced the ugly footwell and glove box amber color with the Lexus white and it is so much better. 20220207_122545.jpeg 20220207_120438.jpeg 20220207_190505.jpeg
  14. AzusaPrius
    2,180
    920
    Burna J likes this.
  15. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
  16. AzusaPrius
    2,180
    920
    Yes they are the same part number.
    MPGRaja likes this.
  17. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Kenwood 10.1 with Garmin ( not a Corona Android head unit) PXL_20220207_211452888.jpg
    Dylan Doxey, RayL99, Johnsk93 and 2 others like this.
  18. Matth Torrijos
    Matth Torrijos Active Member
    114
    207
    Poway
    Added a rear diffuser from a mustang
  19. Nosser
    Nosser Junior Member
    Orange, CA
    Threw on some stock Enkei wheels from an old Subaru with an oil change.
    iPhone ?
  20. xliderider
    8,140
    3,276
    Honolulu, HI
