What did you do to your Prius today?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Benggolf, Sep 10, 2009.
  1. KLD_Prius_PI_Synergy
    68
    82
    Dylan Doxey likes this.
  2. samopriusguy
    samopriusguy Junior Member
    Santa Monica, CA
    Apple CarPlay installed!!!
  3. aspiringnobody
    aspiringnobody Junior Member
    Indiana
    I reupholstered my center console/armrest cover with black vinyl from the hobby store.
    I hope it holds up better than the horrible fabric that came stock!
  4. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    looks pretty professional // (y)
  5. aspiringnobody
    Indiana
    It's a little wonky on the underside of the corners, but I'm happy with it. It was only $12 for the material and the spray adhesive.
    I didn't spray the foam under the stock fabric, just the underside. I also didn't use the little staples that the factory did. Just went slow and held it down until it set. If you buy a foot of the bolt of vinyl you have enough to try three times
  6. horent135
    horent135 Junior Member
    44
    CA
    2014 Prius Plug-in
    I was thinking of this too! any instructions?
  7. samopriusguy
    Santa Monica, CA
  8. aspiringnobody
    Indiana
    Not really. I sort of winged it! You cut it slightly larger than the armrest, and then make slits so the vinyl can go around the ribs and stuff in the plastic under.
    Do the long sides first, and then practice the corners before you spray the adhesive on the ends.
    You have to pinch the vinyl together on the corners to eliminate wrinkles and then cut out the excess.
    I don't have any pictures of underneath sadly. I put silicone goop on each of the tabs to cut down on the creeking, so it'd be hard to get apart at this point.
  9. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Italian tune-up. Ten minutes straight with my foot glued to the floor, not letting up once. Covered 20 miles at full power. Exhaust is clean!
    James Powers likes this.
  10. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Applied Paraflex ceramic tint - 50% 35% 35%. Also installed Class I 1.25 trailer hitch (Curt 11473)
    Before tint: IMG_6220 id.jpg
    After tint:
    Raytheeagle and douglasjre like this.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Did you reset trip A or B before the drive for measurement?
  12. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Now if I could just remember where the start button use to be..............................
    ice9 likes this.
  13. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    That came out pretty sweet. I was also considering this, but haven't gotten around to it yet
  14. privilege
    privilege Active Member
    659
    169
    Birmingham
    I found out blizzaks don't like Florida heat or 70mph !
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    whats the manufacturer date on that?
  16. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    The tire direction in backward. That tire should be on passenger side....
    You should check all the tires to make sure they are going in the correct direction. :)
  17. SnowMexicanuck
    56
    66
    Quebec, Canada
    Why are you still on winter tires? In Florida?
  18. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    411
    2013 Prius Plug-in
    Added a hidden 4500lbs winch behind my front bumper after installing All-Terrain tires!
    Burna J likes this.
  19. bysaul
    bysaul New Member
    Arizona
    Installed the leather wrapped steering wheel on my Prius two
  20. Pax1
    Pax1 New Member
    I bought a 2014 Prius 4 yesterday! 115k miles. It looks brand new. I've always been a VW Golf driver so this is a major change! Nervous about reliability and longevity but the Golf's were always a money pit! Texas mechanics always charge more for VW's. But...I'm really excited as well. I drive 18 miles to work on the highway and back....It's going to be a whole new style of driving compared to my old Jason Bourne style in the Golf LOL! Happy to find this great forum!
    Khezekiah, douglasjre and ASRDogman like this.
