What did you do to your Prime today?
Discussion in 'Prime Accessories and Modifications' started by Raytheeagle, Apr 20, 2019.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Did some fluid drain and fills:).
    Currently at 105 k miles and did the following:
    • Rotated tires
    • Lubed brake pins
    • Drain and filled the differential (last performed at 5 k miles)
    • Inverter coolant drained and filled
    • Engine coolant drained and filled
    If doing this job, I found the attached setup to be handy to collect coolant:
    Here's to another 105 k miles(y).
    m.wynn and JC91006 like this.
  2. Mendel Leisk
    42,055
    Yeah good idea; I did similar, pushed a short piece of surgical rubber tubing on the radiator drain spigot, just leave it on. Pushed a plug onto the end to keep it clean. (y)
    We’ll never catch up Ray, at 102k… kms, on our ‘10. :oops:
    m.wynn and Raytheeagle like this.
  3. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Probably won't catch the mpg's of the Prime either ;).
    126.3 mpg lifetime and going strong :).
    Thinking about the egr circuit and potentially doing that over Christmas break. I've had the catch can installed since 22k miles and it does its job. Might be another piece of data(y).
    TGrracie and m.wynn like this.
  4. Mendel Leisk
    42,055
    @jerrymildred reported when working at Tampa Hybrids someone with a gen 4 asked for an EGR cleaning. The car had over 300k miles, and when they got it out found only a light patina of carbon, wasn't really worth it. And I don't believe it was a plug-in either.
    Raytheeagle likes this.
  5. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    The egr circuit is much more difficult to access in the Gen4 / Prime:(.
    Good to know;).
    The catch can I have on our Prime will collect a couple of ounces every 10k miles:).
    Does its job and I have a feeling it'll protect the egr circuit from further carbonization (y).
    JC91006 likes this.
  6. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Ray if you get a chance to look at the Drive Monitor on the MID while showing your lifetime trip, what's the %EV look like for you. I'm currently at 94K miles and showing 110 mpge lifetime. Though my %EV keeps dropping with each road trip we take. Our lifetime mpge was at 133 a few years ago back when our driving was more EV than it is presently.
  7. vvillovv
    4,336
    1,517
    NY
    My lifetime mpge is at 110.1 - 94661 miles - 66% EV and dropping faster than I'd like. Cest la Vie ...
  8. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    I can look into this, but know that I do much more trip driving than I used to;).
    Our kids are in travel sports and every weekend we are going somewhere, sometimes hundreds of miles away:sick:.
    But compared to the vehicle choices of the other parents, I get there the thriftiest way possible:).
    And have enough room to haul the gear required(y).
  9. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
  10. vvillovv
    4,336
    1,517
    NY
    Ray, any tips or tricks on Howto coolant flush and refill for Prime either engine, inverter or both, without techstream?
    My maintenance minder is currently showing a coolant message, even though I don't remember setting it up.
    I've been way to swamped the last couple weeks to have even given the minder a second thought, until today.
    Has another co incident showing on the gauge cluster late last night, ( after 2 similar 200 mile trips yesterday and the day before ), but I doubt I could explain it in few sentences and have it make sense. :coffee:
  11. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    For the coolant Flush, use the setup I have a pic of to drain the coolant through the valve. No mess:).
    The night before the work, I drove around to have the battery at 50%. This allowed the use of charge mode to activate the engine and fill the engine loop;).
    It does take time to fill the engine loop (more time and more engine cycles than on our old 2010), but taking the extra time was an easy way to do this coolant drain and fill (y).
  12. vvillovv
    4,336
    1,517
    NY
    Thanks Ray, I got a gallon of longlife a couple years ago when I noticed the engine overflow was a cup or 2 low. Now the engine overflow tank is full to the tube on the engine intake side and just below the full mark in the other half of the overflow tank. It's been that way ever since I added some longlife to the tank.
    Thinkin as I write I should probably burp it to see if it levels out before I dive in the drain and refill.
    I got the exact same pan as you've got a week or two before you posted the pic and I should be able to find a gallon jug or similar around here someplace too. ;)
    The inverter side hasn't been touched and is still as it was when new to the best of my understanding.
    I'll definitively take a look to see if I've got printouts for the flush from my last repair manual sub. and if not I'll get another sub and cross my fingers there's a non techstream procedure outlined for either or both sides of the coolant refill. :cool: It's good to have the docs on hand and even better ( most of the time) to have some previous experience under the belt, so to speak.
    #472 vvillovv, Oct 26, 2024
  13. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Reached a Palindrome on Sunday:):
    Still running strong(y).
    m.wynn and Mendel Leisk like this.
  14. Mendel Leisk
    42,055
    Hi Ray. We reached 100,000 (kilometres…), Christmas Eve of 2023. Currently close to 203k. Almost weened I guess, but we still need wheels occasionally.
  15. vvillovv
    4,336
    1,517
    NY
    Wouldn't it have been fun to see another drome to the right too ? 3,121,3 :D
    I'm at 96 + K and my lifetime is dropping fast this time of year, down to 109.x
    Today, I brushed the snow off twice and warmed her up driving around the neighborhood. I was gonna get groceries before the store closed, but after cleaning the snow and than the warmup cycle I realized I wouldn't make it to the store and still have any time to grab a few items. So I decided to call it and try for a morning trip tomorrow, which is now today and still in the teens F here. And the last couple of days the temps only go up a few degrees during the day.
  16. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Got to 115k miles and did a tire rotation and took a peak at the oil catch can and drained it;):
    A couple of ounces after 5k miles of highway driving:eek:.
    Glad I installed the catch can around 22k miles:).
    Happy motoring(y).
    vvillovv, m.wynn and Mendel Leisk like this.
  17. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    My radio went on the fritz ! There were storms last night so maybe there was a powers surge but everything else is ok. Trying to get to reset….
  18. vvillovv
    4,336
    1,517
    NY
    Which Gen Prius / Prime @barbaram ? The Gen 3 trim IV ?
  19. ASRDogman
    ASRDogman Senior Member
    7,901
    4,018
    The radio in the Prius???
    The storms wouldn't effect the car radio, unless lightning actually hit the car.
  20. DavidA
    2,349
    1,824
    Chicago western burbs
    Whaaaat? Couldn't you have burned a few tanks of gas and arranged to have it also display 111.1 mpg lifetime?
