What did you do to your Prime today?
Discussion in 'Prime Accessories and Modifications' started by Raytheeagle, Apr 20, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    Welcome! As my high school shop teacher used to say, "There are no dumb questions."
    I used to jack up one side at a time and do that side before switching to the other side. Then I bought another pair of jack stands to make it easier to have the car level for changing the transaxle fluid. So now it's easier to use the front center jack point and get the front up on the stands. Then take the floor jack to the back get it up on the stands. Then I can get them all done before putting the car back down.
    The problem with using the front center lift point on the Prime is that it's about 54" or so back from the front of the car and my floor jack won't fit under the car. (Edit to add that it will go under the car but that the car is too low to get the fat rear part of the jack under it.) So I drive up on a pair of mini ramps I made out of 2X8 to get the car high enough for the floor jack to fit under it. You can see them in the picture in this thread. Jerry's Evolving Thoughts on "new-to-me" Prime Premium | Page 28 | PriusChat
    As for tread depth, I just have a cheap gauge that has a graduated plunger in inches & mm. It doesn't have to be perfectly accurate. And due to the variances in how you hold it, I don't think any are super accurate unless it's a computerized LIDAR kind of thing.
    #361 jerrymildred, Sep 28, 2021
  2. stomish
    stomish Junior Member
    22
    South Jersey
    PHV GR tail lights installed!
    iPhone ?
    m.wynn, TGrracie and Raytheeagle like this.
  3. jay1105
    jay1105 New Member
    Oklahoma City
    Can you tell me where you sourced those lights? I'm trying to convert my whole rear bumper & light setup to the PHV GR.
    stomish likes this.
  4. stomish
    22
    South Jersey
    I sourced them from Buyee.jp, managed to piece together a set in 3 different auctions :)
    jay1105 likes this.
  5. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Filled to up with gas for the first time in over two months:whistle:.
    Last tank statistics:):
    I at least remembered where the fuel fill door was(y).
    m.wynn, pghyndman and jerrymildred like this.
  7. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    Turns out the husky liners that I had in my 2016 Prius fit just the same in the 2022 Prime. I think I prefer them over the OEM rubber mats because they cover further up the wheel wells in the front and the middle hump in the back.
    I also got a little autobot decal. It amuses me greatly to think that Optimus Prime ended up stuck in a Prius form. Surely Toyota knew the implications adding Prime to the name a few years back.
    And I added some rain-x to the back window. Winter is coming so hopefully it'll help since there isn't a wiper back there.
    Next project isn't until the snow flies - got a set of snow tires on steel rims mounted and ready when it's time.
    dtsexpert likes this.
  8. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    I lied, my next project was tidying up the garage and nailing this neat little cable holder thing for my charger cable. It was only $16. A few dollars less than the $20 plastic garden hose hook I had in my basket at first. Plus it's metal.
    My cable had been just sort of coiled on the ground by some tarps so I threw the tarps in another corner, put this on the side of some shelves, and zip tied the cord to the wall on the bottom of the shelves off the floor. Winters are pretty rough up here and it's not uncommon, when I can't be bothered enough to kick all the snow off the car, that it turns into a salt-dirt-slush puddle around the car. Didn't want that getting all over the cord.
  9. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    I got tired of pressing the wrong temperature control button while driving on bumpy roads, so I cut up some low profile rubber feet so I can feel for the correct button. I didn’t do the same for the other side since the only buttons I use are the volume controls which are convenient to change from the steering wheel controls. 2B989F12-0D69-46BB-A4BA-04125C96FA83.jpeg
  10. 0ddj0b
    0ddj0b New Member
    van
    2022 Prius Prime
    Thanks everyone for sharing their pics! It's inspired me to make a list of things to do as soon as my PP arrives while also planning out future mods.
    Immediate: debadge, tint, de-hubcap, cabin and trunk LED light replacement, add weather-stripping.
    I'm torn on getting clearcoat protection on the hood and bumper as I don't plan to drive on the highway much.
    I would really like to black out the rims soon after delivery, but I may wait until the factory tires start wearing out before looking into it.
