What do I need to make these wheels work?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tpme06, Sep 19, 2013.
  1. tpme06
    tpme06 Junior Member
    I've always used stock wheels, but I would like to put winter tires on the stocks and get some new summer wheels. I do 85% highway, so I would like to keep them at 15" so I don't lose any mpg. These rims are on Craigslist locally for a good price, but what will I need to get them to work? I'm assuming spacers since the offset is only 38? The bolt pattern is fine, so my only other concern would be the larger bore size. Any input is much appreciated, as I would like to pull the trigger on these rims if I can make them work alright on the Prius :)
    Enkei T-FORK Performance Series Wheels
    5x100 Bolt Pattern
    72.6mm Bore
    Offset: 38
    Thanks!
  2. tpme06
    Anyone know the answer to this? I don't want to bite the bullet and have issues after I buy :unsure:
  3. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Just hubcentric rings to center the wheels before tightening the lug nuts.
    SCH-I535
  5. xliderider
    8,140
    3,280
    Honolulu, HI
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    Try to find out how much the wheels weigh as well. If they're very heavy, you will lose mpg as well, even though they are 15 inches.
    SCH-I535
  7. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    According to Tirerack they weigh 16lb..
    I think the RPF's, PF01's, or NT03's may weigh less.
