what do I do... stuck on hyway
Discussion in 'Generation 1 Prius Discussion' started by Sytex, Feb 6, 2013.
  1. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    So... My car started making a loud thud noise... Thought I blew a tire...sounded similar... But I see nothing wrong... Not sure where to tow it to....
    52,863
    i would take it to the nearest toyota dealer, unless you don't need it repaired right away.
  3. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    can you look underneath and see anything hanging down? are there any warning lights on? will it do it while moving or sitting still. you may have run over something not knowing it and it got stuck under the car and is flapping.. could ba a possibility that that plastic shield tht attaches to the front bumper is coming off and flapping because of wind
  4. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    Wish it was that easy... I don't see anything real obvious.... There is quite a bit of grease and what look like grease covered wire hanging down where the drive shaft and the cv joints and tie rod connect
  5. scotman27
    735
    82
    PA
    2001 Prius
    maybe you lost a cv joint. will the car even move? if the car does move does it start thumping right away?
  6. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    the sound happens with revolution of of the tire... Not when idling in park.... No warning lights... But my engine got louder too... Whick seems strange
  7. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    The car will move... But I dont want to go over5km/hr with this sound the way it is
  8. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    I could be imagining the louder engine
  9. scotman27
    735
    82
    PA
    2001 Prius
    ok, im thinking it is a blown cv joint on the axle.
    addressing the possible engine issue: if you ran over something check your exhaust, if you did run over something it could of knocked something loose on the exhaust. start the car and crawl under there and listen to the exhaust see if you hear it leaking.
  10. scotman27
    735
    82
    PA
    2001 Prius
    That too, sometimes when you get into a situation sounds can seem louder and things can seem like they are all wrong.
  11. scotman27
    735
    82
    PA
    2001 Prius
    but this thumping noise and grease sounds like a blown CV joint. only way to really tell is to jack it up, either get under there and wipe everything off and check the CV joint boot, or take the tire off and check the CV joint boot.
  12. scotman27
    735
    82
    PA
    2001 Prius
    Sounds strange but you could of ran over a plastic bag and that son of a gun got wrapped around the CV boot and cut it up and blew out the CV joint. and what you see that is greasy wire is actually the bag. I have seen this and heard of it happening.
  13. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    oThanks... Just waiting for tow truck.... Will take it too tooyota tomotow
  14. scotman27
    735
    82
    PA
    2001 Prius
    not a problem, let us know what they find, but im banking on a blown CV joint, thats what it seems like. is this on the drivers side or passenger side?
  15. scotman27
    735
    82
    PA
    2001 Prius
    By the way, your doing the right thing getting it towed, i would not drive on that either. Good job, some people get fed up and just drive the car and that can make things worse. not necessarily for the car (depending on what broke) but for the person themselves because it can completely bust and leave them sit in an intersection or something. Kudos to you being smart.
  16. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    Drivers side I found the grease... It was making a clicking noise when I accellerated from a stop before this... So I assume you are right... Only thing I found weird is it didnt matter if I turned or not... And it was really quiet.... Not like other cars ive had with cv joint problems
  17. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    If no warning lights on dash probably not Hybrid related. You may want to go to a regular mechanic. Dealer will be expensive for something like an axle. An independent shop can sell you aftermarket axles much much cheaper.
    Similar axle setup as Toyota Echo. If shop can change Echo axle they can do gen1 Prius.
    yotatoter and scotman27 like this.
  18. scotman27
    735
    82
    PA
    2001 Prius
    I agree with paul.
  19. scotman27
    735
    82
    PA
    2001 Prius
    Let us know how you make out.
  20. Sytex
    Sytex Junior Member
    44
    BC Canada
    2001 Prius
    well... I took it to my local toyota dealer in Port Moody, hopefully will be reasonable...
    I suppose I could have used a normal mechanic... but Im still not totally sure if thats all that is wrong or not, because im sure the engine got louder somehow...
    will keep you posted
