What do the rims look like under the caps on the Prime's wheels?
Discussion in 'Prime Main Forum (2017-2022)' started by ChachabahPrime, Mar 25, 2017.
  1. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    thanks for posting, i took the wheel covers off today after my Prime got its first wash as part of the 5k service yesterday, will look at this for a few days and decide which looks better for me, and if the covers remain off, i shall get these center caps
  2. joachimz
    451
    612
    17
    SoCal
    I think i have a winner ... i don't have a pre- picture but i do like this look much better :cool::cool: ... off to Amazon and order :)
  3. Mendel Leisk
    41,463
    Hopefully this doesn't sway you:
  4. DavidA
    2,345
    1,821
    Chicago western burbs
    I see what you did there. You went to his house in the night, stole his stock wheels and gifted him nicer aftermarket rims. Did you upgrade his tires also?
  5. joachimz
    451
    612
    17
    SoCal
    yea ... i was wondering why the speedo was set to km/h ...:confused::p:D
  6. Mendel Leisk
    41,463
    Guilty as charged, except: they're not aftermarket: OEM rims on the previous PIP. No covers.
  7. pkmntrainerharry
    pkmntrainerharry New Member
    17
    17
    DFW
    Does removing the hubcaps reduce MPG?
    HPrimeAdvanced likes this.
  8. joachimz
    451
    612
    17
    SoCal
    good question, haven't noticed it yet, i will see what my EV range does during the week when commuting and will report back ...
  9. Heikki Finland
    Finland
    Excel
    Just changed tyres to 17th inch Prius 4th gen + Good Year tyres..much smoother and quiter than original nanoenergy tyres and they look awesome too..
  10. D B
    D B Junior Member
    Pretty sharp. What size is the tire? It appears to somewhat low-profile. Is the outside circumference (ie, the diameter) of the tire the same as the OEM 15" tire. Does it affect your speedometer reading? Does your tire contact the road in the same place or is there some offset.
  11. Washingtonian
    Washingtonian Senior Member
    726
    621
    Washed the car today and removed the plastic hubcaps. I was pleasantly surprised to note the chrome plated lug nuts. Assumed since they can't be seen that they would just be steel and something else to replace. Also surprised how much brake dust was on the wheels. I guess on cars with aluminum wheels it normally gets blown away, but these hub caps retain it. If there is this much in less than a thousand miles, imagine how much there would be with 50K miles. Thought I might be able to use the center cap on the hub cap, but it is about a half inch too big. One thought: If and when I curb the wheels, just put the hub caps back on and all is well ;).
    dalcon95 likes this.
  12. Heikki Finland
    Finland
    Excel
    It is the same alloy wheel than in 4th gen prius i.e. 225/45 and 17 inch..No significant effect to speedometer..OEM Nanoenergy tyres are quite noisy in our rough tarmac and these are much better..for the comsumption they propably have same effect than in 4th gen Prius i.e. 2 mpg..
    #32 Heikki Finland, Jun 4, 2017
    HPrimeAdvanced and YPizza like this.
  13. Mendel Leisk
    41,463
    Agree with all the above, except just for the sake of accuracy: the size is 215/45R17.
  14. Heikki Finland
    Finland
    Excel
    Yes exactly
    HPrimeAdvanced and Mendel Leisk like this.
  15. JimE2017
    JimE2017 Junior Member
    29
    43
    Maynard, MA
    I just purchased a Prius Prime Advanced on Monday and I know that the parts department says there is no wheel cap listed for the Prime. However the same wheel is sometimes used elsewhere and the Toyota part number for the cap that works is 42603-52170 which is black and chrome plastic and Toyota charges $97.00 plus local taxes for four caps. I know it fits cause we put one in a few hours ago. Some web sites list 42603- 52110 or 52130 as compatible however they only fit 1st gen plugin not the 2nd gen Prius Prime
    Prius from Dad and Mendel Leisk like this.
  16. Washingtonian
    726
    621
    I just ordered a set last weekend from a Toyota dealer in Cupertino, CA who sells on Amazon. $77.72 including shipping and no sales tax. Should be here by the end of the week. Now the next decision is do I plasticoat them black, dark gray, or bronze or leave them alone.
  17. Washingtonian
    726
    621
    Sorry, senior moment. Came from Santa Clarita, CA.
  18. Mendel Leisk
    41,463
    Stock is nice. You mean plastic-dip, ie: something reversible?
  19. Washingtonian
    726
    621
    Yes. Have never done it before, but googled it and looked at a few videos and it looks pretty simple. Also saw one where a person did his BMW wheels and then peeled it off a year later. If you apply a few coats (like 4 or 5), and you don't like it later, not a big thing to peel it off.
  20. joachimz
    451
    612
    17
    SoCal
    The short answer is yes, only slightly though, but I cannot really quantify it. It "costs" me ~ 1 mile EV range which for me is ~2.3%.
    What I observed during my commute this week (I've described my commute in the post "My EV range story", usually I've had 2-4 miles of EV range left when arriving at work
    Mon: EV range leaving 43.2, down to 1.5 ~ 3miles from work, switched to HV for a mile or so and arrived at work with 0.1 EV left.
    Tue: 43.3 departure, 5.0 arriving
    Wed: 43.5 departure, 1.8 arriving
    Thu: 43.6 departure, 1.3 arriving
    Weather was consistent all week, the typical fog/overcast for Jun with temps mid/high 60s
    I try to go the same speed, set DRCC to 67 on fwy
    Tue I had to leave earlier than usual so hit more traffic, a bit slower but still no stop/go
    For Mon running out of EV, I have no explanation.
    I keep monitoring ...
