What do I need to read Toyota specific codes?
Discussion in 'Gen 2 Prius Main Forum' started by Levy B, Apr 25, 2022.
  1. Levy B
    Levy B New Member
    Virginia
    Hi folks,
    I’m a grad student far from any Toyota dealership and need to diagnose my red triangle issue. I believe it’s something with the hybrid battery.
    What’s the minimum setup I need that will read these codes?
    I’ve tried searching threads and have found mixed opinions regarding which scanners will and won’t work. What’s the tries and true method here?
    Thanks in advance!
    49,540
    mini vci/tech stream, and a compatible laptop. cheap money, but requires decent computer savvy. lots of threads here.
    Levy B and JohnPrius3005 like this.
  3. ChapmanF
    15,717
    Techstream is certainly the gold standard, but you might get serviceable results from other setups too, depending on your needs.
    You might take a look at this review thread.
    Levy B likes this.
