What did you do to your Prime today?
Discussion in 'Prime Accessories and Modifications' started by Raytheeagle, Apr 20, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    LED bulb price has come down so much in recent years, I just picked up 60W incandescent equivalent LED bulbs for $0.29 each at a local store. I remember 4-5 years ago, I spent close to $15 a bulb for that. Most of the lightings at my home were with compact fluorescent bulbs already but LED this cheap, I changed most of them.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Take a look at the specs on those bulbs - specs generally vary with the price. If they don't list the CRI, it isn't a good CRI.
  3. Salamander_King
    11,024
    8,980
    New England
    I am pretty sure they were low spec cheap ones made in China. But to be honest, I really don't care to know what CRI they are. If the lights are bright enough and I can see what I need to see at night that's all matters for me. ;)
    jerrymildred likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Got this from Amazon yesterday:
    433E8069-F1D6-4601-B2BB-11AA78531D0F.jpeg 185DA441-6FCA-4537-AAEB-FB02D85BC505.jpeg 86542CA3-D8A8-4DCA-9FB1-8EDF1284FC1A.jpeg
    Trying a different type this time (this is a sporacingrts catch can):).
    Now to find the right spot(y).
    m.wynn and jerrymildred like this.
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    First wash and wax:):
    18AA19CE-6BB6-445D-9919-0F8C75FA5B11.jpeg 9F9DE8D1-E2AC-41FD-900D-223FD5BC3617.jpeg
    Even did the wheel covers for @Mendel Leisk ;):
    Look a bit better than the Gen3’s if I’m honest(y).
    Prius from Dad and m.wynn like this.
  6. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Raytheeagle likes this.
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    This is just the simple Meguiars spray wax too;).
    Wait til @The Critic and I put some elbow grease into it:).
    One of the wife’s friends calls it: the Electric Blueberry:ROFLMAO::LOL::ROFLMAO::LOL:.
    If we get it to shine more, it’ll definitely appear to emit electricity (y).
    The Critic likes this.
  8. orenji
    orenji Senior Member
    5,887
    3,490
    Delete post
  9. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Had tint installed on all the glass:):
    65B17D5A-52C0-448E-BADD-5307BB2BCB11.jpeg 05F2C463-3F65-429F-888D-CC0ECF26FCEC.jpeg 0B6C7588-3985-4323-9134-71C6C4F8F2B4.jpeg 69B6F6F4-59E9-462A-B07C-A231BDB1E397.jpeg
    Llumar ceramic:
    • 15% on the hatch and rear windows
    • 50% on the front windows
    • 80% on the windshield (gives 43% heat rejection)
    Turned out well(y).
  10. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    After the meet up, @The Critic and I went to his shop for additional work:).
    Got the Prime up on the lift, some shots from below;):
    E64A5AFD-329D-4F13-A80C-33B84E5E74B6.jpeg 524110C7-FC50-4BDC-B94F-A3E77F4E1B1B.jpeg
    The lift point is ~45 inches in:cool::
    Which means I might have to side lift first :(.
    The splash shield is interesting too in the way it is molded and fit together, another DIY joy:rolleyes:.
    Shot with the shield off:
    At least the oil change door has screws;):
    Did a trans drain and fill (only at 4K miles, but I wanted to do this early like I did on the RX450h):
    41FFA7F6-B8ED-452C-AFA9-20E27838263A.jpeg BFB909FC-F022-4B07-8287-5ECF0D9DFE24.jpeg
    When you look at the trans axle though, only one drain plug, so where’s the inverter coolant drain:whistle::
    Apparently the lower drain is the inverter coolant loop.
    Also did an oil change as well. The canister appeared to be over torqued and led to this:
    E4F9D54C-253C-44F8-BEEE-1167AC502EF9.jpeg B865F0CE-B9D6-4159-A90B-2FC685E27DA2.jpeg 8905856A-D048-49C2-9C72-18082CFDAC48.jpeg
    Let’s just say that the new one was put on correctly;).
    Great to have a lift for the evening(y).
    #90 Raytheeagle, Jun 9, 2019
    road2cycle, Andyprius1, mjoo and 7 others like this.
  11. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    At the meetup we washed and detailed the Prime:):
    50C1142E-21F2-4E70-B8DB-B38EA673D407.jpeg 8D9532BF-D50C-4E19-BB90-AAF61DF7B85A.jpeg B4995A3A-179E-4219-B7A2-D05D0F7727E0.jpeg 7F0B2BD1-F747-4D76-A150-6ADF41DAEF6E.jpeg
    First time I’ve clayed a car;).
    Turned out well(y).
    m.wynn, SFO, The Critic and 2 others like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    I changed my oil the other day. That's when I discovered that my floor jack will not fit under the car far enough in to reach the front center left point.
    Having the screws for the oil door was very handy. I didn't take off the whole shield. Saving that for when I do the transaxle. I had to change the oil inside our itty bitty garage and there isn't enough elbow room to change your mind when the car's in there. One of these weekends, though, it won't rain and I can work out in the driveway. I suppose I should get on the ball and get the ATF and washers so I'm ready.
  13. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    So how’d you access the oil change door:whistle:?
    I know I’d need to lift it up as it is low to the ground otherwise, but this is how easy it can be:
    https://attachments.priuschat.com/attachment-files/2019/06/168554_IMG_5787.jpg
    @The Critic had a great device that I’ve got in my Amazon cart: a slotted metal jack pad:).
    Stays on the pinch weld and will allow my usual jack to do its job(y).
    #93 Raytheeagle, Jun 9, 2019
  14. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    SFO and Raytheeagle like this.
  15. jerrymildred
    11,517
    14,170
    Tampa, FL
    There are large bolts that connect to the front suspension that I used for the floor jack. Here's a picture that I think @Mendel Leisk provided that's from a Gen 3 that should give you an idea. They are the spots used by the lift in the picture at the right side (front). Gen 4 is similar.
    Then I put the jack stands on the pinch welds meant for the scissors jack. I've never had any issues using those with jack stands at those points since our first Prius oil change in 2014 or '15. But those adaptors @The Critic has sound nice. Do you have the link? If not, I can probably find them.
    road2cycle, Andyprius1, mjoo and 2 others like this.
  16. The Critic
    3,193
    2,333
    CA
    See below:
  17. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Those be the ones :).
    But I got the red ones ;).
    They work well(y).
    jerrymildred and SFO like this.
  18. jerrymildred
    11,517
    14,170
    Tampa, FL
    Thanks. Those are nice! What I normally do is use the jack elsewhere and put the stands under the pinch points. I keep telling myself that I should just fab my own adapters but never seem to get around to it.
    Edit to add. You guys inspired me to go ahead get some jack stand adapters. Just ordered them. For $20, why make 'em?
    #98 jerrymildred, Jun 11, 2019
  19. Salamander_King
    11,024
    8,980
    New England
    The slotted pad in the pic is really nice. I like it is magnetic. I use heavy duty rubber type jack stand pads, but they don't stay on the jack stand after raising the car up to remove it. It gets stuck on the car. I can't remember how much I paid for a set of 4, but I know it did not cost me $14.99/piece. Is yours $20 for a set of 4 or single piece? Are hockey packs cheaper?
    Raytheeagle and jerrymildred like this.
  20. jerrymildred
    11,517
    14,170
    Tampa, FL
    Yes, that was $20 for a set of four. I'll find out when I change the transaxle fluid how well they work and how fussy it is to get the pinch welds to drop into the slots on the adapters as I lower the car onto the stands. It shouldn't be a problem. Here's the link, by the way.
    Raytheeagle and Salamander_King like this.
