What did you do to your PRIUS today?
Discussion in 'Gen 4 Prius Main Forum' started by DBLXX, Aug 2, 2016.
  1. CoolPrius
    CoolPrius Active Member
    218
    291
    86
    Virginia
    2018 Prius c
    pilotgrrl, RCO and 'LectroFuel like this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You into smuggling monitors nowadays? ;)
    CoolPrius likes this.
  3. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
    RCO and pilotgrrl like this.
  4. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I just did that in my gen 2! 4 24" TVs, not monitors, but close enough.(y)
    RCO and CoolPrius like this.
  5. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
    'LectroFuel and RCO like this.
  6. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
    One more modification for the day - Factory rear bumper protector installed. You simply line the letter "i" in prius with the hatch locking bracket and remove the tape underneath. The color might look chrome but it's really a gun metal in most situations.
    I wish it was a more rugged rubberized design. I might consider painting it with some of that truck bed liner later on.
  7. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
  8. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    Hitch and trailer light harness installed. Took it for a test drive.
    'LectroFuel and CoolPrius like this.
  9. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
    Installed the Sylvania LED bulbs in the drivers and passenger door. They are bulb size 168. Nothing wrong with the yellow but the bright white gives it a premium look IMO. Only took like 5 minutes to pry off the cover and replace the lights. Tip I saw online - use tape to remove the factory bulb. That way you don't get your "greasy" hands on them.
    Will probably do the footwell lights next.
    RCO likes this.
  10. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
  11. martintoyota
    martintoyota Junior Member
    Seattle
    Four Touring
    white definitely looks better
  12. Yippeekyaa
    137
    160
    North Carolina
    Husky liners installed. Have weather-tech in the gen 3 and don't like them as the drivers side mat doesn't cover the entire dead pedal where the husky may does. Also the husky mat has gripping nubs on the back side that the weather tech mats didn't have so they don't slide around.
  13. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
    An idea for those of you wanting to add some color to the interior in an inexpensive manner. Use an adhesive fabric or your choice of vinyl film and cover the door handle covers. They are super easy to pop off. This was just an example using some supplies I had on hand. I'll probably go with carbon fiber film as a permanent installation.
    pilotgrrl likes this.
  14. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
  15. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    Just got my Prius back from the detailer yesterday. PPF on front bumper + hood + front fender + side mirror and door cup. They also did the tinting for my prius, front 70% and rear 50% (which is as dark as I can go in Ontario, Canada).
  16. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    I gave mine it's 20k service today including a transaxle drain and fill
  17. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
    I swapped out the footwell lights using the higher end Toyota/Lexus equivalent LED bulb. The drivers side has two screws and a clip holding the under panel on. Once removed just just pry out the light and install replacement. The passenger side has no screws, only 3 clips. Part number is in the image.
    You will be treated with a nice white light and the factory dimmer function still works.
  18. djSyndrome
    djSyndrome Member
    30
    27
    Seattle-ish
  19. CoolPrius
    218
    291
    86
    Virginia
    2018 Prius c
    I got them from eBay. Amazon and global.rakuten.com are other possible options to investigate too.
    djSyndrome likes this.
  20. ColoradoBoo
    ColoradoBoo Senior Member
    1,350
    981
    Monument, Colorado USA
    Nice wheels on that Pearl Prius, Ea8631!
    My wife's 2017 Prius 2 is hitting 25,000 miles so I got out my can of Lucas Oil parts cleaner (for throttle bodies) removed the input hose to the TB and used a rag with the cleaner and cleaned the outside. Then, I gently pushed in the butterfly flap and clean inside of it, top and bottom as well as the edges of the flap, top and bottom. The outside was almost completely clean and there was only a light coating of black varnish on the inside. Easiest job ever. (Remove top of air filter housing, loosen and remove the two hoses with 10mm hose clamps, and disconnect one hose from the top.)
