What did your charging station install cost?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tiggerntatie, Jul 26, 2012.
  1. tiggerntatie
    tiggerntatie New Member
    17
    New Hampshire
    For those of you who have installed chargers at home (not just using the provided charging cable), I'm wondering what you ended up doing and what the final cost was. Here's mine:
    I used the included charging cable for a couple of months, but wanted to switch to a permanent solution. I found an electrician who let me buy most of the stuff and drill and pull the Romex, so he just did the final hookup (he rewired my faulty carport outlet while he was at it, too).
    Leviton Level 2: EVB22-3PM from Garrett Smart Electronics $905
    Leviton prewire kit form Amazon $75
    250' Romex from eBay $70
    Local electrician $206
    Total: $1256
    Gas walls likes this.
  2. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    462.00 for open evse charging station and about 70.00 to replace main plug, circuit breakers and wire. self install.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    GE Wattstation with Federal rebate $700, free 240v outlet installation and self install. Basically, all I have ever used is my Wattstation. The included 120v evse has been used only a few times, maybe 10x in 5 months.
    52,804
    what size romex was it?
  5. heather somaini
    heather somaini Junior Member
    76
    Los Angeles, California
    I went through Leviton and they did everything for the essentially same price.
  6. tiggerntatie
    17
    New Hampshire
  7. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    Do you have a link to the one you purchased?
  8. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    i made the open evse.
  9. ultraturtle
    108
    81
    Peachtree City, GA
    Self installed.
    Leviton EVB22-3PM, $933.48 from Amazon. I placed the order with Garret, but they charged my card and never bothered to send the unit - I cancelled the order after waiting 3 1/2 weeks. Amazon unit arrived 2nd day air, free shipping.
    The prewire kit is unecessary - the unit can mount on simple screws, and I did not need the weather-resistant outlet cover. I saved about $68 by getting a cut-in box, 240v outlet, and cover plate for about 7 bucks at Home Depot.
    I had plenty of 12-2 Romex, wire nuts and a 220v 20amp breaker on hand, so total installed cost was about $940.
  10. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    Leviton EVB22-3PM and prewire kit from Amazon. 10-2 Romex (the cord on the EVSE is also 10-2) which can be read on the cable itself. Unit came same day as delivery of PIP. Hung on wall, and have never yet used the Level 1 that came with car, still in box. Total $1154.
  11. tiggerntatie
    17
    New Hampshire
    My electrician suggested the same, but I was swayed by the install instructions, which implied the kit was necessary. Only when I went to put it up did I realize I had been lied to. On the other hand, the install template for locating the outlet in just the right spot was much more useful than I would have guessed.
  12. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Aeroenvironment EVSE-RS: $500 ("used" from cwerdna)
    Installation by local electrician: $500 or so (includes permits, but don't have the final bill yet).
  13. ultraturtle
    108
    81
    Peachtree City, GA
    The unit draws a maximum of 16 amps requiring no more than 12-2 Romex and a 20 amp breaker unless you have an insanely long run, or your local codes deviate significantly from the NEC. If either case applies, you probably need an electrician to install it, but most of us do not.
    Good on you for installing 10-2, though. It will enable you to upgrade to a 30 amp charger for your next EV. I'll have to pull another cable when that happens, but I hope to be driving my PiP for another 15 years.
  14. pineprius
    245
    134
    NC
    I did have a 70 foot run, and felt the advantage of 1)lower resistance and heat (safety), 2)less V and Amp loss, and 3)never having to snake another cable, had a lot to do with the decision. The cable cost difference was minor.
  15. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I paid $117 for Romex, an outdoor, covered outlet, staples, a GFCI circuit breaker, and misc junk.
    I paid $170 for the permit.
    I just bought a 240V GFCI breaker online for $35, and I'll just need a $5.00 receptacle to switch to 240v. I'll probably upgrade my EVSE to 240v, which will cost about $170.
    So 240v will cost me $327 + $170 in permit fees.
  16. hill
    9,021
    Planning for the future - we did a 7' run of 10-3 (through conduit - not romex) off a 40amp breaker for our AV unit, so if/when charging can be done at 6.5kW (as it ought to be NOW) we'll be good to go. I would truly hate life, if/when on-board chargers can pull a decent amount of power, and I ended up having to do a re-do.
    EDIT
    anyway - after 50% of cost/incentives picked up by the state - it was just over $900 (what a rip off)
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  18. Rebound
    3,996
    2,645
    Portland, OR
    That seems like a bad idea. An expensive solar panel should generate electricity through all daylight hours, not only when a car is plugged in. On the other hand, the greenest approach to EV charging is to do it at night, off-peak.
  19. hill
    9,021
    oops - double post
  20. plugable
    plugable Junior Member
    59
    Rancho Cordova, CA
    Cost of wire, conduit, receptacle, etc., to move my 240 v. dryer outlet to a more desirable location: $90.00
    Cost of GE Wattstation (purchased on eBay): $800.00
    Cost of convenience of being able to leave Toyota supplied EVSE in trunk, plugging charging cable into Prius in 10 seconds, and having car charge in 1/2 the time: priceless!