    Much later: Upgrade speakers, replace horn, add fog lights, add soundproofing
    Much much later: sideview mirror replacement, fibre optic ceiling lights, wire up inverter with projector for optics, add door footwell lights, add fog-lights or swap out bumper/light with one from higher trim.
    VIncencus likes this.
  11. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    I am a new member who took delivery of a 2022 Prius Prime (base Canadian model) last Tuesday.
    Thanks to all the forum members for your insights as I try to understand to use the PP’s features. I have spent a lot of time searching this forum for information and it has been very valuable.
    First mod on the books was the removal of the tire pump and goop canister. They were replaced with a small conventional air pump and tire temporary plug repair kit.
    Next was the removal of the hub caps and getting wheel center caps on order.
    The biggest mod to date was the installation of the Prius Lift Kit yesterday. I was not comfortable with the inch and a half clearance I had with my 5 degree sloped driveway. I am much happier with the 3” I now have. An alignment appointment is booked for tomorrow and I will post more about the lift kit and install after the alignment.
    iPhone ?
  12. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    The rear passenger glass is factory tint, correct? How about the rear hatch? Any issue with windshield low angle haze?
    I have 50% on my Odyssey windshield and front passenger windows and like it, but low angle haze is a bit annoying. Also night visibility through the side windows can be poor. Is your 15% ever an issue at night?
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Stopped by @The Critic 's place today as he is letting me borrow his quick jacks:):
    Got them home safely ;).
    Now I need to find a place to store them:whistle:.
    Fit no problem in the Prime(y).
    m.wynn, The Critic and Mendel Leisk like this.
  14. don_chuwish
    823
    190
    Southern Oregon
    I’m very tempted to get a set in future. Which model is it?
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    don_chuwish likes this.
  16. stomish
    22
    South Jersey
    Winter tires on! 17x7 Subaru Forester wheels, steel so they’re heavy but they’ll do the job for this winter!
    iPhone ?
  17. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Finally, I installed cloned TPMS sensors into the winter wheels and swapped them onto my PP. I bought wheels and winter tires as a set without TPMS sensors and had them delivered mounted and balanced. Then later I bought a TPMS programming tool (Autel TS508) that came with 8 programmable sensors. I have used the TPMS tool (Autel TS508) for winter tire swap on our two other cars, but not on PP. Was thinking to wait till I have to buy a new set of winter tires, but decided to install them into the wheel this year.
    While the wheels were off, I sprayed around suspension with a rust inhibitor. This year I used LPS3 and CRC 06026 Heavy Duty Corrosion Inhibitor. Last time, I used FluidFilm and WoolWax on our other car. They did work to some extent but seem to wash off easily and did not last long. Also, both FluidFilm and WoolWax are lanolin-based chemicals and in an aerosol can, the application was messy due to the thickness of content. The WoolWax is the thickest and makes blobs when applied on the surface. FluidFilm applies similar to WoolWax but in an aerosol can it runs and applies more evenly than WoolWax.
    LPS3 was slightly thinner than FuildFilm but still is substantially thicker than CRC. I really liked the way CRC coated the surface evenly without making a mess but will wait for the verdict until next spring when the winter wheels come off.
    #377 Salamander_King, Nov 21, 2021
    jerrymildred and Raytheeagle like this.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Did an oil change, tire rotation and catch can inspection at the 50k miles mark:):
    A303D836-9695-4B8C-8909-C93CD3D0EDD2.jpeg A8CCFE0B-1174-48A5-BCD5-D18C8F44C85B.jpeg 311EBEDD-210A-4471-9BC6-46BA86AD15E4.jpeg F323D0CF-377C-4E1E-9B88-7A5F7AD9AE6E.jpeg
    Here's how much oil was collected in the oil catch can since last being checked at the 40k mile mark:whistle::
    So about an ounce, but my EV percentage is about 75%, so it averages about an ounce every 2500 miles;).
    The quick jacks made this easier(y).
  19. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Unicorn PUP and MOA, tuff to beat that brew quality:cool:... All thumbs held high!(y)(y)
    vvillovv and Raytheeagle like this.
  20. Mendel Leisk
    41,427
    Oy vey, ramp envy…
    how does hydraulic fluid pump in, hoses run back to an electrically powered pump?
